BDFN2C051V40
Transient Voltage Suppressors
ROHS
Features
Protects one I/O or Power Line
Completely Compatible with SOD923
Low Clamping Voltage
Working Voltage: 5V
Low Leakage Current
Response Time is Typically < 1 ns
DFN-2L
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Mechanical Characteristics
Application
JEDEC DFN-2Lpackage (0402 size)
Cellular Handsets & Accessories
Molding compound flammability rating:
Personal Digital Assistants (PDAs)
UL 94V-0
Notebooks & Handhelds
Marking : Marking Code
Portable Instrumentation
RoHS Compliant
Digital Cameras
MP3 Players
Schematic & PIN Configuration
Bi irectional
1/4
BDFN2C051V40
ROHS
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp = 8/20μs )
PPP
200
Watts
Peak Forward Voltage ( IF = 1A, tp = 8/20μs )
VFP
1.5
V
Operating Temperature
TJ
-55 to + 125
TSTG
-55 to +150
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
I
Parameter
IPP
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
VC VBR VRWM
IT
IR
Breakdown Voltage @ IT
IT
rren t
Tes t Curr
IF
Forward Current
VF
Forward Voltage @ IF
IR
IT
VRWM VBR VC
IPP
Electrical Characteristics
BDFN2C051V40
Parameter
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Symbol
Conditions
Minimum
Typical
VRWM
VBR
IT=1mA
Maximum
Units
5.0
V
6.0
V
VRWM=5V, T=25℃
1
μA
tp =8/20μs
18
A
VC
IPP=1A, tp=8/20μs
6.9
V
Clamping Voltage
VC
IPP=18A, tp=8/20μs
11
V
Junction Capacitance
Cj
VR =0V, f =1MHz
34
pF
IR
Peak Pulse Current
IPP
Clamping Voltage
2/4
V
BDFN2C051V40
ROHS
Typical Characteristics
Figure 2: Power Derating Curve
Time
10
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power Vs Pulse
1
200W 8/20µs
Waveform
0.1
0.01
0.1
1
10
100
td – Pulse Duration - µs
110
100
90
80
70
60
50
40
30
50
75
100
125
150
Ambient Temperature - TA (℃)
Figure 3: Clamping Voltage vs. Peak Pulse
Current
Figure 4: Normalized Junction Capacitance
vs. Reverse Voltage
1.1
14
13
12
11
10
9
8
7
6
5
4
3
2
1
F=1MHz
0.9
Cj(VR )/Cj(VR =0)
Clamping Voltage -Vc(V)
25
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
2
3
4
5
6
7
8
1
2
3
Reverse Voltage
Peak Pulse Current Ipp(A)
5
-VR(V)
Figure 6: ESD Clamping( 8kV Contact per
IEC 61000-4-2)
Figure 5: Pulse Waveform
Tek Run: 2.50GS/s
110
4
Sample
Waveform
Paramters tr=8µs
td=20µs
100
90
Percent Ipp
80
70
e-t
60
50
40
td=Ipp/2
30
10
15
30
CH1 10.0 VΩ
M 20.0ns Ch1
7V
Time
(µs)
3/4
BDFN2C051V40
ROHS
Outline Drawing – DFN-2L
PACKAGE OUTLINE
D
e
h
2
1
L2
L1
1
SYMB
OL
A
A1
b
C
D
e
E
L
L1
h
b
E
h
L1
A1
C
A
BOTTOM VIEW
Land Pattern
DFN-2L
MILIMETER
MIN
NOM
MAX
0.45
0.50
0.55
0.05
0.45
0.50
0.55
0.12
0.15
0.18
0.95
1.00
1.05
0.65BSC
0.55
0.60
0.65
0.20
0.25
0.30
0.05REF
0.07
0.12
0.17
1.00
0.60
0.30
0.35
Marking Codes
Part Number
Marking Code
BDFN2C051V40
M5
0.35
BDFN2C051V40
Package
Information
Qty:10k/Reel
4/4
很抱歉,暂时无法提供与“BDFN2C051V40”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23849
- 1000+0.16721
- 4000+0.14939
- 10000+0.13098
- 国内价格
- 20+0.25770
- 200+0.20630
- 600+0.18060
- 2000+0.16140
- 10000+0.14150
- 20000+0.13370
