SS32C THRU SS3200C
Reverse Voltage - 20 to 200 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
Built-in strain relief,ideal for automated placement
0.280(7.11)
0.260(6.60)
High forward surge current capability
High temperature soldering guaranteed:
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.103(2.62)
0.079(2.06)
0.060(1.52)
0.030(0.76)
Mechanical Data
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Case: JEDEC DO-214AB/SMC molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end Mounting
Position: Any
Weight : 0.0077 ounce, 0.22 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
MDD
SS32C
MDD
SS33C
30
21
30
MDD
SS34C
40
28
40
MDD
SS35C
MDD
SS36C
50
35
50
60
42
60
MDD
SS38C
80
56
80
MDD
SS310C
MDD
SS3150C
MDD
SS3200C
UNITS
150
105
150
200
140
200
V
V
V
100
70
100
I(AV)
3.0
A
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
80
A
Maximum instantaneous forward voltage at 3.0A
VF
Maximum average forward rectified current
Peak forward surge current
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=100℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
IR
CJ
RJA
0.55
0.70
0.85
0.5
5.0
450
0.95
0.3
3.0
350
50
V
mA
pF
℃/W
TJ
-55to +150
TSTG
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
SS32C THRU SS3200C
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
3.0
2.4
1.8
1.2
0.6
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Average Forward Current (A)
3.5
10
4
10
3
10
2
TJ=100°C
TJ=75°C
SS32C/SS36C
10
TJ=25°C
Fig.3 Typical Forward Characteristic
60
80
100
Fig.4 Typical Junction Capacitance
TJ=25°C
10
1.0
Junction Capacitance (pF)
500
SS32C/SS34C
SS36C
SS38C/SS312C
SS315C/SS320C
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
200
100
SS32C~SS36C
SS38C~SS320C
10
0.1
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
10
100
Fig.6- Typical Transient Thermal Impedance
120
80
60
40
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
Number of Cycles
100
Transient Thermal Impedance(°C/W)
100
100
00
1
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Case Temperature (°C)
Instaneous Forward Current (A)
SS38C~SS320C
1
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
SS32C THRU SS3200C
Packing information
unit:mm
P0
Item
Symbol
Tolerance
SMC
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
6.15
8.41
2.42
1.50
330.00
50.00
13.00
1.75
7.50
8.00
4.00
2.00
0.25
16.00
16.50
P1
d
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
SMC
13"
3,000
4.0
BOX
(pcs)
6000
INNER
BOX
(mm)
REEL
DIA,
(mm)
190*190*41
330
CARTON
SIZE
(mm)
CARTON
(pcs)
365*365*340
42000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
4.3
0.170
B
0.160
C
4.1
7.9
0.311
D
3.8
0.150
E
12
0.472
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SS3150C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+1.07960
- 100+0.64400
- 800+0.45080
- 3000+0.32200
- 6000+0.30590
- 30000+0.28340
- 国内价格
- 1+0.71060
- 200+0.49060
- 1500+0.44660
- 3000+0.41690
- 国内价格
- 5+0.62036
- 50+0.50426
- 150+0.44615
- 500+0.40263
- 3000+0.33200
- 6000+0.31450
- 国内价格
- 10+0.56866
- 100+0.46223
- 600+0.36907
- 1200+0.36353
- 3000+0.30433
