65HVD3088EIM/TR
65HVD3088EIM/TR
    HGSEMI(华冠)
    MSOP-8
    低功耗RS-485收发器,可在小型MSOP-8封装中使用
65HVD3088EIM/TR 数据手册
65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E 65HVD308xE Low-Power RS-485 Transceivers, Available in a Small MSOP-8 Package Description Features • • 1 • • • • • • The 65/75HVD308xE devices are half-duplex transceivers designed for RS-485 data bus networks. Powered by a 5-V supply, they are fully compliant with TIA/EIA-485A standard. With controlled transition times, these devices are suitable for transmitting data over long twisted-pair cables. 65HVD3082E and 75HVD3082E devices are optimized for signaling rates up to 200 kbps. The 65HVD3085E device is suitable for data transmission up to 1 Mbps, whereas the 65HVD3088E device is suitable for applications that require signaling rates up to 20 Mbps. These devices are designed to operate with very low supply current, typically 0.3 mA, exclusive of the load. When in the inactive-shutdown mode, the supply current drops to a few nanoamps, which makes these devices ideal for power-sensitive applications. Available in a Small MSOP-8 Package Meets or Exceeds the Requirements of the TIA/EIA-485A Standard Low Quiescent Power – 0.3-mA Active Mode – 1-nA Shutdown Mode 1/8 Unit Load up to 256 Nodes on a Bus Bus-Pin ESD Protection up to 15 kV Industry-Standard HG75176 Footprint Failsafe Receiver (Bus Open, Bus Shorted, Bus Idle) Glitch-Free Power-Up and Power-Down Bus Inputs and Outputs The wide common-mode range and high ESDprotection levels of these devices makes them suitable for demanding applications such as energy meter networks, electrical inverters, status and command signals across telecom racks, cabled chassis interconnects, and industrial automation networks where noise tolerance is essential. These devices match the industry-standard footprint of the HG75176 device. Power-on-reset circuits keep the outputs in a high-impedance state until the supply voltage has stabilized. A thermal-shutdown function protects the device from damage due to system fault conditions. The 75HVD3082E is characterized for operation from 0°C to 70°C and 65HVD308xE are characterized for operation from –40°C to 85°C air temperature. The D package version of the 65HVD3082E has been characterized for operation from –40°C to 105°C. Applications • • • • • • • Energy Meter Networks Motor Control Power Inverters Industrial Automation Building Automation Networks Battery-Powered Applications Telecommunications Equipment Simplified Schematic R R B DE D R A RE RT RT D A R B A R D R RE DE D http://www.hgsemi.com.cn R A RE B DE D B D D R RE DE D 1 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Pin Configuration and Functions D, P, and DGK Packages 8-Pin SOIC, VSSOP, and PDIP Top View R 1 8 VCC RE DE D 2 7 B 3 4 6 A 5 GND Pin Functions PIN NAME TYPE NO. DESCRIPTION A 6 Bus input/output Driver output or receiver input (complementary to B) B 7 Bus input/output Driver output or receiver input (complementary to A) D 4 Digital input Driver data input DE 3 Digital input Driver enable, active high GND 5 Reference potential Local device ground R 1 Digital output Receive data output RE 2 Digital input VCC 8 Supply Receiver enable, active low 4.5-V to 5.5-V supply Absolute Maximum Ratings over operating free-air temperature range unless otherwise noted (1) (2) Supply voltage, VCC MIN MAX –0.5 7 V –9 14 V Voltage at A or B UNIT Voltage at any logic pin –0.3 VCC + 0.3 V Receiver output current –24 24 mA Voltage input, transient pulse, A and B, through 100 Ω (see Figure 20) –50 50 V Junction Temperature, TJ 170 °C Storage temperature, Tstg 150 °C (1) (2) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. All