XMP-02V
XMP-02V
    JST
    P=2.5mm
    胶壳 间距P=2.50mm 2Pin(1x2)
XMP-02V 数据手册
Crimp 2.5mm XM CONNECTOR High box type Disconnectable Crimp style connectors (Board) pitch Features –––––––––––––––––––––––– • Interchangeability The housing is interchangeable with these of the XM receptacle housing. • Inner-housing lock This inner-housing lock secures the plug to the receptacle and prevents accidental disconnection. The lock is protected and is not affected by external forces that might result from the routing of wires. • Secondary retainers The secondary retainers enhance safety in case of partial insertion or accidental release of the contact. Even if a contact is inserted incompletely, the retainer guides the contact to the proper position and securely locks it in place. This is XM connector high box type, with 20.0mm mounting height and with 8.9mm thickness. This connector exhibits the stable electric connection to the condition such as the vibration, the prying, the micro-current and micro-voltage circuit. • Header for 2.5mm pitch XM connector for use specifically with resin coated ("potted") PC boards This header is tall and fully shrouded so as to prevent the resin used to coat the PC board from coming into contact with the mating pins. 6 5 ST HJ 4 3 2 Fa 1 Specifications ––––––––––––––––––– • Current rating: 3 A AC, DC (AWG #22, #20) • Voltage rating: 250 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 500 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable wire: AWG #28 to #20 • Applicable PC board thickness: 1.6 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. 1 XM CONNECTOR High box type Contact–––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Model No. 1.9 SXA- 01T-P0.6 SXA-001T-P0.6 Q'ty/ reel 0.22 to 0.50 24 to 20 1.5 to 1.9 8,000 0.08 to 0.33 28 to 22 0.8 to 1.9 8,000 Material and Finish 6.5 3.1 Applicable wire Insulation O.D. (mm) AWG # mm2 2.9 1.3 Phosphor bronze, tin-plated (reflow treatment) 0.8 2.3 RoHS compliance Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits Model No. 2 XMP-02V XMP-03V XMP-04V XMP-05V XMP-06V XMP-07V XMP-08V XMP-09V XMP-10V 3 4 B A 5 6 2.5 7 8 9 10 11.5 6.3 12 Dimensions (mm) A B Q’ty/ bag 2.5 8.8 1,000 5.0 9.8 1,000 7.5 12.3 1,000 10.0 14.8 500 12.5 17.3 500 15.0 19.8 500 17.5 22.3 500 20.0 24.8 500 22.5 27.3 500 Material 7.7 PA 66, UL94V-0 RoHS compliance Retainer ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits 2 3 4 5 A 6 7 8 2.5 7.8 10 A Q’ty/bag 2.5 1,000 5.0 1,000 7.5 1,000 10.0 1,000 12.5 1,000 15.0 1,000 17.5 1,000 20.0 1,000 22.5 1,000 Material 0.95 2.5 9 Model No. XMS-02V XMS-03V XMS-04V XMS-05V XMS-06V XMS-07V XMS-08V XMS-09V XMS-10V Glass-filled PA 66, UL94V-0 RoHS compliance 2 XM CONNECTOR High box type Shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––––––––––– B Circuits Model No. 2 BH02B-XMSK BH03B-XMSK BH04B-XMSK BH05B-XMSK BH06B-XMSK BH07B-XMSK BH08B-XMSK BH09B-XMSK BH10B-XMSK 3 8.9 4 5 6 7 18.8 8 9 10 Dimensions (mm) A B Q'ty/ bag 2.5 8.9 770 5.0 9.9 700 7.5 12.4 525 10.0 14.9 455 12.5 17.4 385 15.0 19.9 315 17.5 22.4 280 20.0 24.9 245 22.5 27.4 245 1.5 Material and Finish (3.5) Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0 RoHS compliance This product displays (LF)(SN) on a label. 2.5 A PC board layout (viewed from soldering side) and Assembly layout ––––––––––––––––––– 8.9 1.55 A φ1.7 ±0.05 ±0.1 (20) ±0.05 3.15 ±0.05 2.5 ±0.05 φ0.9 + 00.1 Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers. 2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Crimping machine, Applicator––––––––––––––––––––––––––––––––––––––––––––––– Contact SXA-001T-P0.6 SXA-01T-P0.6 Note: *Strip-crimp applicator 3 Crimping machine AP-K2N AP-K2N Crimp applicator Dies Crimp applicator with dies MKS-L MK/SXA/M-001-06 APLMK SXA/M001-06 *MKS-SC SC/SXA/M-001-06 APLSC SXA/M001-06 MKS-L MK/SXA/M-01-06 APLMK SXA/M01-06 *MKS-SC SC/SXA/M-01-06 APLSC SXA/M01-06
XMP-02V 价格&库存
很抱歉,暂时无法提供与“XMP-02V”相匹配的价格&库存,您可以联系我们找货
XMP-02V
    • 1+0.597421+0.07730
    • 500+0.52274500+0.06763
    • 1000+0.448071000+0.05797
    • 4000+0.389994000+0.05046
    • 5000+0.389995000+0.05046
    • 10000+0.3733910000+0.04831
    • 30000+0.3733930000+0.04831
    库存:223
    XMP-02V
      库存:30000
      XMP-02V
        • 1+0.27443
        库存:30
        XMP-02V
          • 1+0.541521+0.07006
          • 10+0.4367110+0.05650
          • 50+0.3668450+0.04746
          • 100+0.31443100+0.04068
          • 500+0.28823500+0.03729
          • 1000+0.270761000+0.03503
          • 2000+0.270762000+0.03503
          库存:3
          XMP-02V
            库存:22000
            XMP-02V
              库存:40000
              XMP-02V
              • 1+1.09000
              • 5+0.97501
              • 10+0.90434
              • 25+0.79965
              • 50+0.72227
              • 100+0.65064
              • 200+0.58908
              • 250+0.57231
              • 1000+0.48451
              • 10000+0.39995
              库存:1014
