山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
MM1Z2V0B THRU MM1Z75B
Silicon Planar Zener Diodes
PINNING
PIN
FEATURES
• Total power dissipation: Max. 500mW.
• Wide zener reverse voltage range 2.0V to 75V.
• Small plastic package suitable for surface mounted design.
• Tolerance approximately±2%
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
▪Case: SOD-123
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪ Approx. Weight:16mg/0.00056oz
Simplified outline SOD-123 and symbol
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Symbol
Value
Unit
Power Dissipation
P tot
500
mW
Forward Voltage at I F = 10 mA
VF
0.9
V
RθJA
340
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Typical thermal resistance juncting to ambient
Operating and Storage Temperature Range
(1)
Fig.1 Maximum Continuous Power Derating
0.6
Power Dissipation ( W )
0.5
0.4
0.3
0.2
0.1
0.0
25
50
75
100
125
150
T c ,Case Temperature (°C)
2017.12
175
Transient Thermal Impedance( °C /W)
(1) Thermal resistance from junction to ambient at P.C.B. mounted with 2 .0" X 2.0" (5 X 5 cm) copper areas pads.
Fig.2 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
100
t, Pulse Duration(sec)
SOD123-W-MM1Z2V0B~MM1Z75B-500mW
Page 1 of 3
山东晶导微电子股份有限公司
Characteristics at Ta = 25°C
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
V ZT(at I ZT)
Min(V)
Reverse Current
I ZT
Z ZT(at I ZT)
IR
at V R
Max(μA)
(V)
Nom(V)
Max(V)
(mA)
Max (Ω)
MM1Z2V0B
4A
1.96
2
2.04
5
100
120
0.5
MM1Z2V2B
4B
2.16
2.2
2.24
5
100
120
0.7
MM1Z2V4B
4C
2.35
2.4
2.45
5
100
120
1
MM1Z2V7B
4D
2.65
2.7
2.75
5
110
120
1
MM1Z3V0B
4E
2.94
3
3.06
5
120
50
1
MM1Z3V3B
4F
3.23
3.3
3.37
5
130
MM1Z3V6B
4H
3.53
3.6
3.67
5
130
10
1
MM1Z3V9B
4J
3.82
3.9
3.98
5
130
5
1
MM1Z4V3B
4K
4.21
4.3
4.39
5
130
5
1
4.7
4.79
MM1Z4V7B
4M
4.61
5
130
2
1
MM1Z5V1B
4N
5
5.1
5.20
5
130
2
1.5
MM1Z5V6B
4P
5.49
5.6
5.71
5
80
1
2.5
MM1Z6V2B
4R
6.08
6.2
6.32
5
50
1
3
MM1Z6V8B
4X
6.66
6.8
6.94
5
30
0.5
3.5
MM1Z7V5B
4Y
7.35
7.5
7.65
5
30
0.5
4
MM1Z8V2B
4Z
8.04
8.2
8.36
5
30
0.5
5
MM1Z9V1B
5A
8.92
9.1
9.28
5
30
0.5
6
MM1Z10B
5B
9.8
10
10.2
5
30
0.1
7
MM1Z11B
5C
10.78
11
11.22
5
30
0.1
8
11.76
12
12.24
5
35
0.1
9
0.1
10
0.1
11
MM1Z12B
5D
MM1Z13B
5E
12.74
13
13.26
5
35
MM1Z15B
5F
14.7
15
15.3
5
40
MM1Z16B
5H
15.68
16
16.32
5
40
0.1
12
MM1Z18B
5J
17.64
18
18.36
5
45
0.1
13
MM1Z20B
5K
19.6
5
50
0.1
15
MM1Z22B
5M
21.56
22
22.44
5
55
0.1
17
MM1Z24B
5N
23.52
24
24.48
5
60
0.1
19
MM1Z27B
5P
26.46
27
27.54
5
70
0.1
21
MM1Z30B
5R
29.4
30
30.6
5
80
0.1
23
MM1Z33B
5X
32.34
33
33.66
5
80
0.1
25
35.28
36
36.72
5
90
0.1
27
2.5
100
MM1Z36B
5Y
MM1Z39B
5Z
38.22
39
39.78
2
30
MM1Z43B
6A
42.14
43
43.86
2.5
130
2
33
MM1Z47B
6B
46.06
47
47.94
2.5
150
2
36
MM1Z51B
6C
49.98
51
52.02
2.5
180
1
39
MM1Z56B
6D
54.88
56
57.12
2.5
180
1
43
MM1Z62B
6E
60.76
62
63.24
2.5
200
0.2
47
MM1Z68B
6F
66.64
68
69.36
2.5
250
0.2
52
MM1Z75B
6H
73.5
75
76.5
2.5
300
0.2
57
(1) V ZT is tested with pulses (20 ms)
2017.12
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123
A
D
b
E
A1
C
∠ALL ROUND
L1
E1
SOD-123 mechanical data
A
C
D
E
E1
L1
b
A1
max
1.3
0.22
1.8
2.8
3.9
0.45
0.7
0.2
min
0.9
0.09
1.5
2.5
3.6
0.25
0.5
max
51
8.7
71
110
154
18
28
min
35
3.5
59
98
142
10
UNIT
mm
9°
8
mil
The recommended mounting pad size
2.0
(79)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
2017.12
www.sdjingdao.com
Page 3 of 3
很抱歉,暂时无法提供与“MM1Z12B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05562
- 500+0.03230
- 3000+0.01944
- 6000+0.01167
- 24000+0.00486
- 51000+0.00130
- 国内价格
- 50+0.08355
- 600+0.06673
- 1200+0.06573
- 3000+0.05832