voltage values, except differential I/O bus voltages, are with respect to network ground terminal. ESD Ratings VALUE V(ESD) Electrostatic discharge Human body model (HBM), per ANSI/ESDA/JEDEC JS001 (1) Bus pins and GND ±15000 All pins ±4000 Charged-device model (CDM), per JEDEC specification JESD22-C101 (2) Electrical Fast Transient/Burst, A, B, and GND (3) (1) (2) (3) ±1000 UNIT V ±4000 JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Tested in accordance with IEC 61000-4-4. http://www.hgsemi.com.cn 2 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Recommended Operating Conditions over operating free-air temperature range unless otherwise noted (1) MIN NOM MAX UNIT Supply voltage, VCC 4.5 5.5 Voltage at any bus terminal (separately or common mode) , VI –7 12 High-level input voltage (D, DE, or RE inputs), VIH 2 VCC V Low-level input voltage (D, DE, or RE inputs), VIL 0 0.8 V V Differential input voltage, VID Driver Output current, IO Receiver Differential load resistance, RL –12 12 –60 60 –8 8 54 0.2 65HVD3085E Signaling rate, 1/tUI 1 65HVD3088E Operating free-air temperature, TA Mbps 20 65HVD3082E (D package) –40 105 65HVD3082E (DGK and P packages), 65HVD3085E, 65HVD3088E –40 85 75HVD3082E Junction temperature, TJ (1) mA Ω 60 65HVD3082E, 75HVD3082E V 0 70 –40 130 °C °C The algebraic convention, in which the least positive (most negative) limit is designated as minimum is used in this data sheet. Thermal Information THERMAL METRIC (1) 65HVD3082E, 75HVD3082E, 65HVD3085E, 65HVD3088E 65HVD3082E, 65HVD3088E D (SOIC) DGK (VSSOP) P (PDIP) 8 PINS 8 PINS 8 PINS UNIT RθJA Junction-to-ambient thermal resistance 130 180 70 °C/W RθJC(top) Junction-to-case (top) thermal resistance 80 66 80 °C/W RθJB Junction-to-board thermal resistance 55 110 40 °C/W ψJT Junction-to-top characterization parameter 7.9 4.6 17.6 °C/W ψJB Junction-to-board characterization parameter 47 73.1 28.3 °C/W (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report, SPRA953. http://www.hgsemi.com.cn 3 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Electrical Characteristics: Driver over recommended operating conditions unless otherwise noted PARAMETER TEST CONDITIONS IO = 0, No Load |VOD| Differential output voltage RL = 54 Ω (see Figure 8) RL = 100 Ω Change in magnitude of differential output voltage VOC(SS) Steady-state common-mode output voltage TYP (1) 3 4.3 1.5 2.3 MAX See Figure 8 and Figure 9 UNIT V 2 VTEST = –7 V to 12 V (see Figure 9) Δ|VOD| MIN 1.5 –0.2 0 0.2 1 2.6 3 –0.1 0 0.1 See Figure 10 V V ΔVOC(SS) Change in steady-state common-mode output voltage VOC(PP) Peak-to-peak common-mode output voltage See Figure 10 IOZ High-impedance output current See receiver input currents in Electrical Characteristics: Receiver II Input current D, DE –100 100 µA IOS Short-circuit output current −7 V ≤ VO ≤ 12 V (see Figure 14) –250 250 mA TYP (1) MAX UNIT –85 –10 mV (1) 500 mV All typical values are at 25°C and with a 5-V supply. Electrical Characteristics: Receiver over recommended operating conditions unless otherwise noted PARAMETER TEST CONDITIONS VIT+ Positive-going differential input threshold voltage IO = –8 mA VIT– Negative-going differential input threshold voltage IO = 8 mA Vhys Hysteresis voltage (VIT+ – VIT–) VOH High-level output voltage VID = 200 mV, IOH = –8 mA (see Figure 15) VOL Low-level output voltage VID = –200 mV, IO = 8 mA (see Figure 15) IOZ High-impedance-state output current VO = 0 or VCC, RE = VCC II Bus input current IIH High-level input current, (RE) –200 –115 mV 30 mV 4 4.6 V 0.15 –1 0.4 V 1 μA VIH = 12 V, VCC = 5 V 0.04 0.1 VIH = 12 V, VCC = 0 V 0.06 0.125 VIH = –7 V, VCC = 5 V –0.1 –0.04 