SLW6028S3R3MST
SLW6028S3R3MST
    SUNLTECH(顺磁)
    SMD,6x6mm
    功率电感 3.3µH ±20% IND_6X6MM_SM 2.80mm 6.00 x 6.00mm 25mΩ 630mA
SLW6028S3R3MST 数据手册
SLW6028S Series Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems SLW (1) (1) (2) (3) (4) 6028 (2) S 100 M (3) (4) (5) S T (6) (7) Series Type Dimension:L X H Material Code Inductance:2R2=2.2μH ; 100=10µH;101=100µH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern Unit:mm Series SLW6028S Rev.01 A B C D E F a Typ. b Typ. c Typ. 6.0±0.3 6.0±0.3 2.8Max. 4.9±0.3 1.55±0.3 2.90±0.3 2.8 1.7 5.7 Page 1 of 4 www. sunltech.com SLW6028S Series ◆ Electrical Characteristics ( : ℃ ℃ ℃ ℃ 1) Operating temperature range Including self-heating) -40 ~ +125 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ◆ Construction and material ◆ REFLOW-PROFILE Rev.01 Page 2 of 4 www. sunltech.com SLW6028S Series ◆ Specification Inductance Part Number @100KHz,1V (µH) DC Resistance ±30% (Ω) DCR Frequency MHz Saturation Current(A) Heat Rating Current (A) S.R.F Isat Irms Min.Self-resonant ( ) SLW6028S Series SLW6028S1R0NST 1.0±30% 0.010 70 6.00 5.20 SLW6028S1R5NST 1.5±30% 0.013 65 6.00 4.58 SLW6028S2R2MST 2.2±20% 0.015 56 5.10 4.09 41 3 .63 3.48 SLW6028S3R3MST 3.3±20% 3.3±20% 0.025 41 3.63 3.48 0.025 SLW6028S4R7MST 4.7±20% 0.030 35 3.00 3.08 SLW6028S6R8MST 6.8±20% 0.047 27 2.85 2.40 SLW6028S8R2MST 8.2±20% 0.055 24 2.60 2.25 SLW6028S100MST 10±20% 0.072 23 2.04 1.95 SLW6028S120MST 12±20% 0.080 18 1.80 1.85 SLW6028S150MST 15±20% 0.125 18 1.75 1.45 SLW6028S180MST 18±20% 0.120 15 1.52 1.45 SLW6028S220MST 22±20% 0.140 14 1.60 1.40 SLW6028S270MST 27±20% 0.155 13 1.50 1.32 SLW6028S330MST 33±20% 0.185 12 1.35 1.22 SLW6028S390MST 39±20% 0.225 11 1.25 1.10 SLW6028S470MST 47±20% 0.245 9.5 1.15 1.06 SLW6028S620MST 62±20% 0.345 7.7 0.95 0.89 SLW6028S680MST 68±20% 0.360 7.7 0.95 0.86 SLW6028S750MST 75±20% 0.410 7.7 0.90 0.81 SLW6028S820MST 82±20% 0.445 7.7 0.90 0.78 SLW6028S101MST 100±20% 0.500 7.1 0.65 0.70 ◆ Note :All test data is referenced to 20°C ambient; 2:Rated current: Isat or Irms, whichever is smaller; 3:Isat: DC current at which the inductance drops approximate 30% from its value without current; 4:Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. 1 ◆ Standard Packing Quantity: :2000 pcs/reel Rev.01 Page 3 of 4 www. sunltech.com SLW6028S Series ◆ TYPICAL ELECTRICAL CHARACTERISTICS SLW6028S Series Rev.01 Page 4 of 4 www. sunltech.com
