ESD5451NL
ESD5451NL
1-Line, Bi-directional, Transient Voltage Suppressors
http//:www.sh-willsemi.com
Descriptions
The ESD5451NL is a bi-directional TVS (Transient Voltage
Suppressor). It is specifically designed to protect sensitive
electronic components which are connected to low speed
data lines and control lines from over-stress caused by ESD
(Electrostatic Discharge), EFT (Electrical Fast Transients)
and Lightning.
DFN1006-2L (Bottom View)
The ESD5451NL may be used to provide ESD protection up
to
±15kV
(contact
and
air
discharge)
according
to
IEC61000-4-2, and withstand peak pulse current up to 4.0A
(8/20μs) according to IEC61000-4-5.
Pin1
Pin2
The ESD5451NL is available in DFN1006-2L package.
Standard products are Pb-free and Halogen-free.
Circuit diagram
Features
Reverse stand-off voltage: ±5.0V Max.
Transient protection for each line according to
W
Pin1
IEC61000-4-2 (ESD): ±15kV (contact discharge)
IEC61000-4-4 (EFT): 40A (5/50ns)
IEC61000-4-5 (surge): 4.0A (8/20μs)
W = Device code
Capacitance: CJ = 11pF typ.
Low leakage current
Low clamping voltage: VCL = 12V typ. @ IPP = 16A (TLP)
Solid-state silicon technology
* = Month code (A~Z)
Marking (Top View)
Order information
Applications
Cellular handsets
Tablets
Laptops
Other portable devices
Network communication devices
Will Semiconductor Ltd.
Pin2
Device
Package
Shipping
ESD5451NL-2/TR DFN1006-2L 10000/Tape&Reel
1
Revision 1.0, 2018/09/17
ESD5451NL
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
44
W
Peak pulse current (tp = 8/20μs)
IPP
4
A
ESD according to IEC61000-4-2 air discharge
±20
VESD
ESD according to IEC61000-4-2 contact discharge
Junction temperature
TJ
Operating temperature
TOP
Lead temperature
TL
Storage temperature
kV
±15
TSTG
125
o
-40~85
o
260
o
-55~150
o
C
C
C
C
Electrical characteristics (TA=25 oC, unless otherwise noted)
Parameter
Symbol
Condition
VRWM
Reverse leakage current
IR
VRWM = 5V
Reverse breakdown voltage
Min.
Typ.
Unit
±5.0
V
0.5
µA
8.0
V
VBR
IBR = 1mA
Clamping voltage
1)
VCL
IPP = 16A, tp = 100ns
12
V
Clamping voltage
2)
VCL
VESD = 8kV
12
V
3)
IPP = 1A, tp = 8/20μs
7.5
9
V
Clamping voltage
VCL
IPP = 4A, tp = 8/20μs
9.5
11
V
Dynamic resistance
1)
Junction capacitance
RDYN
CJ
5.2
Max.
Ω
0.35
VR = 0V, f = 1MHz
11
15
pF
Notes:
1) TLP parameter: Z0 = 50Ω, tp = 100ns, tr = 2ns, averaging window from 60ns to 80ns. RDYN is calculated from 4A to
16A.
2)
Contact discharge mode, according to IEC61000-4-2.
3)
Non-repetitive current pulse, according to IEC61000-4-5.
2
ESD5451NL
o
Typical characteristics (TA=25 C, unless otherwise noted)
Time to half-value: T2= 20s
Current (%)
Peak pulse current (%)
100
90
Front time: T1= 1.25 T = 8s
100
90
50
T2
10
T
T1
tr = 0.7~1ns
CJ - Junction capacitance (pF)
VC - Clamping voltage (V)
Pulse waveform: tp = 8/20s
9
8
7
6
2
3
Time (ns)
Contact discharge current waveform per IEC61000-4-2
8/20μs waveform per IEC61000-4-5
10
t
60ns
30ns
Time (s)
4
f = 1MHz
VAC = 50mV
14
12
10
8
6
-5
5
-4
-3
-2
-1
2
3
4
IPP - Peak pulse current (A)
VR - Reverse voltage (V)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reverse voltage
5
1000
% of Rated power
Peak pulse power (W)
100
100
10
1
80
60
40
10
100
Pulse time (s)
1000
25
50
75
100
125
150
o
TA - Ambient temperature ( C)
Non-repetitive peak pulse power vs. Pulse time
Power derating vs. Ambient temperature
3
ESD5451NL
o
10V/div
10V/div
20ns/div
20ns/div
ESD clamping
ESD clamping
(+8kV contact discharge per IEC61000-4-2)
(-8kV contact discharge per IEC61000-4-2)
TLP current (A)
16
12
8
4
-8
Z0 = 50
-12
tr = 2ns
-16
tp = 100ns
-20
-14-12-10 -8 -6 -4 -2 0 2 4 6 8 10 12 14
TLP voltage (V)
TLP Measurement
4
ESD5451NL
Package outline dimensions
DFN1006-2L
L
E
b
e
TOP VIEW
BOTTOM VIEW
A1
A
A3
D
SIDE VIEW
Dimensions in Millimeters
Symbol
Min.
Typ.
Max.
A
0.43
0.48
0.53
A1
A3
0.13Ref
D
0.95
1.00
1.05
E
0.55
0.60
0.65
b
0.20
0.25
0.30
L
0.44
0.49
0.54
e
0.64 BSC
Recommended PCB Layout (Unit: mm)
0.55
0.60
0.30
0.85
1.40
Notes:
This recommended land pattern is for reference
purposes only. Please consult your manufacturing
group to ensure your PCB design guidelines are met.
5
ESD5451NL
TAPE AND REEL INFORMATION
RD
Reel Dimensions
W
Tape Dimensions
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
User Direction of Feed
RD
Reel Dimension
7inch
13inch
W
Overall width of the carrier tape
8mm
12mm
16mm
P1
Pitch between successive cavity centers
2mm
4mm
8mm
Pin1 Quadrant
Q1
Q2
Q3
Pin1
6
Q4
很抱歉,暂时无法提供与“ESD5451NL-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07139
- 500+0.05800
- 1500+0.05055
- 国内价格
- 1+0.23540
- 500+0.07854
- 5000+0.05236
- 10000+0.04290
- 国内价格
- 50+0.06544
- 2000+0.06479
- 4000+0.06349
- 10000+0.06159
