5Φ SERIES
Metal Oxide Varistor (MOV) Data Sheet
Features
Wide operating voltage (V1mA) range from 18V to 750V
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
■ Operating Temperature:-40℃ ~ +105℃
■ Storage Temperature:-40℃ ~ +125℃
■ Safety certification: UL: E327997
CSA: 246579
VDE: 40027827
Applications
Transistor, diode, IC, thyristor or triac semiconductor protection
Surge protection in consumer electronics
Surge protection in industrial electronics
Surge protection in electronic home appliances, gas and petroleum appliances
Relay and electromagnetic valve surge absorption
Part Number Code
Packing
No suffix: Bulk
TB: Tape & Box
TR: Tape & Reel
Tolerance
K: ±10%
Type
D: Disk
Varistor Voltage
180: 18V
101: 100V
102: 1000V
Revision: MOV-5Φ SERIES-001(A4)
Surge Series
No suffix: Standard type
J: High Surge type
Lead Shape
No suffix: Straight leads
O: Outside crimped leads
F: Y Kinked leads
Element Diameter
05~53
2 / 13
http://brightking.pulseelectronics.com
5Φ SERIES
Dimensions
D
D
T
H1
K≤3.0
F
e
d
L1
d1
L1
L
K≤3.0
d
T
H1
H
D
d
F
O Type
F Type
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H
5.5~10.0
180K
1.5~4.5
1.3
221K
2.0~4.5
1.9
H1
8.0~13.0
220K
1.6~4.6
1.4
241K
2.1~4.6
2.0
L(min.)
20.0
270K
1.6~4.7
1.6
271K
2.1~4.9
2.2
L1(min.)
15.0
330K
1.7~4.9
1.5
301K
2.2~5.0
2.3
D
5.0~7.5
390K
1.6~4.8
1.6
331K
2.2~5.1
2.3
F(±0.8)
5.0
470K
1.7~4.9
1.7
361K
2.4~5.2
2.5
T
Table 2
560K
1.8~5.0
1.9
391K
2.5~5.4
2.6
e(±0.8)
Table 2
680K
1.9~5.2
2.2
431K
2.7~5.7
2.8
d(±0.05)
0.6
820K
1.6~4.1
1.6
471K
2.8~6.0
3.0
d1(±0.4)
1.2
101K
1.9~4.3
1.8
511K
2.9~6.2
3.2
121K
1.9~4.5
2.0
561K
3.1~6.5
3.4
151K
1.7~4.8
1.6
621K
3.3~6.5
3.7
181K
1.8~4.3
1.7
681K
3.5~6.8
4.0
201K
1.9~4.4
1.8
751K
3.8~6.9
4.1
3 / 13
5Φ SERIES
Electrical Characteristics
Part
Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
Standard
High
Surge
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
(J)
High
Surge
(W)
@1KHz (pf)
180KD05
180KD05J
11
14
18(15~21.6)
1
40
100
250
0.4
0.6
0.01
1400
220KD05
220KD05J
14
18
22(19.5~26)
1
48
100
250
0.5
0.7
0.01
1150
270KD05
270KD05J
17
22
27(24~31)
1
60
100
250
0.6
0.9
0.01
930
330KD05
330KD05J
33(29.5~36.5)
1
73
100
250
0.8
1.1
0.01
760
390KD05
390KD05J
25
31
39(35~43)
1
80
100
250
0.9
1.2
0.01
640
470KD05
470KD05J
30
38
47(42~52)
1
104
100
250
1.1
1.5
0.01
530
560KD05
560KD05J
35
45
56(50~62)
1
123
100
250
1.3
1.8
0.01
450
680KD05
680KD05J
40
56
68(61~75)
1
