ET215N12-Z
ET215N12-Z
    NIDEC(尼得科)
    插件
    钮子开关 双刀双掷 3万次 面板安装 15A 125V -40℃~+85℃
ET215N12-Z 数据手册
ET Standard Size Toggle Switch ET RoHS RoHS Compliant ■ Introduction The ET series is Copal’s standard size high capacity toggle switch. The ET series are available in various current rating, switching functions, and terminals. The housing is made of self-extinguishing phenol resin which has excellent heat resistance, arc resistance, and tracking resistance. The contacts are designed to eliminate chattering and bouncing to prevent insulation deterioration. ■ Part Numbering E T Series code Fig. 1 2 3 4 6 2 Actuator shape No. of poles Current Swiching function Terminal styles AC125V AC250V - 15 15A 10A 3A 20 20A 12A 6A (2A) 25 25A 15A 10A (7A) 30 30A (25A) Fig. 1pole 03 3A 05 5A 06 10 Fig. K Fig. No. of poles 2poles 3poles 4poles 6poles 12 - Z 25 AC125V AC250V Terminal style None TAB#250 10 Screw Terminal 12 Solder Terminal 13 Plate Connect SolderTerminal 1pole 3pole 2pole 4pole 6pole A C D・V E F G H - K M N P R S - PA Key way ON OFF ON ON ON (ON) ON ON ■Terminal Style and Dimentions TAB#250 (Style:-) Solder Terminal Screw Terminal (Style:10) M3.5×0.6 M4×0.7 M4.5×0.75 ET115・215Type ET120・220Type ET125・225・230Type and (ON) (OFF) :Momentary. Please refer to P.564 for Common Specifications Solder Terminal (Style:12・13) Style:12 ET103□12 Type ET206 □12 Key way - - - OFF - OFF OFF ON Key way OFF (ON) ON ON (ON) (ON) (ON) OFF ET Series Selection Table Part No. Appearance No. of poles Rating Switching function Terminal style Page Solder Terminal ET103 1 AC125V 3A ON ON − − OFF ON 416 Solder Terminal ET105 416 1 AC125V AC250V ET205 5A 3A ON ON ON − − − OFF − OFF ON ON 418 2 TAB # 250 ET110 1 ET210 2 AC125V 10A AC250V 7A AC125V 10A ET115 ON ON ON ON ON ON − OFF − ON − OFF − ON − (ON) − OFF − (ON) − ON − 417 Screw Terminal(M3.5×0.6) 419 OFF 417 1 Solder Terminal ET215 2 ET315 3 OFF ON − OFF − (ON) ON − ON AC125V 15A ON − OFF − ON AC250V 10A ON − (ON) Solder Terminal (ON) − OFF − (ON) − OFF − (ON) ON 419 421 ET415 4 TAB # 250 ET120 1 AC125V 20A AC250V 12A ON ON − − OFF ON 417 Screw Terminal(M4.5×0.6) ET125 418 1 AC125V 25A AC250V 15A ET225 2 ON ON ON − − − OFF − OFF ON ON Solder Terminal 420 Part No. Appearance No. of poles Rating Switching function Terminal style Page Solder Terminal ET425 4 ET206 2 ET220 2 AC125V 25A AC250V 15A ON ON − − OFF ON AC125V 6A ON − OFF AC125V AC250V 6A 2A AC125V 20A AC250V 12A ON − 424 Solder Terminal 418 ON ON − OFF ON − ON (ON) − OFF − (ON) Solder Terminal 420 Screw Terminal(M4.5×0.75) ET230 420 2 AC125V 30A AC250V 25A ET330 3 ET310 3 − − − OFF − OFF ON ON Solder Terminal 422 Solder Terminal AC125V 10A AC250V 7A ET410 ON ON ON ON ON ON − − − OFF − OFF ON ON 422 4 ET420 Solder Terminal 4 421 AC125V 20A AC250V 12A ON − 423 ON ET420 Plate type 424 ET610N Plate type 6 AC125V 10A AC250V 7A ON − ON 424 ET620N Plate type 6 AC125V 20A AC250V 12A ON − ON 425 ● Ratings are based on resistance load. ● Refer to P.425 for UL-recognized and CSA, PSE-certified products. and (ON) (OFF) :Momentary. ET ■Panel Cut-Out Dimensions ●Refer to P.426 for a list of accessories. Panel