OR-3H7B-TP-G
OR-3H7B-TP-G
    ORIENT(奥伦德)
    SOP-4
    光电耦合器 If=50mA Vr=6V P=70mW 3.75KVrms
OR-3H7B-TP-G 数据手册
Shenzhen Orient Components Co ., Ltd OR-3H7 ORIENT Photo coupler Product Data Sheet Part Number: OR-3H7 Customer: Date: SHENZHEN ORIENT COMPONENTS CO.,LTD. Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGangDist,Shenzhen,GD TEL:0755-29681816 FAX:0755-29681200 www.orient-opto.com Copyright© 2019 Orient .All rights Reserved 1 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 1.Features 1. Current transfer ratio(CTR) : MIN. 50% at IF = 5mA, VCE = 5V, Ta=25 ℃ 2. High input-output isolation voltage.(VISO=3,750Vrms) 3. Collector and emitter Voltage : 80V(MIN) 4. Operating Temperature :-55 ℃ to 125 ℃ 5. Lead free, in compliance with RoHS standards 6. MSL Class Ⅰ 2.Instructions The OR-3H7 series device contains an infrared led and a photo transistor detector. They are encapsulated in a 4-pin SOP, free of halogens and Sb2O3 3.Application Range 1.Mixed PCB substrate requiring high density installation 2.Programmable controller 3.System apparatus and measuring instruments 4.Max Absolute rated Value (Normal Temperature=25℃) Parameter Input Output Symbol Rated Value Unit Forward Current IF 50 mA Peak forward current(t=10us) IFM 1 A Reverse Voltage VR 6 V Power Dissipation P 70 mW Junction Temperature 125 ℃ Collector and emitter Voltage Tj VCEO 80 Emitter and collector Voltage VECO 7 Collector Current IC 50 mA Power Dissipation PC 150 mW Junction Temperature Tj 125 ℃ mW Total Power Dissipation V *1 Insulation Voltage Ptot 200 Viso 3750 Vrms Rated Impulse Insulation Voltage VIORM 630 V Operating Temperature -55 to + 125 Storage Temperature Topr Tstg *2 Soldering Temperature Tsol 260 -55 to + 150 ℃ *1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2.soldering time is 10 seconds Copyright© 2019 Orient .All rights Reserved 2 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 5.Opto-electronic Characteristics(Normal Temperature=25℃) Parameter Input Output Typ.* Max Unit Symbol Condition Min Forward Voltage VF IF=20mA --- 1.2 1.4 V Reverse Current IR VR=5V --- --- 5 μA Terminal Capacitance Ct V=0, f=1KHz --- 30 250 pF Collector Dark Current ICEO --- --- 100 nA 80 --- --- V 7 --- --- V 50 --- 600 % 2.5 --- 30 mA 100 --- 600 % 0.5 --- 3 mA --- --- 0.4 V --- Ω Collector-Emitter Breakdown Voltage BVCEO Emitter-Collector Breakdown Voltage BVECO *1 Current Transfer Ratio CTR Collector Current IC *1 Current Transfer Ratio CTR Collector Current IC VCE=20V IF=0mA IC=0.1mA IF=0mA IE=0.1mA IF=0mA IF=5mA VCE=5V Transforming Characteristics Collector-Emitter Saturation Voltage VCE(sat) IF=0.5mA VCE=5V IF=8mA IC= 2.4mA DC500V Insulation Impedance Riso Floating Capacitance Cf V=0, f=1MHz --- 0.6 1 pF Response Time tr VCE=5V, --- 2 18 μs --- 3 18 μs 40~60%R.H. 5×1010 1×1011 IC=2mA, Descend Time tf RL=100Ω, f=100Hz  Current Conversion Ratio = IC / IF × 100% Copyright© 2019 Orient .All rights Reserved 3 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 6.Rank table of current transfer ratio CTR MODEL NO. CTR Rank Min. Max. A 80 160 A1 100 160 B 130 260 C 200 400 D 300 600 No Mark 50 600 AL 100 200 BLL 200 400 GB 100 600 OR-3H7 Condition Unit IF=5mA, VCE=5V, Ta=25℃ % IF=0.5mA, VCE=5V, Ta=25℃ IF=5mA, VCE=5V, Ta=25℃ IF=0.5mA, VCE=5V, Ta=25℃ Current Conversion Ratio = IC / IF × 100%  7.Order Information Part Number OR-3H7X-W-Y-Z Note X = CTR Rank (A , A1, B, C, D, AL, BLL, GB or none) W = Tape and reel option (TP