SS22 THRU SS2200
Reverse Voltage - 20 to 200 Volts
Forward Current - 2.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
PINNING
PIN
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
DESCRIPTION
1
Cathode
2
Anode
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
DO-214AC/SMA
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
2
1
250 °C/10 seconds at terminals
Mechanical Data
Unipolar
Case: JEDEC DO-214AC/SMA molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end Mounting
Position: Any
Weight : 0.003 ounce, 0.093 grams
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 2.0A
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SYMBOLS
SS22
SS23
SS24
SS25
SS26
SS28
SS210
SS2150
SS2200
UNITS
VRMM
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
V
V
V
VRMS
VDC
I(AV)
2.0
A
IFSM
50
A
VF
0.55
IR
CJ
RJA
5.0
220
0.95
0.2
2.0
180
-50 to +125
TJ
1
mA
℃/W
-50 to +150
-50 to +150
TSTG
V
pF
75.0
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
www.tw-gmc.com
0.85
0.70
0.5
10.0
SS22 THRU SS2200
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
10 4
T J =75°C
10 2
SS22/SS24
SS26-SS220
10
1
T J =25°C
10 0
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
500
Junction Capacitance ( pF)
Instaneous Forward Current (A)
T J =100°C
10 3
Case Temperature (°C)
10
1.0
SS22/SS24
SS26/SS28
SS210/SS212
SS215/SS220
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
T J =25°C
200
100
50
SS22/SS24
SS26-SS220
10
1.8
0.1
Transient Thermal Impedance( °C /W)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
www.tw-gmc.com
1
100
10
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.6- Typical Transient Thermal Impedance
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2
100
SS22 THRU SS2200
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
The recommended mounting pad size
2.4
(94)
1.8
(71)
1.8
(71)
1.8
(71)
mm
Unit :
(mil)
www.tw-gmc.com
3
a
0.3
12
很抱歉,暂时无法提供与“SS22”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.17107
- 200+0.13900
- 800+0.12118
- 国内价格
- 20+0.18663
- 200+0.15164
- 600+0.13220
- 2000+0.09990
- 10000+0.08975
- 20000+0.08424