thickness : 5.5mm max. With Locking Ring Note : Panel thickness should be 5.5 mm max. unless otherwise specified. Without Locking Ring ET103□12(1 pole) Switching function Key way Key way Key way M12×1 Part No. (1)(4) ET103A12−Z ON − OFF (3)(6) Connecting terminals 1−4 − − ON − ON 1−4 − 3−6 ★ ET103V12−Z Connecting terminals Terminal numbers are shown on the bottom of the switch. ■Specifications Rating Initial contact resistance Dielectric strength ET103A12 30mΩ Max. AC1500V AC125V 3A (DC2V 100mA) 1minute ET103V12 ET105□12(1 pole) Insulation resistance Electrical life 100MΩ Min. (DC500V) 10,000回 cycles Terminal pins No.3 and No.6 are not available in switches with Switching Function “A”. L dimensions Terminal pin No.2 is not available in switches with Switching Function “A”. (1) M12×1 Part No. ET105A12−Z ET105D12−Z ET105E12−Z (2) (3) Switching function Terminal numbers are shown on the bottom of the switch. ■Specifications Rating Terminal style Solder Terminal 24.6±1 24.6±1 24.6±1 Key way Key way ON − 1−3 − − ON ON − OFF ON ON 2−3 − 2−1 Key way Part No. ☆ ET105A12−Z Initial contact resistance Dielectric strength ET105A12 AC125V 5A 20mΩ Max. AC1500V ET105D12 AC250V 3A (DC2V 100mA) 1minute ET105E12 Insulation resistance 100MΩ Min. (DC500V) Electrical life 20,000回 cycles Connecting terminals ☆ ET105D12−Z ☆ ET105E12−Z Connecting terminals ☆:Semi-standard products. OFF ★:Made to order products. ET ET110(1 pole) Terminal pin No.2 is not available in switches with Switching Function “A”. L dimensions Part No. M12×1 ET110A■・D■−Z ET110E■−Z ET110F■−Z ET110H■−Z 0.5 1 2 29 Terminal style TAB#250 − − 27.6±1 27.6±1 ScrewTerminal Solder Terminal − − − 25.4±1 24.6±1 24.6±1 24.6±1 24.6±1 3 Switching function 0.5 ■Specifications ET110A■ ET110D■ ET110E■ ET110F ■ ET110H■ Initial contact resistance Dielectric strength AC125V 10A AC250V 7A 20mΩ Max. AC1500V AC125V 10A(DC2V 100mA) 1minute Insulation resistance Electrical life 30,000 cycles 100MΩ Min. (DC500V) 20,000 cycles AC250V 7A ET115(1 pole) Terminal pin No.2 is not available in switches with Switching Function “A”, “B”, or “ ”. ET110A■−Z ON − OFF 1−3 − − ET110D■−Z ET110E■−Z ET110F■−Z ET110H■−Z ON ON ON ON − OFF − OFF ON ON (ON) (ON) Connecting terminals 2−3 − 2−1 ■:Refer to “Table of Part Numbers” on P.425 for a full list of part numbers. L dimensions Terminal style 29 0.5 ET115A■・D■−Z ET115E■−Z ET115C■・F∼H■−Z Switching function 0.5 Terminal numbers are shown on the bottom of the switch. ■Specifications ET115A■ ET115D■ ET115E■ ET115C■ ET115G■ ET115H■ Initial contact resistance Dielectric strength AC125V 15A AC250V 10A 20mΩ Max. AC1500V AC125V 15A(DC2V 100mA) 1minute Insulation resistance Electrical life 30,000 cycles 100MΩ Min. (DC500V) 20,000 cycles AC250V 10A ET120( pole) Key way Connecting terminals Part No. Rating Key way Part No. Terminal numbers are shown on the bottom of the switch. Rating Key way Terminal pin No.2 is not available in switches with Switching Function “A”. TAB#250 ±1 27.6 27.6±1 − ScrewTerminal Solder Terminal 25.4±1 25.4±1 25.4±1 Key way Key way 24.6±1 24.6±1 24.6±1 Key way Part No. ET115A■−Z ON − OFF