or TP1). Y = ‘V’ code for VDE safety (This options is not necessary). Z = ‘G’ code for Halogen free. * VDE Code can be selected. Option Description Packing quantity TP Surface mount lead form (low profile) + TP tape & reel option 3000 units per reel TP1 Surface mount lead form (low profile) + TP1 tape & reel option 3000 units per reel Copyright© 2019 Orient .All rights Reserved 4 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 8.Naming Rule (1) ORIENT. (2) 3H7 denotes Device Part Number. (3) (4) (5) (6) (7) denotes Rank Code. denotes Year Code. denotes Week Code. denotes Day Code. Anode. * Halogen Free Mark can be selected. * VDE Mark can be selected. Copyright© 2019 Orient .All rights Reserved 5 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 9.Outer Dimension 10.Recommended Foot Print Patterns (Mount Pad) (Unit:mm) Copyright© 2019 Orient .All rights Reserved 6 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 11.Taping Dimensions (1)OR-3H7-TP (2)OR-3H7-TP1 type Symbol Dimensions: mm (in.) bandwidth W 12±0.3 (0.47) pitch P0 4±0.1 (0.15) F 5.5±0.1 (0.217) P2 2±0.1 (0.079) P1 8±0.1 (0.315) pitch interval Encapsulation type Quantity (pieces) Copyright© 2019 Orient .All rights Reserved TP/TP1 3000 7 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 12.Package Dimension (1) package dimension (2)Packing Label Sample 1. 2. 3. 4. 5. MTL NO:Contents with "Order Information" in the specification. LOT NO:The production cycle of the product. BATCH:The CTR RANK of the product. Quantity:Product packaging quantity. Product Data: The data when product be made. Copyright© 2019 Orient .All rights Reserved 8 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 13.Reliability Test Copyright© 2019 Orient .All rights Reserved 9 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 14.Temperature Profile Of Soldering (1)IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (T Smin ) 150˚C - Temperature Max (T Smax ) 200˚C - Time (min to max) (ts) 90±30 sec Soldering zone - Temperature (TL ) 217˚C - Time (t L ) 60 sec Peak Temperature 260˚C Peak Temperature time 20 sec Ramp-up rate 3˚C / sec max. Ramp-down rate from peak temperature 3~6˚C / sec Reflow times ≤3 Copyright© 2019 Orient .All rights Reserved 10 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 (2).Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 25 to 140˚C Preheat time 30 to 80 sec (3).Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Copyright© 2019 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 11 V8 Shenzhen Orient Components Co ., Ltd OR-3H7 15.Characteristics Curve Copyright© 2019 Orient .All rights Reserved 12 V8 Shenzhen Orient Components Co ., Ltd Copyright© 2019 Orient .All rights Reserved 13 OR-3H7 V8 Shenzhen Orient Components Co ., Ltd Copyright© 2019 Orient .All rights Reserved 14 OR-3H7 V8
OR-3H7B-TP-G 价格&库存
很抱歉,暂时无法提供与“OR-3H7B-TP-G”相匹配的价格&库存,您可以联系我们找货
OR-3H7B-TP-G
    • 10+0.38481
    • 100+0.31223
    • 300+0.27486
    • 3000+0.23955
    • 6000+0.22886
    • 9000+0.22162
    库存:101082
    OR-3H7B-TP-G
      • 50+0.22310
      • 300+0.21530
      库存:13679
      OR-3H7B-TP-G
      • 1+0.21410
      • 50+0.20830
      • 300+0.20090
      库存:13679
      OR-3H7B-TP-G
      • 1+0.37950
      • 200+0.24530
      • 1500+0.21230
      • 3000+0.18810
      库存:13943
      OR-3H7B-TP-G
      • 10+0.35274
      • 100+0.28621
      • 600+0.25196
      • 1200+0.24818
      • 3000+0.21958
      • 30000+0.21738
      库存:49189
