PSBD3D60V1H
Schottky Barrier diode
Feature
Ultra Small mold type. (SOD-323)
Low IR
High reliability.
Construction
Applications
Low current rectification
Silicon epitaxial planar
Mechanical Characteristics
Lead finish:100% matte Sn(Tin)
Mounting position: Any
Qualified max reflow temperature:260℃
Pure tin plating: 7 ~ 17 um
Pin flatness:≤3mil
Electrical characteristics per line@25℃
Parameter
Symbol
Min.
Typ.
Max.
Unit
Conditions
Forward voltage
VF
0.685
V
IF=1A
Reverse current
IR
0.1
mA
VR=60V
Absolute maximum rating@25℃
Parameter
Symbol
limits
Unit
Reverse voltage (DC)
VRM
60
V
Average rectified forward current
Io
1
A
IFSM
25
A
Operating Junction temperature Range
Tj
-55 to 125
Storage temperature
Tstg
-55 to 125
Peak Forward Surge Current 8.3ms Single Half
Sine Wave Superimposed on Rated Load
Rev.06.4
1
www.prisemi.com
PSBD3D60V1H
Typical Characteristics
100
IR –Reverse Current (mA)
1000
IF –Forward Current (mA)
100
10
1.0
25℃
0.1
0.01
0.001
0.0
0.1
0.2
0.3
0.4
0.5
125℃
10
75℃
1
0.1
25℃
0.01
-25℃
0.001
VF – Forward Voltage (V)
Fig 1.Forward Voltage
15
VR – Reverse Voltage (V)
30
45
60
Fig 2.Leakage Current
Solder Reflow Recommendation
Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec
280
240
200
160
120
80
40
60
90
120
150
180
240
210
270
300
330
360
390
420
450
480
Time (sec)
Rev.06.4
2
www.prisemi.com
PSBD3D60V1H
Product dimension (SOD-323)
C
Dim
A
E
B
F
D
H
Inches
Millimeters
MIN
MAX
MIN
MAX
A
0.063
0.075
1.60
1.90
B
0.045
0.057
1.15
1.45
C
0.090
0.106
2.30
2.70
D
0.031
0.043
0.80
1.10
E
0.010
0.01
0.25
0.40
F
0.004
0.007
0.09
0.18
H
0.000
0.004
0.00
0.10
3.00
0.90
0.80
Suggested
PCB Layout
Unit:mm
Marking information
SH
Ordering information
Device
Package
Reel
Shipping
PSBD3D60V1H
SOD-323(Pb-free)
7"
3000 / Tape & Reel
Rev.06.4
3
www.prisemi.com
PSBD3D60V1H
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi
assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06.4
4
www.prisemi.com
很抱歉,暂时无法提供与“PSBD3D60V1H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.13201
- 100+0.12001
- 500+0.11201
- 1000+0.10401
- 5000+0.09440
- 10000+0.09040
- 国内价格
- 50+1.03680
- 500+1.01952
- 3000+0.99360
- 10000+0.96768
