LPW5210B5F
LPW5210B5F
    LPSEMI(微源)
    SOT23-5
    1.5一个具有可编程电流限制的电源开关
LPW5210B5F 数据手册
Preliminary Datasheet LPW5210 1.5A Power Switch with Programmable Current Limit General Description Features The LPW5210 is an integrated power switch for  160mΩ Low RDS(ON), High-side N-MOSFET self-powered and bus-powered Universal Series Bus  1500mA Programmable current limit (USB) applications. A built-in charge pump is used to  2.5V to 6V Input Voltage  Low Quiescent Current:16μA  Soft Start Function quiescent current (16μA) and small package (SOT23-5)  Built-In Short-Circuit Protection is particularly suitable in battery-powered portable  Built-in Thermal Protection equipment.  RoHS Compliant and 100% Lead (Pb)-Free drive the N-Channel MOSFET that is free of parasitic body diode to eliminate any reversed current flow across the switch when it is powered off. Its low Several protection functions include soft start to limit inrush current during plug-in, current limiting at 1500mA to meet USB power requirement, and thermal Typical Application Circuit shutdown to protect damage under over current conditions. VIN LPW5210 5 Order Information Cin VIN 4 EN VOUT VOUT GND RSET 1 Cout 3 2 LPW5210 □ □ □ Riset 6.8K F: Pb-Free Package Type B5: SOT23-5 Marking Information Device Marking Package Shipping LPW5210 LPS SOT23-5 3K/REEL Applications Marking indication:  Power Switch  USB Device  Battery Charger Circuits LPW5210-03 7WYWX Y:Production year W:Production week Nov.-2012 Email: marketing@lowpowersemi.com X:Production batch www.lowpowersemi.com Page 1 of 5 Preliminary Datasheet LPW5210 Functional Pin Description Package Type Pin Configurations Top View VOUT 1 GND 2 ISET 3 5 VIN 4 EN SOT23-5 Pin Description Pin Name Description 1 VOUT Output to system pin. 2 GND Ground. 3 ISET Connect a resistor to GND for setting current limit. 4 EN Device Enable (active High). 5 VIN Input pin. Function Block Diagram LPW5210-03 Nov.-2012 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 2 of 5 Preliminary Datasheet LPW5210 Absolute Maximum Ratings Note 1  Input Voltage to GND --------------------------------------------------------------------------------------------------- 6.5V  Output Voltage to GND ------------------------------------------------------------------------------------------------ 6.5V  Other pin to GND ---------------------------------------------------------------------------------------------------------- 6V  Maximum Junction Temperature ---------------------------------------------------------------------------------- 150°C  Operating Ambient Temperature Range (TA) -------------------------------------------------------- -40℃ to 85°C  Maximum Soldering Temperature (at leads, 10 sec) ------------------------------------------------------ Note 1. 260°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Thermal Information  Maximum Power Dissipation (SOT23-5, PD, TA=25°C) ----------------------------------------------------- 0.45W  Thermal Resistance (SOT23-5, θJA) ------------------------------------------------------------------------- 250℃/W ESD Susceptibility  HBM(Human Body Mode) --------------------------------------------------------------------------------------------- 2KV  MM(Machine Mode) --------------------------------------------------------------------------------------------------- 200V Electrical Characteristics (Over recommended operating conditions unless specified otherwise, TA=25℃ ) Symbol Parameter VIN Input Voltage IOUT Output Current Limited Condition RISET=10K 680 RISET=6.8K 1000 RISET=4.53K 1500 Output N-MOSFET RDS(ON) IQ Quiescent Current VIN=3V ISHDN Shutdown Current VEN=GND VEN(L) Enable Threshold Low VEN(H) Enable Threshold High IEN Input High Current Nov.-2012 Typ 2.5 RDS(ON) LPW5210-03 Min Max Units 6 V mA 160 16 1.4 VIN=VEN=5.0V Email: marketing@lowpowersemi.com mΩ 28 µA 1 µA 0.4 V V 5 www.lowpowersemi.com µA Page 3 of 5 Preliminary Datasheet LPW5210 Typical Operating Characteristics RISET VS Current Limit 1.6 Current Limit(A) 1.4 1.2 1 0.8 0.6 0.4 0.2 0 0 2 4 6 8 10 12 14 RISET(KΩ) LPW5210-03 Nov.-2012 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 4 of 5 Preliminary Datasheet LPW5210 Packaging Information SOT23-5 LPW5210-03 Nov.-2012 Email: marketing@lowpowersemi.com www.lowpowersemi.com Page 5 of 5
LPW5210B5F 价格&库存
很抱歉,暂时无法提供与“LPW5210B5F”相匹配的价格&库存,您可以联系我们找货
LPW5210B5F
  • 5+0.55736
  • 50+0.43843
  • 600+0.43185
库存:510
