UMW
R
UMW BAV23A/C/S
SOT-23 Plastic-Encapsulate Transistors
BAV23A/C/S
SWITCHING DIODE
SOT-23
FEATURES
Fast Switching Speed
High Conductance
z
z
For General Purpose Switching Applications
z
BAV23A
BAV23C
BAV23S
MARKING: KT7
MARKING: KT6
MARKING:KL31
KT6
KL31
KT7
Solid dot = Green molding compound device,
if none, the normal device
KT7
KT6
KL31
MAXIMUM RATINGS ( Ta=25℃ unless otherwise noted )
Symbol
Parameter
Value
Unit
250
V
RMS Reverse Voltage
175
V
Average Rectified Output Current
225
mA
IFSM
Non-repetitive Peak Forward Surge Current @ t= 8.3ms
1.7
A
PD
Power Dissipation
350
mW
Thermal Resistance from Junction to Ambient
357
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
VRRM
Peak Repetitive Reverse Voltage
VRWM
Working Peak Reverse Voltage
VR(RMS)
IO
RΘJA
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Reverse voltage
V(BR)
IR=100μA
Reverse current
IR
VR=250V
0.1
Forward voltage
VF
IF=100mA
1
IF=200mA
1.25
Total capacitance
Ctot
Reverse recovery time
www.umw-ic.com
trr
250
Unit
V
μA
V
VR=0V,f=1MHz
5
pF
IF= IR=30mA, Irr=0.1×IR, RL=100Ω
50
ns
1
友台半导体有限公司
Typical Characteristics
Forward
Characteristics
Reverse
1000
300
Pulsed
Characteristics
Pulsed
(nA)
(mA)
100
REVERSE CURRENT IR
T=
a 2
5℃
FORWARD CURRENT
T=
a 1
00
IF
10
1
0.1
0.01
0.2
Ta=100℃
100
10
Ta=25℃
1
0.4
0.6
0.8
FORWARD VOLTAGE
1.0
VF
1.2
(V)
100
150
REVERSE VOLTAGE
200
250
(V)
VR
Power Derating Curve
Capacitance Characteristics
1.6
400
(mW)
f=1MHz
350
300
PD
1.4
1.2
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
Ta=25℃
1.0
0.8
0.6
250
200
150
100
50
8
12
REVERSE VOLTAGE
www.umw-ic.com
16
VR
(V)
25
50
75
100
AMBIENT TEMPERATURE
2
125
Ta
150
友台半导体有限公司
Symbol
A
A1
A2
b
c
D
E1
E
e
e1
L
Dimensions In Millimeters
Min.
Max.
1.050
1.250
0.000
0.100
1.050
1.150
0.300
0.500
0.100
0.200
2.820
3.020
1.500
1.700
2.650
2.950
0.950(BSC)
1.800
2.000
0.300
0.600
0°
8°
Dimensions In Inches
Min.
Max.
0.041
0.049
0.000
0.004
0.041
0.045
0.012
0.020
0.004
0.008
0.111
0.119
0.059
0.067
0.104
0.116
0.037(BSC)
0.071
0.079
0.012
0.024
0°
8°
-3L
www.umw-ic.com
3
友台半导体有限公司
www.umw-ic.com
4
友台半导体有限公司
很抱歉,暂时无法提供与“BAV23C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.51896
- 200+0.17264
- 1500+0.10816
- 3000+0.08591
- 国内价格
- 20+0.16097
- 300+0.12533
- 1200+0.10553
- 3000+0.08959
- 国内价格
- 20+0.17561
- 200+0.13673
- 600+0.11513
- 3000+0.09774
- 9000+0.08651
- 21000+0.08046
