UMW
R
UMW BAW56/BAV70/BAV99
SOT-23 Plastic-Encapsulate Transistors
BAW56/BAV70/BAV99
SWITCHING DIODE
SOT-23
FEATURES
Fast Switching Speed
z
z
For General Purpose Switching Applications
High Conductance
z
1. BASE
2. EMITTER
3. COLLECTOR
BAV99
BAW56
BAV70
MARKING:A1
MARKING:A4
A1
MARKING:A7
A4
A7
Solid dot = Green molding compound device,
if none, the normal device
A1
A7
A4
Maximum Ratings @Ta=25℃
Parameter
Symbol
Limit
Unit
Reverse Voltage
VR
70
V
Forward Current
IF
200
mA
IFSM
2.0
A
PD
225
mW
RθJA
556
℃/W
TJ
150
TSTG
-55~+150
Non-Repetitive Peak Forward Surge Current @t=8.3ms
Power Dissipation
Thermal Resistance Junction to Ambient
Junction Temperature
Storage Temperature range
Electrical Characteristics @Ta=25℃
Parameter
Reverse breakdown voltage
Symbol
VR
Min
Typ
Max
70
Unit
Conditions
V
IR=100μA
VF1
0.715
V
IF=1mA
VF2
0.855
V
IF=10mA
VF3
1
V
IF=50mA
VF4
1.25
V
IF=150mA
Reverse current
IR
2.5
μA
VR=70V
Capacitance between terminals
CT
1.5
pF
VR=0,f=1MHz
Reverse recovery time
t rr
6
ns
Forward voltage
www.umw-ic.com
1
IF = IR = 10mA,
Irr= 0.1 x IR, RL = 100Ω
友台半导体有限公司
Typical Characteristics
Forward
Reverse
Characteristics
Characteristics
1000
300
100
(nA)
REVERSE CURRENT IR
FORWARD CURRENT
10
Ta=100℃
100
Ta
=2
5℃
Ta
=1
00
30
IF
(mA)
300
3
1
30
10
Ta=25℃
3
0.3
0.1
0.0
1
0.4
0.8
FORWARD VOLTAGE
1.2
VF
(V)
40
REVERSE VOLTAGE
60
VR
80
(V)
Power Derating Curve
Capacitance Characteristics
1.4
300
Ta=25℃
f=1MHz
(mW)
PD
1.3
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
250
1.2
1.1
200
150
100
50
1.0
10
REVERSE VOLTAGE
www.umw-ic.com
15
VR
50
75
AMBIENT TEMPERATURE
(V)
2
100
Ta
125
150
友台半导体有限公司
Symbol
A
A1
A2
b
c
D
E1
E
e
e1
L
Dimensions In Millimeters
Min.
Max.
1.050
1.250
0.000
0.100
1.050
1.150
0.300
0.500
0.100
0.200
2.820
3.020
1.500
1.700
2.650
2.950
0.950(BSC)
1.800
2.000
0.300
0.600
0°
8°
Dimensions In Inches
Min.
Max.
0.041
0.049
0.000
0.004
0.041
0.045
0.012
0.020
0.004
0.008
0.111
0.119
0.059
0.067
0.104
0.116
0.037(BSC)
0.071
0.079
0.012
0.024
0°
8°
-3L
www.umw-ic.com
3
友台半导体有限公司
www.umw-ic.com
4
友台半导体有限公司
很抱歉,暂时无法提供与“BAV70”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.04743
- 600+0.03837
- 国内价格
- 50+0.07030
- 500+0.06560
- 5000+0.06100
- 10000+0.05630
- 30000+0.05160
- 50000+0.04690
- 国内价格
- 50+0.06275
- 500+0.04979
- 3000+0.03834
- 6000+0.03402
- 24000+0.03035
- 51000+0.02830
