79L15
SOT-89 Plastic-Encapsulate Voltage Regulators
79L15
SOT-89-3L
Three-terminal positive voltage regulator
FEATURES
z
z
z
1. GND
Maximum output current
IOM: 0.1A
Output voltage
V O: -15V
Continuous total dissipation
PD: 0.6 W (Ta= 25 ℃ )
2. IN
3. OUT
ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Symbol
Value
Unit
Vi
-30
V
Thermal Resistance from Junction to Ambient
RθJA
208.3
℃/W
Operating Junction Temperature Range
TOPR
0~+150
Storage Temperature Range
TSTG
-65 ~+150
Parameter
Input Voltage
ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JUNCTION TEMPERATURE (Vi=-23V,Io=40mA,Ci=0.33uF,,Co=0.1uF, unless otherwise specified )
Parameter
er
mbol
Test conditions
25℃
Output Voltage
-17.5V≤Vl≤-30V, Io=1mA~40mA
Vo
Io=1mA~70mA
Load Regulation
ΔVo
Line Regulation
ΔVo
Quiescent Current
Quiescent Current Change
MD[8QLW
-14.40
-15
-15.60
V
-14.25
-15
-15.75
V
-14.25
-15
-15.75
V
25℃
25
150
mV
Io=1mA~40mA ,Vi=-23V
25℃
15
75
mV
-17.5V≤V l≤-30V , Io=40mA
25℃
65
300
mV
-20V≤V l≤-30V , Io=40mA
25℃
50
250
mV
25℃
6.5
mA
0-125℃
1.5
mA
0-125℃
0.1
mA
Iq
ΔIq
I
T\S
Io=1mA~100mA ,Vi=-23V
ΔIq
I
1mA ≤I O≤40mA
Output Noise Voltage
VN
10Hz≤f≤100KHz
Ripple Rejection
RR
-18.5V≤V l≤-28.5V,f=120Hz
Dropout Voltage
Vd
* Pulse test.
TYPICAL APPLICATION
0-125℃
MLQ
25℃
0-125℃
34
25℃
-Vi
2
3
0.33μF
μV/Vo
39
dB
1.7
V
-Vo
79L15
Ci
90
1
C0
0.1μF
Note: Bypass capacitors are recommended for optimum stability and transient response and should be located as close as
Possible to the regulators.
The above data are for reference only.
https://www.microdiode.com
Rev:2024A1
Page :1
79L15
Typical Characteristics
Dropout Characteristics
Output Characteristics
-21
-15.50
TJ=25℃
IO=0mA
TJ=25℃
(V)
-15.25
-15.00
IO=0mA
VO
-15
-14.75
-12
OUTPUT VOLTAGE
OUTPUT VOLTAGE VO
(V)
-18
-9
-6
-3
IO=40mA,70mA,100mA
-14.50
-14.25
-14.00
-13.75
-10
-15
-20
INPUT VOLTAGE
VIN
-25
-30
-13.50
-15.0
-35
-15.5
-16.0
-16.5
INPUT VOLTAGE
(V)
Quiescent Current vs Input Voltage
-17.0
VIN
-17.5
Current Cut-off Grid Voltage
-3.0
-18
VIN=-23V
TJ=25℃
TJ=25℃
-15
Pulsed
(V)
-2.5
VO
-2.0
OUTPUT VOLTAGE
IQ
(mA)
IO=0mA
QUIESCENT CURRENT
-18.0
(V)
-1.5
-1.0
-0.5
0.0
-12
-9
-6
-3
-10
-15
-20
INPUT VOLTAGE
VIN
-25
-30
50
75
100
OUTPUT CURRENT
(V)
Output Voltage vs Junction Temperature
125
IO
150
175
200
(mA)
Power Derating Curve
-18
800
Vin=-23V
IO=5mA
(W)
700
600
PD
-16
-15
POWER DISSIPATION
OUTPUT VOLTAGE VO
(V)
-17
-14
-13
-12
-11
-10
500
400
300
200
100
50
75
100
TJ
125
150
50
75
Rev:2024A1
100
TJ
125
150
Page :2
79L15
Outlitne Drawing
SOT-89-3L Package Outline Dimensions
Symbol
A
b
b1
c
D
D1
E
E1
e
e1
L
Dimensions In Millimeters
Max
Min
1.400
1.600
0.320
0.520
0.400
0.580
0.350
0.440
4.400
4.600
1.550 REF.
2.300
2.600
3.940
4.250
1.500 TYP.
3.000 TYP.
0.900
1.200
Dimensions In Inches
Min
Max
0.055
0.063
0.013
0.020
0.016
0.023
0.014
0.017
0.173
0.181
0.061 REF.
0.091
0.102
0.155
0.167
0.060 TYP.
0.118 TYP.
0.035
0.047
SOT-89-3L Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-89-3L
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
330
1000
203×203×195
40000
438×438×220
7'
Rev:2024A1
G.W.(Kg)
180000
Page :3
很抱歉,暂时无法提供与“78L15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.60170
- 10+0.44520
- 100+0.38160
- 1000+0.31800