145
100
250
1.6
2.2
0.01
370
820KD05
820KD05J
50
65
82(74~90)
5
150
400
800
2.5
4.0
0.1
300
101KD05
101KD05J
60
85
100(90~110)
5
177
400
800
3.0
4.1
0.1
250
121KD05
121KD05J
75
100
120(108~132)
5
210
400
800
4.0
4.9
0.1
210
151KD05
151KD05J
95
125
150(135~165)
5
260
400
800
4.1
6.5
0.1
165
181KD05
181KD05J
115
150
180(162~198)
5
320
400
800
4.9
7.5
0.1
140
201KD05
201KD05J
130
170
200(180~220)
5
355
400
800
6.5
8.5
0.1
125
221KD05
221KD05J
140
180
220(198~242)
5
380
400
800
7.5
9.0
0.1
110
241KD05
241KD05J
150
200
240(216~264)
5
415
400
800
8.0
10.5
0.1
100
271KD05
271KD05J
175
225
270(243~297)
5
475
400
800
8.5
11.0
0.1
95
301KD05
301KD05J
190
250
300(270~330)
5
520
400
800
9.0
12.0
0.1
85
331KD05
331KD05J
210
275
330(297~363)
5
570
400
800
9.5
13.0
0.1
75
361KD05
361KD05J
230
300
360(324~396)
5
620
400
800
10.0
16.0
0.1
70
391KD05
391KD05J
250
320
390(351~429)
5
675
400
800
12.0
17.0
0.1
65
431KD05
431KD05J
275
350
430(387~473)
5
745
400
800
13.0
20.0
0.1
60
471KD05
471KD05J
300
385
470(423~517)
5
810
400
800
15.0
21.0
0.1
55
511KD05
511KD05J
320
415
510(459~561)
5
845
400
800
16.0
22.5
0.1
50
561KD05
561KD05J
350
460
560(504~616)
5
920
400
800
16.8
24.0
0.1
45
621KD05
621KD05J
385
505
620(558~682)
5
1025
400
800
17.7
25.0
0.1
40
681KD05
681KD05J
420
560
680(612~748)
5
1120
400
800
21.0
29.0
0.1
35
751KD05
751KD05J
460
615
750(675~825)
5
1240
400
800
22.4
32.0
0.1
30
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K)
IR≤25μA (820K~751K)
4 / 13
5Φ SERIES
Electrical Ratings
Items
Varistor Voltage
Maximum Allowable
Voltage
Test Condition/Description
Requirement
The voltage between the two terminals with the specified measuring
current 1mA.DC applied is called Vb.
The recommended maximum sine wave voltage (RMS) or the
Maximum DC voltage can be applied continuously.
The maximum voltage between the two terminals with the
specification standard impulse current.
Applied waveform: 8/20μs
Crest value
100
90
Current (%)
Maximum Clamping
Voltage
To meet the
50
Specified value
20µs
10
8µs
Time
Impulse Width
Rated Wattage
Energy
Withstanding Surge
Current
The maximum average power that can be applied within the
specified ambient temperature.
The maximum energy within the varistor voltage change of ±10%
when one impulse of 10/1000μs or 2ms is applied.
The maximum current within the varistor voltage change of ±10%
with the standard impulse current (8/20μs) applied one time.
