东沃电子
Reverse Voltage: 5.0 to 440 V
Peak Pulse Power: 5000 W
Axial Lead
Transient Voltage Suppressors
Features
R-6/P600
Glass passivated chip
5000 W peak pulse power capability with a
10/1000 μs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-202, method
208 guranteed
DIA.
0.360 9.14
0.340 8.64
1.000 [25.40]
MIN
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
DO
WO
DIA.
0.052 1.32
0.048 1.22
1.000 [25.40]
MIN
0.360 9.14
0.340 8.64
Mechanical Data
5kp Series
5KP Series
DOWOSEMI
Dimensions :
inch [ mm ]
Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
Peak power dissipation with a 10/1000μs waveform(1)
Symbol
PPP
Value
5000
UNIT
W
Peak pulse current wih a 10/1000μs waveform(1)
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sine(2)
wave unidirectional only
Maximum instantaneous forward voltage at 100 A for
unidirectional only(3)
Operating junction and storage temperature range
IPP
PD
See Next Table
8.0
A
W
IFSM
500
A
VF
3.5/5.0
V
TJ, TSTG
–55 to +150
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
(3)VF
很抱歉,暂时无法提供与“5KP24CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.72400
- 10+2.95960
- 30+2.58720