VIH = –7 V, VCC = 0 V mA –0.05 –0.03 VIH = 2 V –60 –30 μA –60 –30 μA 7 pF IIL Low-level input current, (RE) VIL = 0.8 V Cdiff Differential input capacitance VI = 0.4 sin (4E6πt) + 0.5 V, DE at 0 V (1) MIN All typical values are at 25°C and with a 5-V supply. http://www.hgsemi.com.cn 4 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Power Characteristics over operating free-air temperature range (unless otherwise noted) TYP (1) MAX UNIT Driver and receiver enabled D at VCC or open, DE at VCC, RE at 0 V, No load 425 900 µA Driver enabled, receiver disabled D at VCC or open, DE at VCC, RE at VCC, No load 330 600 µA Receiver enabled, driver disabled D at VCC or open, DE at 0 V, RE at 0 V, No load 300 600 µA Driver and receiver disabled D at VCC or open, DE at 0 V, RE at VCC 0.001 2 µA Average power dissipation Input to D is a 50% duty cycle square wave at max specified signal rate RL = 54 Ω VCC = 5.5 V, TJ = 130°C PARAMETER ICC P(AVG) (1) TEST CONDITIONS MIN ALL HVD3082E 203 ALL HVD3085E 205 ALL HVD3088E 276 mW All typical values are at 25°C and with a 5-V supply. Switching Characteristics: Driver over recommended operating conditions unless otherwise noted PARAMETER tPLH tPHL TEST CONDITIONS Propagation delay time, low-to-high-level output RL = 54 Ω, CL = 50 pF Propagation delay time, high-to-low-level output (see Figure 11) TYP MAX HVD3082E 700 1300 HVD3085E 150 500 HVD3088E 12 20 HVD3082E tr tf tsk(p) tPZH tPZL tPHZ tPLZ tPZH(SHDN) tPZL(SHDN) MIN 900 1500 HVD3085E 200 300 HVD3088E 7 15 HVD3082E 20 200 HVD3085E 5 50 HVD3088E 1.4 2 Propagation delay time, high-impedance-toRL = 110 Ω, RE at 0 V high-level output (see Figure 12 and Propagation delay time, high-impedance-to-lowFigure 13) level output HVD3082E 2500 7000 HVD3085E 1000 2500 HVD3088E 13 30 Propagation delay time, high-level-to-highimpedance output Propagation delay time, low-level-to-highimpedance output RL = 110 Ω, RE at 0 V (see Figure 12 and Figure 13) HVD3082E 80 200 HVD3085E 60 100 HVD3088E 12 30 Propagation delay time, shutdown-to-high-level output Propagation delay time, shutdown-to-low-level output HVD3082E 3500 7000 RL = 110 Ω, RE at VCC (see Figure 12) HVD3085E 2500 4500 HVD3088E 1600 2600 Differential output signal rise time Differential output signal fall time Pulse skew (|tPHL – tPLH|) http://www.hgsemi.com.cn RL = 54 Ω, CL = 50 pF (see Figure 11) RL = 54 Ω, CL = 50 pF (see Figure 11) 5 500 UNIT ns ns ns ns ns ns 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Switching Characteristics: Receiver over recommended operating conditions unless otherwise noted PARAMETER tPLH tPHL tsk(p) TEST CONDITIONS HVD3082E HVD3085E Propagation delay time, low-to-highlevel output Propagation delay time, high-to-lowlevel output MIN TYP MAX 75 200 HVD3086E CL = 15 pF (see Figure 16) HVD3082E HVD3085E 79 Output signal rise time tf Output signal fall time tPZH Output enable time to high level VID = –1.5 V to 1.5 V, CL = 15 pF (see Figure 16) HVD3082E HVD3085E 4 tPHZ Output enable time to low level Output enable time from high level CL = 15 pF, DE at 3 V (see Figure 17 and Figure 18) HVD3082E HVD3085E HVD3082E HVD3085E Output disable time from low level 3 ns 3 ns 5 50 Propagation delay time, shutdown-to-high-level output tPZL(SHDN) Propagation delay time, shutdown-to-low-level output http://www.hgsemi.com.cn CL = 15 pF, DE at 0 V, (see Figure 19) 6 ns 30 10 50 ns 30 5 50 ns 30 8 HVD3088E tPZH(SHDN) ns 1.8 HVD3088E tPLZ 30 1.5 HVD3088E HVD3082E HVD3085E ns 10 HVD3088E tPZL 200 100 HVD3088E tr ns 100 HVD3088E HVD3082E HVD3085E Pulse skew (|tPHL – tPLH|) UNIT 50 ns 30 1600 3500 ns 1700 3500 ns 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Typical Characteristics 80 10 No Load, VCC = 5 V, o TA = 25 C 50% Square Wave Input ICC - Supply Current - mA II - Input Bias Current - mA 60 40 VCC = 0 V 20 VCC = 5 V 0 -20 Driver and Receiver 1 Receiver Only -40 -60 0.1 -8 -6 -4 -2 0 2 4 6 8 10 12 1 10 Figure 2. 