SS52-SS5200
REVERSE VOLTAGE - 20 to 200 Volts FORWARD CURRENT - 5.0 Amperes
SMA/DO-214AC
FEATURES
● Metal-Semiconductor junction with gard ring
● Epitaxial construction
0.087 (2.21)
0.110(2.80)
0.086(2.18)
0.051 (1.29)
● Low forward voltage drop
● High current capability
● The plastic material carries UL recognition 94V-0
0.180(4.57)
0.157(3.99)
● For use in low vlotage, high frequency inverters,
0.012(0.305)
0.006(0.152)
free wheeling, and polarity protection applications
0.096(2.42)
0.067(1.70)
MECHANICAL DATA
0.060(1.52)
0.030(0.76)
●Case: Molded Plastic
0.008(0.203)MAX.
●Polarity:Color band denotes cathode
0.222(5.66)
0.185(4.70)
●Weight :0.058 grams
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
CHARACTERISTICS
SS5200 UNIT
SYMBOL
SS52
SS53
SS54
SS55
SS56
SS58
SS510
Maximum Recurrent Peak Reverse Voltage
VRRM
40
50
60
80
100
150
200
V
Maximum RMS Voltage
VRMS
14
21
28
35
42
56
70
105
140
V
VDC
40
50
60
80
100
150
200
V
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
0.375″(9.5mm) Lead Lengths
SS5150
I(AV)
5.0
A
IFSM
100
A
Peak Forward Surage Current
8.3ms Single Half Sine-Wave
Super Imposed on Rated Load(JEDEC Method)
Maximum Forward Voltage at 5.0A DC
Maximum DC Reverse Current
@TJ=25℃
at Rated DC Bolcking Voltage
@TJ=100℃
Typical Junction Capacitance (Note1)
Typical Thermal Resistance (Note2)
Operating Temperature Range
Storage Temperature Range
VF
0.55
0.85
0.95
V
1.0
CJ
500
350
pF
RθJA
15
10
℃/W
IR
mA
TJ
-55 to +150
TSTG
-55 to +150
NOTES: 1.Measured at 1.0 MHz and applied reverse voltage of 4.0V DC
2.Thermal resistance junction to ambient,
www.slkormicro.com
0.7
0.2
1
SS52-SS5200
RATING AND CHARACTERTIC
FIG. 1 – FORWARD CURRENT DERATING CURVE
FIG. 2 – MAXIMUM NON-REPETITIVE SURGE CURRENT
PEAK FORWARD SURGE CURRENT,
(AMPERES)
AVERAGE FORWARD CURRENT
AMPERES
6.0
5.0
4.0
3.0
2.0
SS52- SS510
SS515- SS520
1.0
75
50
100
125
150
200
150
100
50
PULSE WIDTH 8.3ms
SINGLE HALF-SINE-WAVE
(JEDEC METHOD)
175
2
5
LEAD TEMPERATURE (℃)
10
100
NUMBER OF CYCLES AT 60Hz
FIG.3 – TYPICAL JUNCTION CAPACITANCE
FIG.4-TYPICAL FORWARD CHARACTERISTICS
100
INSTANTANEOUS FORWARD CURRENT,
(A)
SS52 -SS54
CAPACITANCE, (pF)
4000
1000
SS52-SS54
SS55-SS520
10
SS55-SS56
SS58-SS510
SS515 - SS520
1.0
T J = 25°C
T J = 25°C f = 1 MHz
100
0.1
0.1
10
1
0.1
100
0.2
FIG.2-TYPICAL REVER CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT(mA)
T J=100℃
1.0
T J=75℃
0.1
T J=25℃
0.01
0.001
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
www.slkormicro.com
0.4
0.5
0.6
0.7
0.8
0.9
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
REVERSE VOLTAGE ,VOLTS
2
1.0
很抱歉,暂时无法提供与“SS5150”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.38729
- 100+0.31461
- 300+0.27832
- 2000+0.22572
- 4000+0.20402
- 10000+0.19311
