AO3420
LOW VOLTAGE MOSFET (N-CHANNEL)
FEATURES
Ultra low on-resistance:VDS=20V,RDS(ON)≤24mΩ@VGS=10V,ID=6A
For PWM application
For Load switch application
Surface Mount device
SOT-23
MECHANICAL DATA
Case: SOT-23
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.008 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-source voltage
VDS
V
Gate-source voltage
VGS
±12
V
6
A
TA=25°C
ID
Continuous drain current
TA=70°C
ID
5
A
Pulsed drain current
IDM*
30
A
1.4
W
TA=25°C
PD
Power dissipation
PD
TA=70°C
0.9
W
RθJA
Thermal resistance from Junction to ambient
125
°C/W
Junction temperature
150
°C
TJ
-55 ~+150
TSTG
°C
Storage temperature
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Conditions
Parameter
Symbol Min Typ Max Unit
V
Drain-Source breakdown voltage
V(BR)DSS*
VGS=0V, ID=250μA
1
IDSS*
uA VDS=20V, VGS=0V
Zero gate voltage drain current
±100 nA VDS=0V, VGS=±12V
IGSS*
Gate-body leakage current
0.4 0.75
1.1
V
VGS(th)*
Gate-threshold voltage
VDS=VGS, ID=250μA
16
24
mΩ VGS=10V, ID=6A
18
27
mΩ VGS=4.5V, ID=5A
Drain-source on-resistance)
RDS(ON)*
23
42
mΩ VGS=2.5V, ID=4A
31
55
mΩ VGS=1.8V, ID=2A
25
S
gFS
VDS=5V, ID=6A
Forward transconductance
Rg
0.8
1.7
2.6
Gate resistance
VGS=0V, VDS=0V, f=1MHz
Ω
pF
Ciss
420 525
630
Input capacitance
pF VDS=10V, VGS=0V, f=1MHz
Coss
65
95
125
Output capacitance
pF
Crss
45
75
105
Reverse transfer capacitance
3
nS
t
Turn-on delay time
d(on)
tr
7.5
nS VDS=10V, VGS=10V,
Turn-on rise time
nS RGEN=3Ω, RL=1.7Ω
td(off)
Turn-off delay time
tf
6
nS
Turn-off fall time
12.5
nC
Qg
Total gate charge
1
nC VDS=10V,VGS=10V,ID=6A
Qgs
Gate-source charge
2
nC
Qgd
Gate-drain charge
VSD
0.7
1
V
Diode forward voltage
IS=1A, VGS=0V
IS
2
A
Diode forward current
trr
14
nS IF=6A, dI/dt=100A/us
Body Diode Reverse Recovery Time
Body Diode Reverse Recovery Charge
Qrr
6
nC IF=6A, dI/dt=100A/us
*Pulse test ; Pulse width ≤300µs, Duty cycle ≤ 0.5% .
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
E-mail:hkt@heketai.com
1/6
AO3420
Typical Characteristics
40
10V
3.5V
15
2.5V
4.5V
ID(A)
ID (A)
30
VDS=5V
1.8V
125°C
5
10
25°C
VGS=3.5V
2
3
4
0.5
VDS (Volts)
Fig 1: On-Region Characteristics
60
1.5
2
2.5
1.8
Normalized On-Resistance
55
50
45
RDS(ON) (mΩ
Ω)
1
VGS(Volts)
Figure 2: Transfer Characteristics
VGS=1.8V
40
35
VGS=2.5V
30
25
VGS=4.5V
VGS=4.5V
ID=5A
VGS=2.5V
ID=4A
1.6
1.4
17
VGS=1.8V
5
ID=2A
1.2
2
10
=10V
VGS
ID=6A
1
VGS=10V
10
0.8
15
30
ID (A)
Figure 3: On-Resistance vs. Drain Current and Gate
Voltage
25
50
75
100
125
150
175
Temperature (°C)
Figure 4: On-Resistance vs. Junction
18Temperature
1.0E+02
45
ID=6A
1.0E+01
40
40
1.0E+00
30
125°C
25
IS (A)
RDS(ON) (mΩ
Ω)
35
125°C
1.0E-01
1.0E-02
25°C
1.0E-03
25°C
1.0E-04
1.0E-05
15
4
6
8
10
VGS (Volts)
Figure 5: On-Resistance vs. Gate-Source Voltage
0.0
0.2
0.4
0.6
0.8
1.0
1.2
VSD (Volts)
Figure 6: Body-Diode Characteristics
2/6
AO3420
10
1000
VDS=10V
ID=6A
800
Capacitance (pF)
VGS (Volts)
8
6
4
600
400
Coss
2
200
10
Qg (nC)
Figure 7: Gate-Charge Characteristics
Ciss
15
Crss
10
15
VDS (Volts)
Figure 8: Capacitance Characteristics
100.0
TA=25°C
RDS(ON)
limited
1000
10µs
Power (W)
ID (Amps)
10.0
100µs
1.0
1ms
10ms
0.1
10
10s
TJ(Max)=150°C
TA=25°C
100
DC
1
0.0
0.00001
0.01
0.1
1
VDS (Volts)
10
Zθ JA Normalized Transient
Thermal Resistance
1
0.1
10
1000
Pulse Width (s)
Figure 10: Single Pulse Power Rating Junction-toAmbient
Figure 9: Maximum Forward Biased Safe
Operating Area
10
0.001
100
D=Ton/T
TJ,PK=TA+PDM.ZθJA.RθJA
In descending order
D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, single pulse
RθJA=125°C/W
0.1
PD
PD
0.01
Ton
Ton T
T
Single Pulse
0.001
0.00001
0.0001
0.001
0.01
0.1
1
10
100
1000
Pulse Width (s)
Figure 11: Normalized Maximum Transient Thermal Impedance
3/6
AO3420
Gate Charge Test Circuit & Waveform
Vgs
Qg
10V
+ Vds
VDC
Qgs
Qgd
VDC
DUT
Vgs
Ig
Charge
R esistive Sw itching Test C ircuit & W aveform s
RL
V ds
V ds
DUT
Vgs
90%
+ Vdd
V DC
Rg
10%
Vgs
V gs
t d(on)
tr
t d(off)
t on
tf
t off
Diode Recovery Test Circuit & W aveform s
Q rr = - Idt
Vds +
DUT
Vgs
Vds -
Isd
L
Vgs
Ig
Isd
IF
t rr
dI/dt
+ Vdd
I RM
Vdd
VD C
Vds
4/6
AO3420
SOT-23 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
e
e1
0.950 TYP
1.800
L
0.037 TYP
2.000
0.071
0.550 RE F
0.079
0.022 REF
L1
0.300
0.500
0.012
0.020
θ
0°
8°
0°
8°
SOT-23 Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
5/6
AO3420
SOT-23 Tape and Reel
SOT-23 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOT-23
3.15
2.77
1.22
Ø1.50
1.75
3.50
4.00
4.00
2.00
8.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOT-23 Tape Leader and Trailer
SOT-23 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
9.50
12.30
±2
±1
±1
±1
±1
±1
±1
±1
6/6
很抱歉,暂时无法提供与“AO3420”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.34120
- 100+0.31840
- 300+0.29560
- 500+0.27280
- 2000+0.25020
- 5000+0.22740
- 国内价格
- 10+0.26154
- 100+0.20489
- 300+0.17658
- 3000+0.15524
- 6000+0.13831
- 9000+0.12980
- 国内价格
- 10+0.25235
- 100+0.19770
- 600+0.19572
- 1200+0.19181
- 3000+0.18606