65HVD3082E RMS Supply Current versus Signaling Rate Figure 1. Bus Input Current versus Bus Input Voltage 100 No Load, VCC = 5 V, TA = 25oC 50% Square Wave Input ICC - Supply Current - mA ICC - Supply Current - mA 100 10 Driver and Receiver 1 Receiver Only No Load, VCC = 5 V, o TA = 25 C 50% Square Wave Input 10 Driver and Receiver 1 Receiver Only 0.1 1 10 1000 100 0.1 Signal Rate - kbps Figure 4. 65HVD3088E RMS Supply Current versus Signal Rate Figure 3. 65HVD3085E RMS Supply Current versus Signaling Rate 5 5 o 4 4.5 RL = 120W VO - Receiver Output Voltage - V TA = 25 C VCC = 5 V 4.5 VOD - Differential Output Voltage - V 100 Signal Rate - kbps VI - Bus Input Voltage - V 3.5 3 RL = 60W 2.5 2 1.5 1 0.5 4 TA = 25oC VCC = 5 V VIC = 0.75 V 3.5 3 2.5 2 1.5 1 0.5 0 0 10 20 30 40 0 -200 -180 -160 -140 -120 -100 -80 -60 -40 -20 50 0 IO - Differential Output Current - mA VID - Differential Input Voltage - V Figure 5. Driver Differential Output Voltage versus Driver Output Current Figure 6. Receiver Output Voltage versus Differential Input Voltage http://www.hgsemi.com.cn 7 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Typical Characteristics (continued) 10 Rise/Fall Time - ns 9 8 VCC = 4.5 V 7 VCC = 5 V VCC = 5.5 V 6 5 -40 -20 0 20 40 60 80 o TA - Temperature - C Figure 7. 65HVD3088E Driver Rise and Fall Time versus Temperature http://www.hgsemi.com.cn 8 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Parameter Measurement Information Test load capacitance includes probe and jig capacitance (unless otherwise specified). Signal generator characteristics: rise and fall time < 6 ns, pulse rate 100 kHz, 50% duty cycle. ZO = 50 Ω (unless otherwise specified). II A IOA 27 W VOD 0 V or 3 V B 50 pF 27 W IOB VOC Figure 8. Driver Test Circuit, VOD and VOC Without Common-Mode Loading 375 W IOA VOD 0 V or 3 V 60 W 375 W IOB VTEST = -7 V to 12 V VTEST Figure 9. Driver Test Circuit, VOD With Common-Mode Loading 27 W A Signal Generator 50 W B 27 W 50 pF VA -3.25 V VB -1.75 V VOC VOC(PP) DVOC(SS) VOC Figure 10. Driver VOC Test Circuit and Waveforms 3V 1.5 V Input 1.5 V 0V RL = 50 W Signal Generator VOD tPLH tPHL CL = 50 pF 50 W 0V Output tr 90% 10% tf VOD(H) VOD(L) Figure 11. Driver Switching Test Circuit and Waveforms http://www.hgsemi.com.cn 9 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Parameter Measurement Information (continued) A S1 D 0 V or 3 V 3 V if Testing A Output 0 V if Testing B Output 3V 0V 0.5 V tPZH RL = 110 W CL = 50 pF 1.5 V 1.5 V DE DE Signal Generator Output B VOH 2.5 V Output 50 W VOff0 tPHZ Figure 12. Driver Enable and Disable Test Circuit and Waveforms, High Output 5V A D 0 V or 3 V 0 V if Testing A Output 3 V if Testing B Output RL = 110 W S1 3V Output B DE 0V tPZL CL = 50 pF DE 1.5 V 1.5 V tPLZ 5V Output Signal Generator 2.5 V VOL 50 W 0.5 V Figure 13. Driver Enable and Disable Test Circuit and Waveforms, Low Output IOS IO VID VO VO Voltage Source Figure 14. Driver Short-Circuit Signal Generator Figure 15. Receiver Switching Test Circuit and Waveforms 50 W Input B VID 1.5 V A B Signal Generator 50 W R CL = 15 pF IO 50% Input A VO 0V tPHL tPLH VOH 90% Output 10% tr tf VOL Figure 16. Receiver Switching Test Circuit and Waveforms http://www.hgsemi.com.cn 10 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Parameter Measurement Information (continued) VCC D DE V CC A 54 W B 1 kW R 3V RE 1.5 V 0V 0V RE Signal Generator CL = 15 pF tPHZ tPZH 50 W 1.5 