V1mA@105℃-V1mA@25℃
V1mA@25℃
Varistor Voltage
1
× 100%(%/℃)
80
≤0.05%/℃
Temp. Coefficient
V1mA@-40℃-V1mA@25℃
V1mA@25℃
1
× 100%(%/℃)
65
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
Surge Life
180K to 680K
10A (8/20μs)
820K to 751K
20A (8/20μs)
5Φ series
5 / 13
5Φ SERIES
Part
Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
Standard
High
Surge
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
(J)
High
Surge
(W)
@1KHz (pf)
180KD05
180KD05J
11
14
18(15~21.6)
1
40
100
250
0.4
0.6
0.01
1400
220KD05
220KD05J
14
18
22(19.5~26)
1
48
100
250
0.5
0.7
0.01
1150
270KD05
270KD05J
17
22
27(24~31)
1
60
100
250
0.6
0.9
0.01
930
330KD05
330KD05J
33(29.5~36.5)
1
73
100
250
0.8
1.1
0.01
760
390KD05
390KD05J
25
31
39(35~43)
1
80
100
250
0.9
1.2
0.01
640
470KD05
470KD05J
30
38
47(42~52)
1
104
100
250
1.1
1.5
0.01
530
560KD05
560KD05J
35
45
56(50~62)
1
123
100
250
1.3
1.8
0.01
450
680KD05
680KD05J
40
56
68(61~75)
1
145
100
250
1.6
2.2
0.01
370
820KD05
820KD05J
50
65
82(74~90)
5
150
400
800
2.5
4.0
0.1
300
101KD05
101KD05J
60
85
100(90~110)
5
177
400
800
3.0
4.1
0.1
250
121KD05
121KD05J
75
100
120(108~132)
5
210
400
800
4.0
4.9
0.1
210
151KD05
151KD05J
95
125
150(135~165)
5
260
400
800
4.1
6.5
0.1
165
181KD05
181KD05J
115
150
180(162~198)
5
320
400
800
4.9
7.5
0.1
140
201KD05
201KD05J
130
170
200(180~220)
5
355
400
800
6.5
8.5
0.1
125
221KD05
221KD05J
140
180
220(198~242)
5
380
400
800
7.5
9.0
0.1
110
241KD05
241KD05J
150
200
240(216~264)
5
415
400
800
8.0
10.5
0.1
100
271KD05
271KD05J
175
225
270(243~297)
5
475
400
800
8.5
11.0
0.1
95
301KD05
301KD05J
190
250
300(270~330)
5
520
400
800
9.0
12.0
0.1
85
331KD05
331KD05J
210
275
330(297~363)
5
570
400
800
9.5
13.0
0.1
75
361KD05
361KD05J
230
300
360(324~396)
5
620
400
800
10.0
16.0
0.1
70
391KD05
391KD05J
250
320
390(351~429)
5
675
400
800
12.0
17.0
0.1
65
431KD05
431KD05J
275
350
430(387~473)
5
745
400
800
13.0
20.0
0.1
60
471KD05
471KD05J
300
385
470(423~517)
5
810
400
800
15.0
21.0
0.1
55
511KD05
511KD05J
320
415
510(459~561)
5
845
400
800
16.0
22.5
0.1
50
561KD05
561KD05J
350
460
560(504~616)
5
920
400
800
16.8
24.0
0.1
45
621KD05
621KD05J
385
505
620(558~682)
5
1025
400
800
17.7
25.0
0.1
40
681KD05
681KD05J
420
560
680(612~748)
5
1120
400
800
21.0
29.0
0.1
35
751KD05
751KD05J
460
615
750(675~825)
5
1240
400
800
22.4
32.0
0.1
30
IR≤25μA (820K~751K)
6 / 13
5Φ SERIES
Soldering Recommendation
Lead-free Wave Soldering Recommendation
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
7 / 13
5Φ SERIES
Mechanical Characteristics
Items
Test conditions / Methods
Specifications
Gradually applying the force specified and keeping the unit
fixed for 10±1 sec.
Tensile Strength
of Terminals
Bending Strength
of Terminals
Vibration
Terminal diameter (mm)
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
1.0
2.0
4.0
Hold specimen and apply the force specified below to each
lead. Bend the specimen to 90°, then return to the original
position. Repeat the procedure in the opposite direction.
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
0.5
1.0
2.0
Frequency range: 10~55 Hz
2
Amplitude: 0.75mm or 98m/s
Direction: 3 mutually perpendicular directions, 2hrs each.