Connecting terminals 1−3 − − ET115C■−Z OFF − (ON) Connecting terminals − − 1−3 ET115D■−Z ET115E■−Z ET115G■−Z ET115H■−Z ON ON (ON) ON − OFF OFF OFF ON ON (ON) (ON) Connecting terminals 2−3 − 2−1 ■:Refer to “Table of Part Numbers” on P.425 for a full list of part numbers. L dimensions Part No. Terminal style ET120A■・D■−Z TAB#250 ScrewTerminal Solder Terminal 24.6±1 − Key way Key way ET120A■−Z ON − OFF Connecting terminals 1−3 − − ET120D■−Z ON − ON Connecting terminals 2−3 − 2−1 0.5 − Key way 29 Switching function Part No. 0.5 Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ET120A■ ET120D■ Initial contact resistance Dielectric strength AC125V 20A 20mΩ Max. AC1500V AC250V 12A (DC2V 100mA) 1minute (ON) :Momentary. Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles ■ shows the terminal style “(blank)”, “10”, or “12”. ■:Refer to “Table of Part Numbers” on P.425 for a full list of part numbers. ET ET125(1 pole) Terminal pin No.2 is not available in switches with Switching Function “A”. L dimensions Part No. Terminal style ET125A■−Z ET125D■−Z 27.6±1 ScrewTerminal Solder Terminal 28.8±1 24.6±1 0.5 M12×1 TAB#250 Key way ET125A■−Z ON − Connecting terminals 1−3 − − ET125D■−Z ON − ON Connecting terminals 2−3 − 2−1 29 Key way Switching function Key way Part No. 0.5 Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ET125A■ ET125D■ OFF ■:Refer to “Table of Part Numbers” on P.425 for a full list of part numbers. Initial contact resistance Dielectric strength AC125V 25A 20mΩ Max. AC1500V AC250V 15A (DC2V 100mA) 1minute ET205(2 poles) Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles Terminal pins No.2 and No.5 are not available in switches with Switching Function “K”. Key way Key way ON − 1−3 4−6 − − ON ON − OFF ON ON 2−3 5−6 − 2−1 5−4 Switching function Key way Part No. ★ ET205K12−Z 24 0.5 Connecting terminals ★ ET205N12−Z ★ ET205P12−Z 0.5 Connecting terminals OFF Terminal numbers are shown on the bottom of the switch. ■Specifications Rating Initial contact resistance Dielectric strength ET205K12 AC125V 5A 20mΩ Max. AC1500V ET205N12 AC250V 3A (DC2V 100mA) 1minute ET205P12 ET206□12(2 poles) Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles Terminal pins No.3 and No.6 are not available in switches with Switching Function “K”. Switching function Key way Key way Key way Part No. M12×1 ★ ET206K12−Z Connecting terminals ON − OFF 2−1 5−4 − − ON − ON 2−1 5−4 − 2−3 5−6 ★ ET206N12−Z Connecting terminals Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ET206K12 AC125V 6A Initial contact resistance Dielectric strength AC1500V 20mΩ Max. 100mA) 1minute (DC2V AC125V 6A ET206N12 AC250V 2A Insulation resistance Electrical life 100MΩ Min. (DC500V) 10,000 cycles ■ shows the terminal style “(blank)”, “10”, or “12”. ☆:Semi-standard products. ★:Made to order products. ET ET210(2 poles) Terminal pins No.2 and No.5 are not available in switches with Switching Function “K”. L dimensions Part No. Terminal style ET210K■・N■−Z ET210P■−Z ET210PA −Z 30.6±1 30.6±1 − ScrewTerminal Solder Terminal 28.4±1 28.4±1 − 27.6±1 27.6±1 27.6±1 24 0.5 M12×1 TAB#250 Switching function Key way Key way Key way