V R VOH VOH -0.5 V GND Figure 17. Receiver Enable and Disable Test Circuit and Waveforms, Data Output High 0V D DE V CC A 54 W B R RE 5V 1.5 V 0V CL = 15 pF RE Signal Generator 3V 1 kW tPZL 50 W tPLZ VCC R 1.5 V VOH +0.5 V VOL Figure 18. Receiver Enable and Disable Test Circuit and Waveforms, Data Output Low VCC A 1.5 V or -1.5 V R B RE Signal Generator Switch Down for V(A) = 1.5 V Switch Up for V(A) = -1.5 V 3V RE 1 kW 1.5 V CL = 15 pF 0V tPZH(SHDN) tPZL(SHDN) 50 W 5V VOH R 1.5 V 0V VOL Figure 19. Receiver Enable From Shutdown Test Circuit and Waveforms http://www.hgsemi.com.cn 11 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Parameter Measurement Information (continued) VTEST 100 W 0V Pulse Generator, 15 ms Duration, 1% Duty Cycle 15 ms -VTEST 15 ms Figure 20. Test Circuit and Waveforms, Transient Overvoltage Test DE Input D and RE Input VCC Input VCC 50 kW 500 W Input 9V 500 W 50 kW 9V A Input B Input VCC VCC 36 kW 16 V 36 kW 16 V 180 kW 180 kW Input Input 16 V 36 kW 16 V 36 kW A and B Output R Output VCC VCC 16 V 5W Output 16 V Output 9V Figure 21. Equivalent Input and Output Schematic Diagrams http://www.hgsemi.com.cn 12 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Overview The 65/75HVD308xE family of half-duplex RS-485 transceivers is suitable for data transmission at rates up to 200 kbps (for 65HVD3082E and 75HVD3082E), 1 Mbps (for 65HVD3085E), or 20 Mbps (for 65HVD3088E) over controlled-impedance transmission media (such as twisted-pair cabling). Up to 256 units of 65/75HVD308xE may share a common RS-485 bus due to the family’s low bus input currents. The devices also feature a high degree of ESD protection and typical standby current consumption of 1 nA. Functional Block Diagram VCC R RE A DE B D GND Feature Description The 65/75HVD308xE provides internal biasing of the receiver input thresholds for open-circuit, bus-idle, or shortcircuit failsafe conditions. It features a typical hysteresis of 30 mV in order to improve noise immunity. Internal ESD protection circuits protect the transceiver bus terminals against ±15-kV Human Body Model (HBM) electrostatic discharges. The devices protect themselves against damage due to overtemperature conditions through use a of a thermal shutdown feature. Thermal shutdown is entered at 165°C (nominal) and causes the device to enter a low-power state with high-impedance outputs. Device Functional Modes When the driver enable pin, DE, is logic high, the differential outputs A and B follow the logic states at data input D. A logic high at D causes A to turn high and B to turn low. In this case the differential output voltage defined as VOD = VA – VB is positive. When D is low, the output states reverse, B turns high, A becomes low, and VOD is negative. When DE is low, both outputs turn high-impedance. In this condition the logic state at D is irrelevant. The DE pin has an internal pull-down resistor to ground, thus when left open the driver is disabled (high-impedance) by default. The D pin has an internal pull-up resistor to VCC, thus, when left open while the driver is enabled, output A turns high and B turns low. Table 1. Driver Function Table INPUT (1) ENABLE (1) OUTPUTS (1) FUNCTION D DE A B H H H L Actively drive bus High L H L H Actively drive bus Low X L Z Z Driver disabled X OPEN Z Z Driver disabled by default OPEN H H L Actively drive bus High by default H = high level, L = low level, Z = high impedance, X = irrelevant, ? = indeterminate http://www.hgsemi.com.cn 13 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E When the receiver enable pin, RE, is logic low, the receiver is enabled. When the differential input voltage defined as VID = VA – VB is positive and higher than the positive input threshold, VIT+, the receiver output, R, turns high. When VID is negative and lower than the negative input threshold, VIT–, the receiver output, R, turns low. If VID is between VIT+ and VIT– the output is indeterminate. When RE is logic high or left open, the receiver output is high-impedance and the magnitude and polarity of VID are irrelevant. Internal biasing of the receiver inputs causes the output to go failsafe-high when the transceiver is disconnected from the bus (open-circuit), the bus lines are shorted (short-circuit), or the bus is not actively driven (idle bus). Table 2. Receiver Function Table DIFFERENTIAL INPUT ENABLE OUTPUT VID = VA – VB RE R VIT+ < VID L H Receive valid bus High VIT– < VID < VIT+ L ? Indeterminate bus state FUNCTION VID < VIT– L L Receive valid bus Low X H Z Receiver disabled X OPEN Z Receiver disabled by default Open-circuit bus L H Fail-safe high output Short-circuit bus L H Fail-safe high output Idle (terminated) bus L H Fail-safe high output http://www.hgsemi.com.cn 14 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Application Information The 65/75HVD308xE devices are half-duplex RS-485 transceivers commonly used for asynchronous data transmissions. The driver and receiver enable pins allow for the configuration of different operating modes. R R R R R R RE A RE A RE A DE B DE B DE B D D D D D D Figure 22. Half-Duplex Transceiver Configurations Using independent enable lines provides the most flexible control as it allows for the driver and the receiver to be turned on and off individually. While this configuration requires two control lines, it allows for selective listening into the bus traffic whether the driver is transmitting data or not. Combining the enable signals simplifies the interface to the controller by forming a single direction-control signal. In this configuration, the transceiver operates as a driver when the direction-control line is high and as a receiver when the direction-control line is low. Additionally, only one line is required when connecting the receiver-enable input to ground and controlling only the driver-enable input. In this configuration, a node not only receives the data from the bus, but also the data it sends and can verify that the correct data have been transmitted. Typical Application An RS-485 bus consists of multiple transceivers connecting in parallel to a bus cable. To eliminate line reflections, each cable end is terminated with a termination resistor, RT, whose value matches the characteristic impedance, Z0, of the cable. This method, known as parallel termination, allows for higher data rates over longer cable length. R R B DE D R A RE R A RT RT D A R B A R D R RE DE D RE B DE D B D D R RE DE D Figure 23. Typical Application Circuit http://www.hgsemi.com.cn 15 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Typical Application (continued) Design Requirements RS-485 is a robust electrical standard suitable for long-distance networking that may be used in a wide range of applications with varying requirements, such as distance, data rate, and number of nodes. Data Rate and Bus Length There is an inverse relationship between data rate and bus length, meaning the higher the data rate, the shorter the cable length; and conversely, the lower the data rate, the longer the cable may be without introducing data errors. While most RS-485 systems use data rates between 10 kbps and 100 kbps, some applications require data rates up to 250 kbps at distances of 4,000 feet and longer. Longer distances are possible by allowing for small signal jitter of up to 5 or 10%. 