UMW
R
UMW MMBT5551
SOT-23 Plastic-Encapsulate Transistors
MMBT5551
TRANSISTOR (NPN)
SOT–23
FEATURES
z Complementary to MMBT5401
z Ideal for Medium Power Amplification and Switching
1. BASE
MARKING: G1
2. EMITTER
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
180
V
VCEO
Collector-Emitter Voltage
160
V
VEBO
Emitter-Base Voltage
6
V
IC
Collector Current
600
mA
PC
Collector Power Dissipation
300
mW
Thermal Resistance From Junction To Ambient
416
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RΘJA
3. COLLECTOR
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Collector-base breakdown voltage
Symbol
V(BR)CBO
Collector-emitter breakdown voltage
V(BR)CEO
Emitter-base breakdown voltage
V(BR)EBO
Collector cut-off current
ICBO
Emitter cut-off current
IEBO
hFE(1)
DC current gain
hFE(2) *
hFE(3)
Collector-emitter saturation voltage
Base-emitter saturation voltage
Min
Typ
Max
Unit
IC=100µA, IE=0
180
V
IC=1mA, IB=0
160
V
IE=10µA, IC=0
6
V
VCB=120V, IE=0
50
nA
VEB=4V, IC=0
50
nA
VCE=5V, IC=1mA
80
VCE=5V, IC=10mA
100
VCE=5V, IC=50mA
50
300
VCE(sat)1
IC=10mA, IB=1mA
0.15
V
VCE(sat)2
IC=50mA, IB=5mA
0.2
V
VBE(sat)1
IC=10mA, IB=1mA
1
V
VBE(sat)2
IC=50mA, IB=5mA
1
V
300
MHz
6
pF
fT
Transition frequency
Collector output capacitance
Test conditions
Cob
VCE=10V,IC=10mA, f=100MHz
100
VCB=10V, IE=0, f=1MHz
*Pulse test: pulse width ≤300μs, duty cycle≤ 2.0%.
CLASSIFICATION OF hFE (2)
RANK
L
H
RANGE
100-200
200-300
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW MMBT5551
Static Characteristic
18
80uA
15
COMMON EMITTER
VCE=5V
COMMON
EMITTER
Ta=25℃
60uA
50uA
9
40uA
6
30uA
Ta=25℃
100
IB=20uA
3
10
4
6
8
10
COLLECTOR-EMITTER VOLTAGE
VBEsat ——
1.0
VCE
1
12
COLLECTOR CURRENT
IC
IC
200
100
200
β=10
0.8
Ta=25℃
0.6
Ta=100℃
0.4
0.2
0.1
0.1
Ta=100℃
Ta=25℃
0.01
1
10
COLLECTOR CURRENT
VBE
100
IC
1
200
10
(mA)
COLLECTOR CURRENT
IC
Cob / Cib
100
200
IC
(mA)
VCB / VEB
COMMON EMITTER
VCE=5V
f=1MHz
IE=0 / IC=0
CAPACITANCE
C
Ta=100℃
Ta=25℃
Cib
(pF)
IC (mA)
100
100
(mA)
VCEsat ——
B IC
0.3
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
10
(V)
β=10
COLLECTOR CURRENT
Ta=100℃
hFE
70uA
12
DC CURRENT GAIN
IC
(mA)
90uA
COLLECTOR CURRENT
hFE —— IC
500
Ta=25℃
10
1
0.2
0.4
0.6
BASE-EMITTER VOLTAGE
fT
0.8
Cob
1
0.1
1.0
VBE(V)
10
1
10
REVERSE VOLTAGE
IC
PC
0.4
150
V
(V)
Ta
VCE=10V
TRANSITION FREQUENCY
fT
COLLECTOR POWER DISSIPATION
PC (W)
(MHz)
Ta=25℃
100
50
0.3
0.2
0.1
0.0
1
10
3
COLLECTOR CURRENT
www.umw-ic.com
IC
25
50
75
AMBIENT TEMPERATURE
(mA)
2
100
Ta
125
150
友台半导体有限公司
UMW
R
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.umw-ic.com
UMW MMBT5551
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
3
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
友台半导体有限公司
很抱歉,暂时无法提供与“MMBT5551”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07517
- 500+0.05962
- 3000+0.04450
- 6000+0.03932
- 24000+0.03489
- 51000+0.03251
- 国内价格
- 1+0.21890
- 200+0.07293
- 1500+0.04565
- 3000+0.03619
- 国内价格
- 50+0.07231
- 600+0.05741
- 1200+0.05655
- 3000+0.04287
