SL32 THRU SL310
Reverse Voltage - 20 to 100 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER DIODES
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.051 (1.30)
0.177(4.50)
0.157(3.99)
High forward surge current capability
0.012(0.305)
0.006(0.152)
High temperature soldering guaranteed:
260°C/10 seconds at terminals
0.096(2.42)
0.078(1.98)
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
Mechanical Data
0.208(5.30)
0.188(4.80)
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002ounce, 0.07 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
VRRM
VRMS
VDC
MDD
SL33
MDD
SL34
MDD
SL35
MDD
SL36
MDD
SL38
MDD
SL310
UNITS
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
V
V
V
I(AV)
3.0
A
IFSM
70
A
Maximum instantaneous forward voltage at 3.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
IR
TA=25℃
TA=125℃
MDD
SL32
Typical junction capacitance (NOTE 1)
CJ
Typical thermal resistance (NOTE 2)
Operating junction temperature range
RJA
Operating storage temperature range
TSTG
TJ
0.45
0.5
20.0
500
V
0.70
0.2
10.0
0.50
mA
pF
300
℃/W
75.0
-55 to +150
-55 to+125
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0x2.0”(5.0x5.0cm) copper pad areas.
http://www.microdiode.com
Rev:2024A2
Page :1
SL32 THRU SL310
FIG. 1- FORWARD CURRENT DERATING CURVE
3.0
P.C.B mounted on
2.0*2.0"(5.0*5.0cm)
copper pad areas
2.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.8
1.2
SL32-SL36
SL38-SL310
0.6
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
70
56
42
28
14
175
8.3ms SINGLE HALF SINE-WAVE
1
10
LEAD TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
50
100
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
CURRENT,AMPERES
TJ=25 C
10.0
1
SL32-SL34
SL35-SL36
SL38-SL310
0.1
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.01
100
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
0.9
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
2000
1000
TJ=25 C
100
SL32-SL34
SL35-SL310
TRANSIENT THERMAL IMPEDANCE,
C/W
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A2
Page :2
SL32 THRU SL310
Packing information
unit:mm
P0
P1
d
Item
E
F
B
A
W
P
D2
D1
T
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
Symbol
Tolerance
SMA
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
2,000
4.0
4,000
183*155*183
178
CARTON
SIZE
(m/m)
CARTON
(pcs)
80,000
APPROX.
GROSS WEIGHT
(kg)
12.0
SMA
7"
SMA
11"
5,000
4.0
10,000
290*290*38
330
310*310*360
80,000
11.0
SMA
13"
7,500
4.0
15,000
335*335*38
330
350*330*360
120,000
14.5
382*356*392
Suggested Pad Layout
Symbol
Unit (mm)
A
1.68
Unit (inch)
0.066
B
1.52
0.060
C
3.93
0.154
D
2.41
0.095
E
5.45
0.215
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SL34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.45770
- 100+0.37326
- 300+0.33094
- 1000+0.29930
- 5000+0.21088
- 10000+0.19821
- 国内价格
- 10+0.40890
- 100+0.33149
- 1000+0.26370
- 2000+0.25974
- 5000+0.18265
