HSM4805
HSM4805
    HUASHUO(华朔)
    SOP-8
    双P-Ch 30V快速开关MOSFET
HSM4805 数据手册
HSM4805 Dual P-Ch 30V Fast Switching MOSFETs Description Product Summary The HSM4805 is the high cell density trenched Pch MOSFETs, which provide excellent RDSON and gate charge for most of the synchronous buck converter applications. The HSM4805 meet the RoHS and Green Product requirement, 100% EAS guaranteed with full function reliability approved. ⚫ ⚫ ⚫ ⚫ ⚫ 100% EAS Guaranteed Green Device Available Super Low Gate Charge Excellent CdV/dt effect decline Advanced high cell density Trench technology VDS -30 V RDS(ON),typ 12 mΩ ID -9 A SOP8 Pin Configuration Absolute Maximum Ratings Symbol Parameter Rating Units VDS Drain-Source Voltage -30 V VGS Gate-Source Voltage ±25 V ID@TA=25℃ Continuous Drain Current, -VGS @ -10V1 -9 A ID@TA=70℃ Continuous Drain Current, -VGS @ -10V1 -7 A IDM Pulsed Drain Current2 -40 A EAS Single Pulse Avalanche Energy3 125 mJ IAS Avalanche Current -50 A PD@TA=25℃ Total Power Dissipation4 2 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Thermal Data Symbol Parameter RθJA Thermal Resistance Junction-Ambient 1 RθJC Thermal Resistance Junction-Case1 www.hs-semi.cn Ver 2.0 Typ. Max. Unit --- 85 ℃/W --- 24 ℃/W 1 HSM4805 Dual P-Ch 30V Fast Switching MOSFETs Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol BVDSS Parameter Drain-Source Breakdown Voltage △BVDSS/△TJ BVDSS Temperature Coefficient RDS(ON) Static Drain-Source On-Resistance2 VGS(th) Gate Threshold Voltage △VGS(th) VGS(th) Temperature Coefficient IDSS Drain-Source Leakage Current Conditions Min. Typ. Max. Unit VGS=0V , ID=-250uA -30 --- --- V Reference to 25℃ , ID=-1mA --- -0.022 --- V/℃ VGS=-10V , ID=-8A --- 12 16 VGS=-4.5V , ID=-5A --- 18 28 -1.0 --- -2.5 V --- 4.6 --- mV/℃ VDS=-24V , VGS=0V , TJ=25℃ --- --- -1 VDS=-24V , VGS=0V , TJ=55℃ --- --- -5 VGS=VDS , ID =-250uA m uA IGSS Gate-Source Leakage Current VGS=±20V , VDS=0V --- --- ±100 nA gfs Forward Transconductance VDS=-5V , ID=-8A --- 24 --- S Rg Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 9 ---  Qg Total Gate Charge (-4.5V) --- 20 --- --- 5.1 --- VDS=-15V , VGS=-4.5V , ID=-8A Qgs Gate-Source Charge Qgd Gate-Drain Charge --- 7.3 --- Turn-On Delay Time --- 33.8 --- Td(on) nC Rise Time VDD=-15V , VGS=-10V , RG=3.3, --- 35.8 --- Turn-Off Delay Time ID=-1A --- 72.8 --- Fall Time --- 10.6 --- Ciss Input Capacitance --- 2215 --- Coss Output Capacitance --- 310 --- Crss Reverse Transfer Capacitance --- 237 --- Min. Typ. Max. Unit --- --- -9 A --- --- -50 A --- --- -1.2 V --- 35 --- nS --- 25 --- nC Tr Td(off) Tf VDS=-15V , VGS=0V , f=1MHz ns pF Diode Characteristics Symbol Parameter IS Continuous Source Current1,5 ISM Pulsed Source Current2,5 VSD Diode Forward Voltage2 trr Reverse Recovery Time Qrr Reverse Recovery Charge Conditions VG=VD=0V , Force Current VGS=0V , IS=-1A , TJ=25℃ IF=-8A , dI/dt=100A/µs , TJ=25℃ Note : 1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper. 2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3.The EAS data shows Max. rating . The test condition is V DD=-25V,VGS=-10V,L=0.1mH,IAS=-50A 4.The power dissipation is limited by 150℃ junction temperature 5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation. www.hs-semi.cn Ver 2.0 2 HSM4805 Dual P-Ch 30V Fast Switching MOSFETs Typical Characteristics Fig.2 On-Resistance vs G-S Voltagede Fig.1 Typical Output Characteristicsdiode 12 -IS Source Current(A) 10 8 6 TJ=150℃ TJ=25℃ 4 2 0 0.2 0.4 0.6 0.8 1 -VSD , Source-to-Drain Voltage (V) Fig.3 Forward Characteristics of Reverse diode 2.0 Normalized On Resistance 1.5 Normalized VGS(th) Fig.4 Gate-Charge Characteristics 1.5 1 1.0 0.5 0 0.5 -50 0 50 100 TJ ,Junction Temperature ( ℃) 150 -50 Fig.5 Normalized VGS(th) vs. TJ www.hs-semi.cn 0 50 100 150 TJ , Junction Temperature (℃) Fig.6 Normalized RDSON vs. TJ Ver 2.0 3 HSM4805 Dual P-Ch 30V Fast Switching MOSFETs 10000 F=1.0MHz Capacitance (pF) Ciss 1000 Coss Crss 100 10 1 5 9 13 17 -VDS Drain to Source Voltage(V) 21 25 Fig.7 Capacitance Fig.8 Safe Operating Area Normalized Thermal Response (RθJA) 1 DUTY=0.5 0.2 0.1 0.1 0.05 0.01 P DM 0.01 T ON T D = TON/T SINGLE TJpeak = TC+P DMXRθJC 0.001 0.0001 0.001 0.01 0.1 1 10 100 1000 t , Pulse Width (s) Fig.9 Normalized Maximum Transient Thermal Impedance Fig.10 Switching Time Waveform www.hs-semi.cn Fig.11 Unclamped Inductive Switching Waveform Ver 2.0 4 HSM4805 Dual P-Ch 30V Fast Switching MOSFETs Ordering Information Part Number HSM4805 www.hs-semi.cn Package code SOP-8 Ver 2.0 Packaging 4000/Tape&Reel 5
HSM4805
物料型号:HSM4805
器件简介:HSM4805是高单元密度的沟槽P沟道MOSFET,为同步降压转换器应用提供出色的RDSON和栅极电荷。
引脚分配:SOP8封装,具体的引脚配置未在文档中明确列出。
参数特性: - 漏源电压(VDs):-30V - 静态漏源导通电阻(RDS(ON).typ):12mΩ - 连续漏电流(ID):-9A
功能详解: - 符合RoHS和绿色产品要求 - 100% EAS保证 - 超低栅极电荷 - 优秀的CdV/dt效应下降 - 高级高单元密度沟槽技术
应用信息:适用于同步降压转换器应用。
封装信息:SOP8封装,4000/卷带式封装。
绝对最大额定值和热数据提供了器件在极端条件下的电气和热性能参数。
电气特性表格详细列出了在不同条件下的最小值、典型值和最大值。
二极管特性表格提供了二极管的连续源电流、脉冲源电流、二极管正向电压等参数。
文档还包含了典型的特性曲线图和开关时间波形图,以及安全工作区和未夹紧感性开关波形图。
订购信息提供了部件编号、封装代码和包装信息。
SOP8封装外形尺寸表格列出了封装的详细尺寸。
HSM4805 价格&库存
很抱歉,暂时无法提供与“HSM4805”相匹配的价格&库存,您可以联系我们找货
