FC-B1010RGBT-HG
FC-B1010RGBT-HG
    NATIONSTAR(国星光电)
    LED 三色 RGB 0404 共阳极 正贴
FC-B1010RGBT-HG 数据手册
表单编号:FGH/BD-0053.01-15A 佛山市国星 RGB 器件事业部 FOSHAN NATIONSTAR RGB DIVISION 产品规格书 S P E C I F I C AT I O N 顾客名称 产品名称 Customer Product 顾客型号 产品型号 Customer Type Type 顾客部品号 版本号 Customer No. Version NO Chip LED FC-B1010RGBT-HG C版 地址:广东省佛山市禅城区华宝南路 18 号 Add: NO.18 South Huabao Rd, Foshan, Guangdong, China 电话(Tel): 0757-83985605; 83985607; 82100231; 82100230 传真(Fax) : 0757-82100223;82100200 邮编(Zip) :528000 http://www.nationstar.com 制 定 DRAW 研 发 中 心 客户(加盖公章) Research & Development Center Customer(Stamp) 审 核 CHECK 批 准 APPROVE 确 认 CONFIRM 发放日期 (Release Date):2020-06-05 保存期限:长期 表单编号:FGH/BD-0053.01-15A 片式彩色发光二极管 FC-B1010RGBT-HG Chip Full-color LED 技术数据表 Technical Data Sheet 本产品属于表面贴装全彩器件,采用全黑框架,对比度高,黑色哑光封装,无镜面反射。 拥有高可靠性、长寿命、宽视角等特点,是户内显示装饰领域的理想选择。 These products are full-color SMD components with black frame, high contrast , black and matt packaging and non-mirror reflection, which are featured by good reliability, long lifespan and wide viewing angle.They are designed for indoor display and decoration applications. 特性:  管芯材料: Material: 红色 Red AlGaInP 绿色 Green InGaN 蓝色 Blue InGaN Features: 封装材料:环氧树脂 Encapsulation: Epoxy Resin 焊接方法:无铅回流焊 Soldering methods: Pb-Free reflow soldering 光强高,功耗低,可靠性好,寿命长 High Luminous Intensity ,Low Power Dissipation, Good Reliability and Long Lifespan  符合欧盟公布的 ROHS 指令要求 Complied With ROHS Directive 目录 Catalogue 电性参数 Electrical Characteristics.............................................................................................................................2 典型特性曲线 Typical Characteristic Curves.....................................................................................................................3 可靠性实验 Reliability Test Items and Conditions........................................................................................................4 外形尺寸 Outline Dimensions......................................................................................................................................5 包装 Packaging......................................................................................................................................................6 焊接指导 Guideline for Soldering................................................................................................................................8 使用注意事项 Precautions....................................................................................................................................................10 * 产品规格如因工艺改进而有所改变,恕不另行通知。 * The specifications of the product may be modified for improvement without notice. 发放日期:20200605TYBC 1 / 13 保存期限:长期 表单编号:FGH/BD-0053.01-15A 片式彩色发光二极管 光电参数 Electro-Optical Characteristics  极限参数(温度=25℃) Absolute Maximum Ratings (Temperature=25°C) 参数名称 Parameter 符号 Symbol 数值 Rating 单位 Unit 正向电流 Forward Current IF 10 mA 正向脉冲电流* Pulse Forward Current* 红 Red 50 绿 Green IFP 蓝 Blue 40 反向电压 Reverse Voltage 工作温度 Operating Temperature 贮存温度 Storage Temperature VR 5 V Tamb -30 ~ +85 ℃ Tstg -40 ~ +100 ℃ 红 Red 功耗 Power Dissipation 24 绿 Green 32 Ptot 蓝 Blue  mA 40 mW 32 光电参数(温度=25℃) Electro-Optical Characteristics (Temperature=25°C) 参数名称 Parameter 符号 Symbol 条件 Condition 反向电流 Reverse Current IR VR=5 正向电压 Forward Voltage VF 主波长 Dominant Wavelength λD 半波宽度 Spectrum Radiation Bandwidth Δλ 光强 Luminous Intensity IV 视角度 View Angle 颜色 Color 最小值 Min. 