CL-SA-12C-02
CL-SA-12C-02
    NIDEC(尼得科)
    插件,10x2.54mm
    滑动开关 插件,10x2.54mm 单刀双掷 1万次 直插
CL-SA-12C-02 数据手册
CL-SA SLIDE SWITCHES RoHS compliant INTERNAL STRUCTURE ② ⑤ ⑥ ③ ① ④ Part name Material Flammability ① Housing Polyamido UL94V-0 ■ FEATURES ② Slider Polyamido UL94V-0 ● Correspond to rating current 500mA ● Possible to continue mounting with 2.54mm pitch ● RoHS compliant ③ Slider contact Copper alloy, Gold-plated — ④ Terminal pin Copper alloy, Gold-plated — ⑤ Click spring Stainless steel(SUS304) — ⑥ Click ball Stainless steel(SUS304) — ■ PART NUMBER DESIGNATION CL - SA - 1 2 C - 0 2 Series name Form of packaging Blank:Bulk in plastic bag No. of bits 1:1 pole Contact material 2:Gold No. of positions 2:2 positions Knob length・Color Shape of terminal C:PC terminal C4:PC terminal-R/A(Right angle) ※ Please refer to the LIST OF PART NUMBERS when placing orders. 0:Short・White 2:Short・Red CL-SA SLIDE SWITCHES ■ LIST OF PART NUMBERS No. of poles No. of contacts Contact material Knob length・ Shape of terminal Color Part number From of packaging Pieces in package Plastic bag 50pcs./pack CL-SA-12C-02 Short・White PC terminal 1 2 Short・Red CL-SA-12C-22 Short・White CL-SA-12C4-02 Gold PC terminal-R/A CL-SA-12C4-22 Short・Red ■ STANDARD SPECIFICATIONS Operating temp. range − 40 ~ 85 °C Storage temp. range Sealing Non- Washable ■ ELECTRICAL CHARACTERISTICS Contact rating Non-switching Switching Minimum      Initial contact resistance Insulation resistance ■ MECHANICAL CHARACTERISTICS 22 m Ω maximum 10,000 M Ω minimum (DC100 V) AC500 V 60 s 1.6 mm Stroke Operation force Dielectric strength DC50 V 500mA DC12 V 500mA DC20 mV 1 μ A 2.5 ± 1.5 N {0.26 ± 0.15kgf} Rated load 2,000 cycles No load 10,000 cycles Load life ■ PACKAGING SPECIFICATION Plastic bag Flow:260 °C ± 3 5 ~ 6 s 2 times max. ※Except a right angle(CL-SA-12C4-*2) Soldering heat Manual soldering: 380 ± 10 °C 3 ~ 4 s 50pcs./ pack CL-SA SLIDE SWITCHES ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● CL-SA-12C-02 ● CL-SA-12C-22 ● CL-SA-12C4-02 ● CL-SA-12C4-22 ■ SIZE OF P.C.B. PROCESSING ● CL-SA-12C-02 ● CL-SA-12C-22 ■ PACKAGING SPECIFICATIONS ● The smallest unit of bulk pack in plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. ● Boxing of bulk in a plastic bag is performed with 50 pcs. (standard 100 pcs.) per box. (Unit : mm) ● CL-SA-12C4-02 ● CL-SA-12C4-22
CL-SA-12C-02 价格&库存
很抱歉,暂时无法提供与“CL-SA-12C-02”相匹配的价格&库存,您可以联系我们找货
CL-SA-12C-02
  • 1+7.62600
  • 10+7.01100
  • 30+6.88800
CL-SA-12C-02
  • 5+12.30291
  • 25+11.54687
库存:10
