SCW2012F Series
Wire Wound Chip Inductor
1. SHAPES AND DIMENGSIONS
L(Max)
W(Max)
T(Max)
E(Typ.)
F(Typ.)
D(Typ.)
1005(0402)
1.19
0.66
0.64
0.40
0.64
0.64
1608(0603)
1.80
1.25
1.20
0.64
1.02
0.64
2012(0805)
2.29
1.73
1.52
1.02
1.78
0.76
2520(1008)
2.92
2.70
2.23
1.02
2.54
1.27
3225(1210)
3.50
2.90
2.25
1.02
2.54
1.78
4532(1812)
4.80
3.40
3.15
1.14
3.05
3.00
CODE
DIMENSION
UNIT:mm
2. PART NUMBERING SYSTEM
Rev.01
SCW
2012
F
R47
J
S
T
HF
1
2
3
4
5
6
7
8
1
PRODUCT SYMBOL(产品代号)
2
DIMENSIONS (规格尺寸)
3
MATERIAL (芯片类型)
4
INDUCTANCE(电感量)
5
TOLERANCE(公差) :F±1%;G±2%;J±5%;K±10%;M±20%
6
TERMINAL (端电极材料): G-金端头;S-锡端头;Y-银钯端头
7
PACKAGING (包装方式):T-编带盘装;B –散装
8
PHOSPHATE FREE(无红磷)
P age 1 of 13
www. sunltech.com
SCW2012F Series
3. ELECTRICAL CHARACTERISTICS @25
SCW2012FR47*ST
SCW2012F1R0*ST
SCW2012F1R2*ST
SCW2012F1R5*ST
SCW2012F2R2*ST
SCW2012F3R3*ST
SCW2012F4R7*ST
SCW2012F6R8*ST
SCW2012F8R2*ST
SCW2012F100*ST
SCW2012F150*ST
SCW2012F220*ST
SCW2012F330*ST
SCW2012F680*ST
4. Recommended Soldering Conditions
PRE-HEATING
SOLDERING
20~40s
TP(260 C / 10s max.)
TEMPERATURE(
C)
Figure 1.
Re-flow
Soldering (Lead
Free)
NATURAL
COOLING
217
60~150s
200
150
60~180s
480s max.
Note:
‧Preheat circuit and products
to 150℃
‧280℃ tip temperature (max)
25
TIME( sec.)
Rev.01
P age 2 of 6
www. sunltech.com
SCW2012F Series
PRE-HEATING
SOLDERING
NATURAL
COOLING
TEMPERATURE C
260
Figure 2.
Wave Soldering
Note:
‧Never contact the ceramic
with the iron tip
‧1.0mm tip diameter (max)
245
150
Over 2 min.
Gradual Cooling
Within 10 sec.
PRE-HEATING
SOLDERING
NATURAL
COOLING
3s(max.)
350
10s(max.)
330
Figure 3.
Hand Soldering
Note:
‧Use a 20 watt soldering iron
with tip diameter of 1.0mm
‧Limit soldering time to 3 sec.
150
Gradual Cooling
Over 1 min.
Rev.01
P age3 of 6
www. sunltech.com
SCW2012F Series
5. PACKAGING(unit: mm)
Rev.01
P ag4 of 6
www. sunltech.com
SCW2012F Series
6. 1 RELIABILITY TEST
TEST ITEM
SPECIFICATION
0402UC、0603UC、
0805UC、1008UC、
1210UC
0402IF、0805IF
、1210IF、
1812IF
Operating Tempetature
Range
﹣40 ~ +125℃
﹣40 ~ +85℃
Storage Tempetature Range
﹣40 ~ +125℃
﹣40 ~ +85℃
Rating current
150~1360mA(max)
40~1000mA
(max)
Current sources:33010D
1.0~8600uH
Test Frequency:0.252~250MHz Test
1.0~1000uH Equpment:HP4291A、HP4286A、HP4287A、
HP4284A Test Fixture:16193Aor16334A
Q
16~65(min)
Test Frequency:0.252~1500MHz Test
10~35(min) Equpment:HP4291A、HP4286A、HP4287A、
RDC
0.030~9.00Ω(max)
0.20~21.00Ω
(max)
Test Equpment:HP4263B
SRF
55~12500MHz(min)
1.6~350MHz
(min)
Test Equpment:HP4291A
Test Fixture:16193A
Solderability
The metalized area must have
more then 90%of solder coverage
Soldering Temp:230±5℃
Dippng time:5±1S
Resistance to soldering
heat
No eviden ce of mechanical
damage The mealized arer must
have more then 75%of solder
coverage Inductance change,less
than±5% Q chanqe less than±10%
Soldering Temp:260±5℃
Dippng time:10±1S
Tehermal Shock
damage Inductance change,less
A cycle contain:Step1:-40℃,30Min
Step2:-85℃,30Min
Cycle Times:10
Inductance
Rev.01
TEST CONDITION
P ag 5 of 6
www. sunltech.com
SCW2012F Series
6.2 RELIABILITY TEST
Test Temperature:125±2℃(Ceramic core)85±2
damage
High Temperature Storage
℃(Ferrite core)
Inductance change,less than±5%
Test Time:96±2Hours
damage
Test Temperature:-40±2℃
Low Temperature Storage
Test Time:96±2Hours
Test Temperature:50±2℃
damage
Moisture Resistance
Test Time:100Hours
相对湿度90~95%
Amplitude:1.5mm X、Y、Z方向各
1Hours45min
damage
Vibration
Frequency range:10~55~10Hz(min)
Force:2Kgf
damage
Component Adhesion
No evidence of peel off or broken
Test Time:5±1秒
Keep coutinuity of Winding
Camber:20mm
Test Board:Glass-Epoxy board
Thickness:8mm
Rev.01
Resistance to bend
No evidence of mechanical
damage
Life
damage
P ag 6 of 6
Test Temperature:85±2℃
Test Time:1000Hours with rating current
Test Time:96±2Hours
www. sunltech.com
很抱歉,暂时无法提供与“SCW2012F100KST”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.36620
- 100+0.30601
- 400+0.30295
- 800+0.29689
- 2000+0.28798
- 国内价格
- 10+0.39950
- 100+0.33383
- 300+0.30100