典型值 Typ. 红 Red 绿 Green 蓝 Blue 最大值 Max. 单位 Unit 10 10 10 μA IF=5mA IF=2mA IF=2mA IF=5mA IF=2mA IF=2mA IF=5mA IF=2mA IF=2mA IF=5mA 红 Red 1.6 2.0 2.4 绿 Green 2.2 2.6 3.2 蓝 Blue 2.3 2.7 3.2 红 Red 610 620 630 绿 Green 520 530 545 蓝 Blue 460 470 480 红 Red 12 20 35 IF=2mA 绿 Green 15 30 55 IF=2mA 蓝 Blue 3 5 10 红 Red 24 绿 Green 38 蓝 Blue 28 2θ1/2 120 V nm nm mcd deg. * 注:以上参数仅供参考,请以实物标签为准。我司给出的参数均由国星测试系统测得。 * Note: The parameters above only for your reference. In case of any discrepancy, please adhere to the label of our actual products. All parameters tested by the standard testing system of NationStar. 发放日期:20200605TYBC 2 / 13 保存期限:长期 表单编号:FGH/BD-0053.01-15A 片式彩色发光二极管 典型特性曲线 Typical Characteristics Curves 伏安特性 相对光强与正向电流特性 Volt-Ampere Characteristics Relative Luminous Intensity VS Forward Current 1 Blue 1.5 2 2.5 正向电压 (F orward Voltage )(V ) 3 3.5 7 6 5 4 3 Red 0 10 15 20 25 光强与环境温度曲线 正向电流降额曲线 Luminous Intensity VS Ambient Temperature 1. 5 0 5 Blue 1.2 1.0 Red 0 0.2 0.4 0.6 0.8 Blue Green 350 400 450 500 550 600 650 700 750 1. 0 Green -40 -20 0 20 40 60 环境温度(Ambient Temperature )(℃) a .u .) 光谱分布特性曲线 R elative Spectral Dis tribution 相 对 光 强( R ela ti ve Lu mi n ou s In t en si ty ) ( a . u. ) 环境温度(Ambient Temperature )(℃) Blue 0 .5 10 15 Red Red 0 相对光强(Relative Luminous Intensity) 40 35 30 25 20 Green 0 10 20 30 40 50 60 70 80 90 100 相 对 光 强( Rel ati v e Lu m in o u s In ten s ity ) ( 5 正向电流(Forward Current )(mA ) Forward Current Derating Curve 正向电流(Forward Current)(mA) Blue 2 Green Green 1 10 Red TAmbient =25℃ 0 正向电流(Forward Current)(mA) 100 相对光强(Relative Luminous Intensity)(a. u.) TAmbient =25℃ 80 光强分布特性曲线 Typical Spatial Distribution 0° 1 10° 20° 30° 40° 50° 60° 0.5 70° 80° 90° 0 -90 °-80°-70°-60°-50°-40°-30°-20°-10° 0 0.5 1 角度(Angle )(Deg .) 波长(Wavelength )(nm ) 发放日期:20200605TYBC 3 / 13 保存期限:长期 表单编号:FGH/BD-0053.01-15A 片式彩色发光二极管 可靠性试验 Reliability Test Items and Conditions 实验项目 Test Items 参考标准 Reference 实验条件 Test Conditions 时间 Time 样品数 Quantity 合格判据 Criterion 双 85 储存继之耐焊接热继 之冷热冲击 Thermal shock after 85℃ /85%RH storage and solder heat JEITA ED-4701 100 103 GB/T 4937,Ⅱ,2.2&2.3 MIL-STD-202G Ta=85℃,RH=85% Tsol*=260℃ 10sec. -40℃(30min)←→100℃ (30min) 24h 3次 3 times 循环 100 次 100 cycles 100 pcs 零失效,零剥离 No failure and no stripping 高压蒸汽 High-pressure steam Q/DGE 23-2018 ,*D9e Temperature:121℃ Pressure:2×105 Pa Time:8h 循环 2 次 2 cycles 100 pcs 零失效,零剥离 No failure and no stripping 贴板后高温高湿反压测试 High temperature high humidity reverse bias after soldering FGM/GL-0603, IE JEITA ED-4701 100 103 Tsol*=260℃ 10sec. Ta=85℃,RH=85%,VR=7V 1次 1 times 168h 100 pcs 零失效,零暗灯 No failure and no dim light MSL 3 级 MSL level 3 J-STD-020D 192h 3次 3 times 100 pcs 零失效,零剥离 No failure and no stripping 常温寿命试验 Normal temperature lifespan