Part No. 0.5 Terminal numbers are shown on the bottom of the switch. ■Specifications Rating Initial contact resistance Dielectric strength ET210K■ ET210N■ ET210P■ AC125V 10A AC250V 7A 20mΩ Max. AC1500V (DC2V 100mA) 1minute ET210PA12 AC125V 10A ET215(2 poles) Insulation resistance ON − OFF 1−3 4−6 − − ET210N■−Z ET210P■−Z ON ON − OFF ON ON Connecting terminals 2−3 5−6 − 2−1 5−4 ON ON OFF 2−3 5−6 5−6 − ★ ET210PA12−Z Electrical life Connecting terminals ■:Refer to “Table of Part Numbers” on P.425 for a full list of part numbers.of part numbers. 30,000 cycles 100MΩ Min. (DC500V) ET210K■−Z Connecting terminals 20,000 cycles Terminal pins No.2 and No.5 are not available in switches with Switching Function “K”, “L”, or “M”. L dimensions Part No. Terminal style 24 0.5 ET215K■・N■−Z ET215P■−Z ET215M·R·S ■−Z Switching function TAB#250 30.6±1 30.6±1 − ScrewTerminal Solder Terminal 28.4±1 28.4±1 28.4±1 Key way Key way 27.6±1 27.6±1 27.6±1 Key way Part No. 0.5 Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ET215K■ ET215N■ ET215P ■ ET215M■ ET215R■ ET215S■ AC125V 15A AC250V 10A Initial contact resistance Dielectric strength 20mΩ Max. AC1500V 100mA) 1minute (DC2V AC125V 15A AC250V 10A and (ON) (OFF) :Momentary. Insulation resistance 100MΩ Min. (DC500V) Electrical life 30,000 cycles 20,000 cycles ■ shows the terminal style “(blank)”, “10”, or “12”. ET215K■−Z ON − OFF Connecting terminals 1−3 4−6 − − ET215M■−Z OFF − (ON) Connecting terminals − − 1−3 4−6 ET215N■−Z ET215P■−Z ET215R■−Z ET215S■−Z ON ON ON (ON) − OFF − OFF ON ON (ON) (ON) Connecting terminals 2−3 5−6 − 2−1 5−4 ■:Refer to “Table of Part Numbers” on P.425 for a full list of part numbers.of part numbers. ET ET220(2 poles) Terminal pins No.2 and No.5 are not available in switches with Switching Function “K”, “L”, or “M”. L dimensions Part No. Terminal style ET220K■・N■−Z ET220S−Z M12×1 TAB#250 − 30.6±1 ScrewTerminal Solder Terminal − 31.8±1 27.6±1 27.6±1 Key way Key way ET220K■−Z ON − Connecting terminals 1−3 4−6 − − ET220N■−Z ET220S■−Z ON (ON) − OFF ON (ON) Connecting terminals 2−3 5−6 − 2−1 5−4 Switching function Key way Part No. L Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ET220K■ ET220N■ ET220S■ Initial contact resistance Dielectric strength AC125V 20A AC250V 12A AC1500V 20mΩMax. 100mA) 1minute (DC2V AC125V 20A AC250V 12A ET225(2 poles) Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles Terminal pins No.2 and No.5 are not available in switches with Switching Function “K”. OFF ■:Refer to “Table of Part Numbers” on P.425 for a full list of part numbers. L dimensions Part No. Terminal style ET225K■・N■−Z ET225P■−Z TAB#250 30.6±1 ScrewTerminal Solder Terminal 31.8±1 27.6±1 Key way Key way ET225K■−Z ON − OFF Connecting terminals 1−3 4−6 − − ET225N■−Z ET225P■−Z ON ON − OFF ON ON Connecting terminals 2−3 5−6 − 2−1 5−4 Switching function Key way Part No. Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ET225K■ ET225N■ ET225P■ Initial contact resistance Dielectric strength AC125V 25A 20mΩ Max. AC1500V AC250V 15A (DC2V 100mA) 1minute ET230(2 poles) Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles ■:Refer to “Table of Part Numbers” on P.425 for a full list of part numbers. Terminal pins No.2 and No.5 are not available in switches with Switching Function “K”. Switching function Key way Key way Key way Part No. ★ ET230N■−Z ★ ET230P■−Z M12×1 Connecting terminals ON ON − OFF ON ON 2−3 5−6 − 2−1 5−4 Terminal numbers are shown on the bottom of the switch. ■Specifications Rating Initial contact resistance Dielectric strength AC1500V ET230N10 AC250V 25A 20mΩMax. ET230P10 AC125V 30A (DC2V 100mA) 1minute (ON) :Momentary. Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles ■ shows the terminal style “(blank)”, “10”, or “12”. ★:Made to order products. ET ET310(3 poles) Terminal pins No.2, No.5, and No.8 are not available in switches with Switching Function “A”. L寸法/L dimensions Part No. ET310A■−Z ET310D■−Z ET310E■−Z M12×1 Part No. ■Specifications ET310A■ ET310D■ ET310E■ Initial contact resistance Dielectric strength AC125V 10A 20mΩ Max. AC1500V AC250V 7A (DC2V 100mA) 1minute ET315□12(3 poles) Switching function Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles Switching function ★ET315D12−Z ★ET315E12−Z ■Specifications Dielectric strength AC1500V ET315D12 AC125V 15A 20mΩ Max. ET315E12 AC250V 10A (DC2V 100mA) 1minute ★:Made to order products. (ON) :Momentary. Key way Key way ON ON 2−3 5−6 Connecting terminals 8−9 Terminal numbers are shown on the bottom of the switch. Initial contact resistance 36.4±1 Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles − Key way 29.1±1 Key way − OFF − − − OFF − ON ON 2−1 5−4 8−7 ■:Refer to “Table of Part Numbers” on P.425 for a full list of part numbers. Terminal pins No.2, No.5, and No.8 are not available in switches with Switching Function “A”. M12×1 ScrewTerminal Solder Terminal 34±2 ON 1−3 4−6 Connecting terminals 7−9 ET310D■−Z ON ET310E■−Z ON 2−3 5−6 Connecting terminals 8−9 Part No. Rating TAB#250 ET310A■−Z Terminal numbers are shown on the bottom of the switch. Rating Terminal style ■ shows the terminal style “(blank)” or “12”. Key way − OFF − Key way ON ON 2−1 5−4 8−7 ET ET330□12(3 poles) Terminal pins No.2, No.5, and No.8 are not available in switches with Switching Function “A”. L dimensions Part No. Terminal style TAB#250 33.9±2 ET330A■−Z ET330D12−Z ET330E12−Z M12×1 ScrewTerminal Solder Terminal − − Key way Switching function Key way 29.1±1 Key way Part No. ET330A■−Z Terminal numbers are shown on the bottom of the switch. ■Specifications Rating Initial contact resistance Dielectric strength ET330A■ AC125V 30A 20mΩMax. AC1500V ET330D12 AC250V 25A (DC2V 100mA) 1minute ET330E12 Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles ON 1−3 4−6 Connecting terminals 7−9 ON ☆ET330D12−Z ON ★ET330E12−Z 2−3 5−6 Connecting terminals 8−9 − OFF − − − OFF − ON ON 2−1 5−4 8−7 ■:Refer to “Table of Part Numbers” on P.425 for a full list of part numbers. ET410□12(4 poles) Key way Key way Key way Switching function Part No. 33.5 ★ET410N12−Z Connecting terminals ON 2−3 5−6 8−9 11−12 − − ON 2−1 5−4 8−7 11−10 Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ET410N12 Initial contact resistance Dielectric strength AC125V 10A 20mΩ Max. AC1500V AC250V 7A (DC2V 100mA) 1minute ■ shows the terminal style “(blank)”, “10”, or “12”. Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles (ON) :Momentary. ☆:Semi-standard products. ★:Made to order products. ET ET415□12(4 poles) Terminal pins No.2, No.5, No.8, and No.11 are not available in switches with Switching Function “K”. Switching function Key way Key way Key way Part No. ★ET415P12−Z Connecting terminals ON 2−3 5−6 8−9 11−12 OFF − ON −1 5−4 8−7 11−10 Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ET415P12 Initial contact resistance Dielectric strength AC125V 15A 20mΩ Max. AC1500V AC250V 10A (DC2V 100mA) 1minute ET420□12(4 poles) Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles Terminal pins No.2, No.5, No.8, and No.11 are not available in switches with Switching Function “K”. Part No. Switching function ★ET420N12−Z Connecting terminals Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ET420N12 Initial contact resistance Dielectric strength AC125V 20A 20mΩ Max. AC1500V AC250V 12A (DC2V 100mA) 1minute ★:Made to order products. Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles Key way ON 2−3 5−6 8−9 11−12 Key way − − Key way ON 2−1 5−4 8−7 11−10 ET ET420□13(4 poles) Terminal pins No.2, No.5, No.8, and No.11 are not available in switches with Switching Function “K”. Part No. Switching function ★ET420N13−Z 2-M3×0.5 Connecting terminals Viewed from part No. and rating marking side ON 2−3 5−6 8−9 11−12 − − ON 2−1 5−4 8−7 11−10 ■Panel Cut-Out Dimensions Terminal numbers are shown on the bottom of the switch. Plate mounting type ■Specifications Initial contact resistance Rating ET420N13 Dielectric strength AC125V 20A 20mΩ Max. AC1500V AC250V 12A (DC2V 100mA) 1minute ET425□12(4 poles) Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles Terminal pins No.2, No.5, No.8, and No.11 are not available in switches with Switching Function “K”. Switching function Key way Key way Key way Part No. ★ET425K12−Z ON 1−3 4−6 Connecting terminals 7−9 10−12 ON ★ET425N12−Z 2−3 5−6 Connecting terminals 8−9 11−12 12M×1 − OFF − − − − ON 2−1 5−4 8−7 11−10 Terminal numbers are shown on the bottom of the switch. ■Specifications Initial contact resistance Rating Dielectric strength AC1500V ET425K12 AC125V 25A 20mΩ Max. ET425N12 AC250V 15A (DC2V 100mA) 1minute Insulation resistance Electrical life 100MΩ Min. (DC500V) 20,000 cycles ET610N13(6 poles) Switching Viewed from part No. and rating marking side function Part No. ☆ET610N13−Z 4-M3×0.5 ON − 2−3 5−6 Connecting terminals 8−9 11−12 34.5 14−15 17−18 − ON 2−1 5−4 8−7 11−10 14−13 17−16 ■Panel Cut-Out Dimensions Terminal numbers are shown on the bottom of the switch. Plate mounting type ■Specifications Rating ET610N13 Initial contact resistance Dielectric strength AC125V 10A 20mΩ Max. AC1500V AC250V 7A (DC2V 100mA) 1minute Insulation resistance Electrical life 100MΩ Min. (DC500V) 5,000 cycles ☆:Semi-standard products. ★:Made to order products. ET ET620N13(6 poles) Switching Viewed from part No. and rating marking side function Part No. ★ET620N13−Z 4-M3×0.5 ON − 2−3 5−6 34.5 Connecting terminals 8−9 11−12 14−15 17−18 − ON 2−1 5−4 