BC847B
BC847B
    UMW(友台)
    SOT-23
    SOT23 0.1A 100MHz 200mW
BC847B 数据手册
UMW R BC846A, B BC847A, B, C BC848A, B, C UMW BC847 TRANSISTOR (NPN) SOT-23 1. BASE 2. EMITTER 3. COLLECTOR FEATURES Ideally suited for automatic insertion z For Switching and AF Amplifier Applications z MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol VCBO Parameter Value Collector-Base Voltage V BC846 BC847 BC848 VCEO Unit 80 50 30 Collector-Emitter Voltage V BC846 BC847 BC848 65 45 30 VEBO Emitter-Base Voltage 6 V IC Collector Current –Continuous 0.1 A PC* Collector Power Dissipation 200 mW TJ Junction Temperature 150 ℃ Tstg Storage Temperature -65-150 ℃ DEVICE MARKING BC846A=1A; BC846B=1B; BC847A=1E; BC847B=1F; BC847C=1G; BC848A=1J; BC848B=1K: BC848C=1L www.umw-ic.com 1 友台半导体有限公司 UMW R UMW BC847 ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Symbol Parameter Collector-base breakdown voltage Test conditions VCBO IC= 10µA, IE=0 VCEO IC= 10mA, IB=0 VEBO IE= 10µA, IC=0 Collector cut-off current Collector cut-off current ICBO VCB=30 V , IE=0 BC846 VCE=60 V , IB=0 ICEO DC current gain VCE=45 V , IB=0 IEBO VEB=5 V , IC=0 hFE VCE= 5V, IC= 2mA BC846A,847A,848A BC846B,847B,848B V 0.1 μA 0.1 μA 0.1 μA VCE=30 V , IB=0 BC848 Emitter cut-off current 6 VCB=50 V , IE=0 BC848 BC847 V VCB=70 V , IE=0 BC846 BC847 45 30 BC848 Emitter-base breakdown voltage V 50 65 BC846 BC847 Max Unit 30 BC848 Collector-emitter breakdown voltage Typ 80 BC846 BC847 Min 110 220 200 450 420 BC847C,BC848C 800 Collector-emitter saturation voltage VCE(sat) IC=100mA, IB= 5mA 0.5 V Base-emitter saturation voltage VBE(sat) IC=100mA, IB= 5mA 1.1 V fT Transition frequency Collector output capacitance www.umw-ic.com Cob 2 VCE= 5 V, IC= 10mA f=100MHz VCB=10V,f=1MHz 100 MHz 4.5 pF 友台半导体有限公司 UMW R Symbol A A1 A2 b c D E E1 e e1 L L1 θ www.umw-ic.com UMW BC847 Dimensions In Millimeters Min. Max. 0.900 1.150 0.000 0.100 0.900 1.050 0.300 0.500 0.080 0.150 2.800 3.000 1.200 1.400 2.250 2.550 0.950 TYP. 1.800 2.000 0.550 REF. 0.300 0.500 0° 8° 3 Dimensions In Inches Min. Max. 0.035 0.045 0.000 0.004 0.035 0.041 0.012 0.020 0.003 0.006 0.110 0.118 0.047 0.055 0.089 0.100 0.037 TYP. 0.071 0.079 0.022 REF. 0.012 0.020 0° 8° 友台半导体有限公司
BC847B 价格&库存
很抱歉,暂时无法提供与“BC847B”相匹配的价格&库存,您可以联系我们找货
BC847B
  • 1+0.30976
  • 200+0.10330
  • 1500+0.06452
  • 3000+0.05120
库存:4174
BC847B
    • 50+0.08672
    • 600+0.06772
    • 1200+0.06670
    • 3000+0.05356
    库存:2999
    BC847B
      • 1+0.09920
      库存:4442
      BC847B
      • 50+0.09461
      • 500+0.07388
      • 3000+0.05843
      • 6000+0.05152
      • 24000+0.04547
      • 51000+0.04223
      库存:5631