test JESD22-A108D Ta=25℃ IF =IFT 1000h 20 pcs 见下表 See Table below 高温高湿寿命 High temperature high humidity lifespan test JEITA ED-4701 100 103 JESD22-A108D Ta=85℃,RH=85% IFR =5mA 168h 20 pcs 见下表 See Table below 寿命试验合格判断标准 测试项目 Ta=30℃,RH=60% Tsol*=260℃ 10sec. Criteria For Passing Qualification Of Lifespan Test 符号 测试条件 判定标准 Symbol Test Conditions Criteria For Judging Damage 正向电压 Forward Voltage VF IF= IFT 初始值±10% Initial Data±10% 反向电流 Reverse Current IR VR= 5V IR≤10μA IF = IFT 平均 IV 衰减≤30%,单个 IV 衰减≤50% Average IV degradation≤30%; Single LED IV degradation≤50% Test Items 光强 Luminous Intensity IV * 注:Tsol-锡液温度;IFT:典型电流 * Note: Tsol-Temperature of tin liquid; IFT:Typical current. 发放日期:20200605TYBC 4 / 13 保存期限:长期 表单编号:FGH/BD-0053.01-15A 片式彩色发光二极管 外形尺寸 Outline Dimension ④B- ①+ B G ③G- R ②R- ①+ ④B- ③G- ②R- ④ 推荐焊盘尺寸 Recommended Soldering Pad B 敷铜区域: ③ Cuprum Area: G ② ① R *无特别规定时,公差:X.X±0.1,X.XX±0.05,单位为mm* * The Tolerances Unless Mentioned is :X.X±0.1,X.XX±0.05,Unit= mm* 发放日期:20200605TYBC 5 / 13 保存期限:长期 表单编号:FGH/BD-0053.01-15A 片式彩色发光二极管 包装(1) Packaging (1) 载带 Carrier Tape 单位:mm,未注公差:±0.1 mm All dimensions in mm, tolerances unless mentioned is ±0.1 mm.  编带细节 Details Of Carrier Tape  前进方向Progressive Direction A:引导,空带,300mm;B:编载产品 17000 只;C:尾部,空带,100mm A: Leader, Empty, 300mm; B:17000 Lamps Loaded; C: Trailer, Empty, 100mm.   带盘 Reel Dimension 前进方向Progressive Direction   二维码 Qr code CHIP LED TYPE: XX-XXXXX-XX R G B IF(mA) : ( x ) ( x ) ( x ) λd(nm): ( xxx-xxx) ( xxx-xxx) ( xxx-xxx) BIN: XXX IV(mcd): ( xx-xx) ( xx-xx) ( xx-xx) QTY: XXXX SC: XXX VF(V): ( xx-xx) ( xx-xx) ( xx-xx) QC LOT:XXXXX QC: PASS FOSHAN NATIONSTAR OPTOELECTRONICS CO., LTD 佛山市国星光电股份有限公司 发放日期:20200605TYBC 6 / 13 保存期限:长期 表单编号:FGH/BD-0053.01-15A 片式彩色发光二极管 包装(2) Packaging( 2) 防潮抗静电包装 Moisture Proof and Anti-Electrostatic Foil Bag 标签 Label 防潮抗静电包装袋 Moisture Proof and Anti-Electrostatic Foil Bag 外包装箱 干燥剂 密封 标签 Moisture Absorbent Material Sealed Label Cardboard Box 二维码 Qr code CHIP LED TYPE: XX-XXXXX-XX R G B IF(mA) : ( x ) ( x ) ( x ) λd(nm): ( xxx-xxx) ( xxx-xxx) ( xxx-xxx) BIN: XXX IV(mcd): ( xx-xx) ( xx-xx) ( xx-xx) QTY: XXXX SC: XXX VF(V): ( xx-xx) ( xx-xx) ( xx-xx) QC QC: LOT:XXXXX PASS FOSHAN NATIONSTAR OPTOELECTRONICS CO., LTD 佛山市国星光电股份有限公司 佛山市国星光电股份有限公司 FOSHAN NATIONSTAR OPTOELECTRONICS CO.,LTD 地址:佛山市禅城区华宝南路18号 TEL:(86-757)83980208 邮编:528000 FAX:(86-757)82100206 标签说明 Label Explanation TYPE:产品型号 QTY:数量 BIN:分档 Quantity Rank SC:分档编号 LOT:批号 IV:光强范围 Step Code IF:测试电流 QTY: XXXX BIN: SC: Wavelength Range XXX XXX LOT: XXXXXXXX XXXX Luminous Intensity Range VF:正向电压范围 XXXX TYPE: XX-XXXXX-XX Lot Number λd:波长范围 二维码 Qr code CHIP LED IV(mcd) λd(nm) VF(V) IF(mA) R:( xxx-xxx) ( xxx-xxx) ( xx-xx) ( xx) G:( xxx-xxx) ( xxx-xxx) ( xx-xx) ( xx) B:( xxx-xxx) ( xxx-xxx) ( xx-xx) ( xx) QC QC: PASS FOSHAN NATIONSTAR OPTOELECTRONICS CO., LTD 佛山市国星光电股份有限公司 Forward Voltage Range Testing Current 发放日期:20200605TYBC 7 / 13 保存期限:长期 表单编号:FGH/BD-0053.01-15A 片式彩色发光二极管 焊接指导(1) Guideline for Soldering (1) 1. 使用烙铁人手焊接 Hand Soldering 推荐使用功率低于 20W 的烙铁,焊接时烙铁的温度必须保持在 360℃ 以下,且每个电极只能进行一次焊 接,每次焊接的持续时间不得超过 3 秒。 