Revision: A
Date: 2018-04-24 Page
No.: 1 OF 1
PPTC RESETTALBE
电路保护元器件专业制造商
FUSES
FSMD0603 Series
Features
Applications
◆ Surface Mount Devices
◆ Standard 0603mils footprint
◆ Surface mount packaging for automated assembly
◆ Compatible with Pb and Pb-free solder re flow profiles
◆ UL(Pending), C-UL(Pending), TUV(Pending)
◆ RoHS, Reach, HF compliance
◆ Mobile phones
◆ PC motherboards
◆ P DA’s/Digital cameras
◆ USB port protection
◆ HDMI source protection
电气特性:
P/N
保持电流
跳脱电流
最大电压
最大电流
最大动作时间
消耗功率
电阻范围(Ω)
IH, (A)
IT, (A)
V max, (V)
I max, (A)
(A)
(Sec.)
Pd typ, (W)
R min,
R1 max,
TLC-FSMD010
0.10
0.30
15
40
0.50
1.00
0.50
0.90
6.00
TLC-FSMD020
0.20
0.50
9
40
1.00
0.60
0.50
0.55
3.50
TLC-FSMD035
0.35
0.75
6
40
8.00
0.10
0.50
0.20
1.40
TLC-FSMD050
0.50
1.00
6
40
8.00
0.10
0.50
0.10
0.80
产品尺寸 (Unit: mm) :
Top and Bottom View
Side View
A
I
C
B
D
A
B
C
D
P/N
Marking
(标识)
Min.
Max.
Min.
Max.
Min.
Max.
Min.
TLC-FSMD010
I
1.45
1.85
0.65
1.05
0.35
0.85
0.20
TLC-FSMD020
1.45
1.85
0.65
1.05
0.30
0.75
0.20
TLC-FSMD035
II
1.45
1.85
0.65
1.05
0.30
0.75
0.20
TLC-FSMD050
1.45
1.85
0.65
1.05
0.60
1.00
0.20
I
Part Identification
环境温度与工作电流关系特性曲线 :
P/N
工作环境温度
-40℃
-20℃
0℃
25℃
40℃
50℃
60℃
70℃
85℃
TLC-FSMD010
0.13
0.12
0.11
0.10
0.08
0.07
0.06
0.05
0.03
TLC-FSMD020
0.27
0.25
0.23
0.20
0.17
0.14
0.12
0.10
0.07
TLC-FSMD035
0.47
0.41
0.38
0.35
0.29
0.26
0.24
0.20
0.14
TLC-FSMD050
0.67
0.59
0.54
0.50
0.41
0.37
0.34
0.29
0.20
TEL: 86-0769-3892 0554
FAX: 86-0769-8793 2077
E-mail:sales@tlcet.com.cn
Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710
PPTC RESETTALBE
FUSES
电路保护元器件专业制造商
Revision: A
No.: 1 OF 2
FSMD0603 Series
动作电流时间曲线表 :
The Time to Trip curves represent typical performance
of a device in a simulated application environment.
Actual performance in specific customer applications
may differ from these values due to the influence of
other variables.
标准包装数量 :
Model
Q’t y/Reel
TLC-FSMD010~TLC-FSMD035
5000pcs
TLC-FSMD050
4000pcs
Note: Reel packaging per EIA-481-1 standard
6、Agency Recognition:
Caution:Operation beyond the rated voltage or current may result in rupture electrical arcing or flame.Specifications are
subject to change without notice.
很抱歉,暂时无法提供与“TLC-FSMD010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15001
- 100+0.14001
- 300+0.13001
- 500+0.12001
- 2000+0.11501
- 5000+0.11201
