UMW
R
BC807
UMW BC807
SOT-23 Plastic-Encapsulate Transistors
TRANSISTOR (PNP)
SOT-23
FEATURE
Ldeally suited for automatic insertion
Epitaxial planar die construction
Complementary NPN type available(BC817)
1. BASE
2. EMITTER
3. COLLECTOR
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
-50
Unit
V
Collector-Emitter Voltage
-45
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current -Continuous
-0.5
A
PC
Collector Power Dissipation
0.3
W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55-150
VCBO
Collector-Base Voltage
VCEO
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Symbol
Parameter
T est conditions
Min
Max
Unit
Collector-base breakdown voltage
VCBO
IC= -10μA, IE=0
-50
V
Collector-emitter breakdown voltage
VCEO
IC==
-10mA, IB 0
-45
V
Emitter-base breakdown voltage
VEBO
IE= -1μA, IC=0
-5
V
Collector cut-off current
ICBO
V
CB= -45V, IE 0
-0.1
μA
ICEO
V
CE= -40V, IB 0
-0.2
μA
Emitter cut-off current
IEBO
V=
EB= -4 V, IC 0
-0.1
μA
hFE(1)
VCE= -1V, IC= -100mA
100
hFE(2)
VCE= -1V, IC= -500mA
40
DC current gain
600
Collector-emitter saturation voltage
VCE(sat)
IC=-500mA, IB= -50mA
-0.7
V
Base-emitter saturation voltage
VBE(sat)
IC= -500mA, IB= -50mA
-1.2
V
fT
Transition frequency
VCE= -5V, IC= -10mA
f=100MHz
100
MHz
CLASSIFICATION OF hFE (1)
Rank
BC807-16
BC807-25
BC807-40
Range
100-250
160-400
250-600
Marking
5A
5B
5C
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW BC807
Typical Characteristics
Static Characteristic
- 200
o
hFE
-0.7mA
-0.6mA
- 160
-0.5mA
- 120
-0.4mA
-0.3mA
- 80
Ta=100 C
- 400
DC CURRENT GAIN
COLLECTOR CURRENT
hFE —— IC
- 500
-1mA
COMMON
-0.9mA EMITTER
Ta=25℃
-0.8mA
- 240
IC
(mA)
- 280
- 300
o
Ta=25 C
- 200
-0.2mA
- 40
VCE= -1V
IB=-0.1mA
- 6
- 10
- 8
- 4
COLLECTOR-EMITTER VOLTAGE
- 12
- 14
VCE (V)
- 100
- 1
- 16
VBEsat —— IC
-1.2
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
VCEsat ——
-0.4
β=10
-1.0
-0.8
- 10
COLLECTOR CURRENT
Ta=25℃
-0.6
Ta=100℃
IC
- 100
(mA)
- 500
IC
β=10
-0.3
-0.2
Ta=100℃
-0.1
-0.4
Ta=25℃
-0.2
-0.1
-1
-10
COLLECTOR CURRENT
IC
-0.0
-0.1
- 500
-100
-1
(mA)
IC
-10
-100
COLLECTOR CURRENT
VBE
Cob / Cib
100
-1000
IC
VCB / VEB
f=1MHz
IE=0 / IC=0
o
Ta=25 C
(pF)
IC (mA)
50
Cib
COLLECTOR CURRENT
C
-100
o
CAPACITANCE
Ta=100 C
-10
Ta=25℃
- 500
(mA)
10
Cob
-1
VCE=-1V
-0.1
- 0.3
- 0.4
- 0.5
- 0.7
- 0.8
- 0.6
BASE-EMITTER VOLTAGE
VBE(V)
1
- 1.0
IC
Pc
0.4
(MHz)
100
TRANSITION FREQUENCY
fT
- 5
REVERSE VOLTAGE
COLLECTOR POWER DISSIPATION
Pc (W)
fT
300
- 0.9
- 10
V
(V)
Ta
0.3
0.2
0.1
VCE=-5V
o
Ta=25 C
10
-1
COLLECTOR CURRENT
www.umw-ic.com
0.0
- 60
- 10
IC
50
75
AMBIENT TEMPERATURE
(mA)
2
100
Ta
125
150
友台半导体有限公司
UMW
R
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.umw-ic.com
UMW BC807
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
3
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
友台半导体有限公司
很抱歉,暂时无法提供与“BC807-40”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.11801
- 300+0.08930
- 1200+0.08796
- 3000+0.07336
- 国内价格
- 1+0.42458
- 200+0.14172
- 1500+0.08861
- 3000+0.07029
- 国内价格
- 50+0.12874
- 500+0.09742
- 3000+0.08003
- 6000+0.06956
- 24000+0.06048
- 51000+0.05562