No visible damage
| V1mA/V1mA |≤5%
No visible damage
| V1mA/V1mA |≤5%
No visible damage
| V1mA/V1mA |≤5%
Solder ability
Solder Temp: 245±5℃
Dipping Time: 2±0.5 sec
At least 95% of terminal
electrode is covered by
new solder
Resistance to
Soldering Heat
Solder Temp: 260±5℃
Dipping Time: 10±1 sec
No visible damage
| V1mA/V1mA |≤10%
Reliability
Items
Specifications
High Temperature
Storage
Ambient Temp: 125±2℃
Duration: 1000hrs
| V1mA/V1mA |≤5%
Low Temperature
Storage
Ambient Temp: -40±2℃
Duration: 1000hrs
| V1mA/V1mA |≤5%
Ambient Temp: 40±2℃, 90~95% R.H.
Duration: 1000hrs
| V1mA/V1mA |≤5%
Humidity
The conditions shown below shall be repeated 5 cycles
Step
Temperature (℃)
Period (minutes)
1
-40±3
30±3
2
Room temperature
15±3
3
125±3
30±3
4
Room temperature
15±3
Temperature Cycle
No visible damage
| V1mA/V1mA |≤5%
High Temperature
Load
Ambient Temp: 105±2℃
Duration: 1000hrs
Load: Max. Allowable Voltage In AC eara.
| V1mA/V1mA|≤10%
Damp Heat Load
Duration: 1000hrs
Load: Max. Allowable Voltage.
No visible damage
| V1mA/V1mA |≤10%
Metal balls method, 2500Vac 1 min.
No visible damage
Voltage Proof
8 / 13
5Φ SERIES
Maximum Surge Current Derating Curve
820KD05 to 751KD05
10000
1000
1000
100
10
Max. Surge Current (A)
180KD05 to 680KD05
10000
1
2
10
102
103
1045
10
106
1
1
2
100
10
10
1023
10
1045
106
10
1
0.1
10
100
1000
0.1
10
10000
100
Td (μs)
1000
1000
10000
1
2
10
10
102
103
1045
10
106
1
0.1
10
10000
820KD05J to 751KD05J
180KD05J to 680KD05J
10000
100
1000
Td (μs)
100
10
1
2
10
102
103
104
105
106
1
100
1000
10000
0.1
10
Td (μs)
100
1000
10000
Td (μs)
9 / 13
5Φ SERIES
Maximum Leakage Current and Maximum Clamping Voltage Curve
10 / 13
5Φ SERIES
11 / 13
5Φ SERIES
Marking Code
① Brightking Logo
② Varistor Voltage
③ UL Accreditation Logo
①
XXXKDXXX
③
XXX Y
④
④ VDE Accreditation Logo
⑤
⑥
②
⑤“J”is High Surge Code, no“J”is Standard Surge
⑦
⑥ Disk Size
VDE
⑦ Internal control code
Taping Dimensions
P2
P
h
B
W2
W0
W
H
D0
I
P1
P0
F
Symbol
Dimension (mm)
P
12.7±1.0
P0
12.7±0.3
P1
3.85±0.7
P2
6.35±1.3
F
5.0±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H
20.0±2.0
I
1.0max
D0
4.0±0.2
t
0.6±0.3
B
32max
W1
t
12 / 13
5Φ SERIES
Quantity
Packaging Dimensions (Unit: mm)
Quantity
In bulk for Terminals Untrimmed Products
5M
ax
1000pcs/bag
4bags/box
16
130 Max.
250 Max.
In bulk for Terminals Trimmed Products
ax
1000pcs/bag
0M
4bags/box
16
66 Max.
252 Max.
Tape & Box
ax
1500pcs/box
(180K~391K)
0M
1000pcs/box
(431K~751K)
25
60 Max.
340 Max.
Tape & Reel
5M
ax
2000pcs/reel
(180K~391K)
36
60 Max.
365 Max.
55 Max.
1500pcs/reel
(431K~751K)
30±1
Φ365 Max.
13 / 13
很抱歉,暂时无法提供与“180KD05J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.33440
- 50+0.19690
- 1000+0.17600
- 国内价格
- 10+0.39689
- 100+0.31452
- 200+0.30980
- 400+0.30670
- 1000+0.30057