10000 Cable Length (ft) 5%, 10%, and 20% Jitter 1000 Conservative Characteristics 100 10 100 1k 10k 100k 1M 10M 100M Data Rate (bps) Figure 24. Cable Length vs Data Rate Characteristic Stub Length When connecting a node to the bus, the distance between the transceiver inputs and the cable trunk, known as the stub, must be as short as possible. Stubs present a non-terminated piece of bus line which can introduce reflections as the length of the stub increases. As a general guideline, the electrical length, or round-trip delay, of a stub must be less than one-tenth of the rise time of the driver, thus giving a maximum physical stub length as shown in Equation 1. Lstub ≤ 0.1 × tr × v × c where: • • • tr is the 10/90 rise time of the driver c is the speed of light (3 × 108 m/s) v is the signal velocity of the cable or trace as a factor of c (1) Bus Loading The RS-485 standard specifies that a compliant driver must be able to driver 32 unit loads (UL), where 1 unit load represents a load impedance of approximately 12 kΩ. Because the 65/75HVD308xE is a 1/8 UL transceiver, it is possible to connect up to 256 receivers to the bus. http://www.hgsemi.com.cn 16 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Typical Application (continued) Receiver Failsafe The differential receiver is fail-safe to invalid bus states caused by: • open bus conditions such as a disconnected connector, • shorted bus conditions such as cable damage shorting the twisted-pair together, or • idle bus conditions that occur when no driver on the bus is actively driving In any of these cases, the differential receiver outputs a failsafe logic High state, so that the output of the receiver is not indeterminate. Receiver failsafe is accomplished by offsetting the receiver thresholds so that the input indeterminate range does not include zero volts differential. To comply with the RS-422 and RS-485 standards, the receiver output must output a High when the differential input VID is more positive than +200 mV, and must output a Low when the VID is more negative than –200 mV. The receiver parameters which determine the failsafe performance are VIT+ and VIT– and VHYS. As seen in the table, differential signals more negative than –200 mV will always cause a Low receiver output. Similarly, differential signals more positive than +200 mV will always cause a High receiver output. When the differential input signal is close to zero, it will still be above the VIT+ threshold, and the receiver output is High. Only when the differential input is more negative than VIT– will the receiver output transition to a Low state. So, the noise immunity of the receiver inputs during a bus fault condition includes the receiver hysteresis value VHYS (the separation between VIT+ and VIT– ) as well as the value of VIT+. Detailed Design Procedure In order to protect bus nodes against high-energy transients, the implementation of external transient protection devices is necessary. 5V 100 nF 100 nF 10 kΩ VCC R1 R RxD MCU/ UART DIR RE A DE B TVS D TxD R2 10 kΩ GND Figure 25. Transient Protection Against ESD, EFT, and Surge Transients http://www.hgsemi.com.cn 17 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Power Usage in an RS-485 Transceiver Power consumption is a concern in many applications. Power supply current is delivered to the bus load as well as to the transceiver circuitry. For a typical RS-485 bus configuration, the load that an active driver must drive consists of all of the receiving nodes, plus the termination resistors at each end of the bus. The load presented by the receiving nodes depends on the input impedance of the receiver. The TIA/EIA-485-A standard defines a unit