8−7 11−10 14−13 17−16 ■Panel Cut-Out Dimensions Terminal numbers are shown on the bottom of the switch. ■Specifications Rating ET620N13 Plate mounting type Initial contact resistance Dielectric strength AC125V 20A 20mΩ Max. AC1500V AC250V 12A (DC2V 100mA) 1minute Insulation resistance Electrical life 100MΩ Min. (DC500V) 5,000 cycles ■Table of Part Numbers Part No. TAB terminals Screw terminals Solder terminals ★  ET110F−Z ★ ET110H−Z    ET115A−Z ☆ ET115A10−Z ※1. Part No. ※1. Part No. ※1. Part No. ★  ET115D−Z ★  ET215N−Z 40.0 ET225P−Z ★ ET125A−Z 26.6 ☆  ET215P−Z 39.7 ★ ET330A−Z ET215K−Z 39.3 ☆ ET225K−Z 39.4 29.4 ★  ★ ET125A10−Z ☆  ET215N10−Z ★ ET230N10−Z ★ ★ ET115D10−Z ET215K10−Z ★  ET215P10−Z ★ ET230P10−Z    ET103A12−Z 21.0 ☆  ET120A12−Z ★ ET215M12−Z ★  ET315D12−Z ★ ET103V12−Z 21.0 ★  ET120D12−Z ☆  ET215N12−Z 38.1 ★  ET315E12−Z ☆ ET105A12−Z ☆ ET125A12−Z 25.9 ★  ET215P12−Z 37.8 ★ ET330A12−Z 26.0 ★ ☆ ET105D12−Z 25.8 ★ ET125D12−Z ☆ ET105E12−Z ★ ET205K12−Z ET215R12−Z ☆ ET330D12−Z ET215S12−Z 38.4 ★ ET330E12−Z ☆ ET110A12−Z 25.8 ★ ET205N12−Z ★  ET220K12−Z ★ ET410N12−Z ☆ ET110D12−Z ★ ET205P12−Z ★  ET220N12−Z ★  ET415P12−Z ★ ET110E12−Z    ET206K12−Z 26.1 ★ ET220S12−Z ★ ET420N12−Z    ET115A12−Z 25.9 ☆  ET206N12−Z 26.3 ☆ ET225K12−Z 38.1 ★ ET420N13−Z ★ ET115C12−Z ☆ ET210K12−Z ET225N12−Z 38.6 ★ ET425K12−Z    ET115D12−Z 25.9 ☆ ET210N12−Z 38.0 ET225P12−Z ★ ET425N12−Z ★  ET115E12−Z 25.9 ☆ ET210P12−Z 37.9 ★ ET310A12−Z 54.0 ☆ ET610N13−Z ★ ET115G12−Z ★ ET210PA12−Z ☆ ET310D12−Z 54.6 ★ ★ ET115H12−Z ET215K12−Z 37.9 ☆ ET310E12−Z 25.0 ☆  ※1. 54.4 54.7 54.2 57.4 105.0 ET620N13−Z − − As shown in the above table, not all products are UL-recognized or CSA-certified.Please check with your local sales representative if you have any questions. Note: For overseas standards, see P.627. ※1 : Switch mass (g) : includes accessories = hex nut, locking ring, lock washer and terminal screw ★:Made to order products. ☆:Semi-standard products. ET ■ Standard Accessories 《Supplied with switch》 Part Name Hex Nut Hex Nut Lockwasher Locking Ring Part No. 140008010235 140008010221 140008030055 140008020065 Nickel plated Zinc plated Zinc plated Zinc plated Dimensions Finish ■Optional Accessories ET·8B Type Part Name Part No. 《Supplied separately》 Plate 140008040021 ET Plate 140008040025 ET Waterproof boot Red 140000610335 Gray 140000610334 Black 140000610333 Boot Bushing 140000610080 140008010244 Dimensions ■Handling Precautions 1. Soldering Specifications ⑴Manual Soldering Device:Soldering iron 420℃, Max.; 3 seconds, Max. ⑵ Waterproof boot ①The boot is fixed to the switch with the built-in screw. ②The boot cannot be used for plate-mounting switches. ■Packaging Specification ビニール袋 Plastic bag 付属部品 Accessories 2. Flux Cleaning ⑴ Solvent : Fluorine or Alcohol type. ⑵ The ET series are not washable. To wash the PC board, clean the soldering surface of the PC board with a brush so that the switch is not exposed to the cleaning solution. :Optional Accessories.
ET215N12-Z 价格&库存
很抱歉,暂时无法提供与“ET215N12-Z”相匹配的价格&库存,您可以联系我们找货
ET215N12-Z
  • 1+59.55674
  • 2+57.22404
  • 5+55.37038
库存:7
ET215N12-Z
    • 1+48.373751+6.24834
    库存:8