人手焊接过程中的不慎操作易引起 LED 产品的损坏,应当小心谨慎。 If manual soldering is necessary used, the power of less than 20W is recommended. The temperature of the iron must be kept at below 360ºC, with soldering time within 3 seconds and each electrode can be only soldered at one time. No stress should be exerted on the resin portion of the SMD LED during soldering. 2. 回流焊接:推荐使用以下无铅回流焊接温度图进行。 Reflow Soldering: Use the conditions shown in the under Figure of Pb-Free Reflow Soldering. · 回流焊接最多只能进行两次。 Reflow soldering should not be done more than two times. · 在回流焊接升温过程中,请不要对 LED 施加任何压力。 No stress should be exerted on the package during the ramp-up progress of the soldering. · 在焊接完成后,待产品温度下降到室温之后,再进行其他处理。 After soldering, do not deal with the product before its temperature cooling down to room temperature. 发放日期:20200605TYBC 8 / 13 保存期限:长期 表单编号:FGH/BD-0053.01-15A 片式彩色发光二极管 焊接指导(2) Guideline for Soldering (2) 3.清洗 Cleaning 在焊接后推荐使用酒精(无水乙醇)进行清洗,在温度不高于 30℃的条件下持续 3 分钟,不高于 50℃的 条件下持续 30 秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部分造成损 伤。 超声波清洗也是有效的方法,一般最大功率不应超过 300W,否则可能对 LED 造成损伤。请根据具体的 情况预先测试清洗条件是否会对 LED 造成损伤。 It is recommended that alcohol(Anhydrous ethanol)be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for 3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the solvents will dissolve the package and the resin or not. Ultrasonic cleaning is also an effective way for cleaning. The influence of Ultrasonic cleaning on LED depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W, otherwise it will cause LED damage. Before cleaning, a pre-test should be done to confirm if any damage to LEDs will occur. * 注意:此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响, 请根据特定的PCB设计和焊接设备来确定焊接方案。 * Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment. The technique in practice is influenced by many factors. Thus, the soldering methods should be specific base on the PCB designs and configurations of the soldering equipment. 发放日期:20200605TYBC 9 / 13 保存期限:长期 表单编号:FGH/BD-0053.01-15A 片式彩色发光二极管 使用注意事项(1) Precautions (1) 1. 贮存: Storage · 产品在运输和储存中要注意防潮,需使用密封防潮抗静电袋包装,并内附干燥剂、湿度卡,湿度卡可显示 防静电铝箔袋内的湿度。 In order to prevent moisture absorption into the SMD LEDs during the transportation and storage, the LEDs should be packed in the moisture proof and anti-electrostatic sealed foil bag. Desiccants and a humidity indicator are packed together with the SMD LEDs as secondary protection. The humidity-indicator card indicates the humidity of the inside of the foil bag. · 开封前,产品须存放在温度不高于 30℃,湿度不高于 60%RH 的环境中,要求所有产品上线前均按要求进 行烘烤除湿。 All the products should be stored in the environment of temperature
FC-B1010RGBT-HG 价格&库存
很抱歉,暂时无法提供与“FC-B1010RGBT-HG”相匹配的价格&库存,您可以联系我们找货
FC-B1010RGBT-HG
  • 10+0.22520
  • 100+0.16850
  • 2000+0.13060
  • 17000+0.09460
  • 34000+0.08990
  • 170000+0.08330
库存:48661
FC-B1010RGBT-HG
  • 1+0.09700
  • 41000+0.08430
库存:32395
FC-B1010RGBT-HG
  • 20+0.14909
  • 4100+0.09712
  • 16400+0.06881
  • 41000+0.06812
库存:48661
FC-B1010RGBT-HG
  • 20+0.16265
  • 200+0.13263
  • 600+0.11600
  • 2000+0.10595
  • 10000+0.07982
  • 20000+0.07506
库存:68300