load as allowing up to 1 mA. With up to 32 unit loads allowed on the bus, the total current supplied to all receivers can be as high as 32 mA. The HVD308xE is rated as a 1/8 unit load device. As shown in , the bus input current is less than 1/8 mA, allowing up to 256 nodes on a single bus. The current in the termination resistors depends on the differential bus voltage. The standard requires active drivers to produce at least 1.5 V of differential signal. For a bus terminated with one standard 120-Ω resistor at each end, this sums to 25 mA differential output current whenever the bus is active. Typically the HVD308xE can drive more than 25-mA to a 60-Ω load, resulting in a differential output voltage higher than the minimum required by the standard (see Figure 3). Overall, the total load current can be 60 mA to a loaded RS-485 bus. This is in addition to the current required by the transceiver itself; the HVD308xE circuitry requires only about 0.4 mA with both driver and receiver enabled, and only 0.3 mA with either the driver enabled or with the receiver enabled. In low-power shutdown mode, neither the driver nor receiver is active, and the supply current is low. Supply current increases with signaling rate primarily due to the totem pole outputs of the driver (see Figure 2). When these outputs change state, there is a moment when both the high-side and low-side output transistors are conducting and this creates a short spike in the supply current. As the frequency of state changes increases, more power is used. Low-Power Shutdown Mode When both the driver and receiver are disabled (DE low and RE high) the device is in shutdown mode. If the enable inputs are in this state for less than 60 ns, the device does not enter shutdown mode. This guards against inadvertently entering shutdown mode during driver or receiver enabling. Only when the enable inputs are held in this state for 300 ns or more, the device is assured to be in shutdown mode. In this low-power shutdown mode, most internal circuitry is powered down, and the supply current is typically 1 nA. When either the driver or the receiver is re-enabled, the internal circuitry becomes active. If only the driver is re-enabled (DE transitions to high) the driver outputs are driven according to the D input after the enable times given by tPZH(SHDN) and tPZL(SHDN) in the driver switching characteristics. If the D input is open when the driver is enabled, the driver outputs defaults to A high and B low, in accordance with the driver failsafe feature. If only the receiver is re-enabled (RE transitions to low) the receiver output is driven according to the state of the bus inputs (A and B) after the enable times given by tPZH(SHDN) and tPZL(SHDN) in the receiver switching characteristics. If there is no valid state on the bus the receiver responds as described in the failsafe operation section. If both the receiver and driver are re-enabled simultaneously, the receiver output is driven according to the state of the bus inputs (A and B) and the driver output is driven according to the D input. http://www.hgsemi.com.cn 18 2019 NOV 65HVD3082E/75HVD3082E 65HVD3085E/65HVD3088E Important statement: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the consequences of the application of these products in these fields. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http://www.hgsemi.com.cn 19 2019 NOV
65HVD3088EIM/TR 价格&库存
很抱歉,暂时无法提供与“65HVD3088EIM/TR”相匹配的价格&库存,您可以联系我们找货
65HVD3088EIM/TR
  • 1+4.73220
  • 10+3.86100
  • 500+2.48490
  • 1000+2.34630
  • 2500+2.32284
库存:2500
65HVD3088EIM/TR
  • 1+4.01480
  • 30+3.72810
  • 100+3.44130
  • 500+3.15450
  • 1000+2.86770
库存:2500
