SOD1F1 THRU SOD1F7
SURFACE MOUNT FAST RECOVERY RECTIFIER
Reverse Voltage - 50 to 1000 Volts
SOD-123FL
FEATURES
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.8± 0.1
1.0±0.2
Cathode Band
Top View
0.10-0.30
2.8±0.1
1.1± 0.15
Forward Current - 1.0 Ampere
0.6±0.25
MECHANICAL DATA
Case: JEDEC SOD-123FL molded plastic body over passivated chip
Terminals: Solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS SOD1F1 SOD1F2 SOD1F3 SOD1F4 SOD1F5 SOD1F6 SOD1F7
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TA=65 C (NOTE 1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method) TL=25 C
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=125 C
Maximum reverse recovery time (NOTE 2)
Typical junction capacitance (NOTE 3)
VRRM
VRMS
VDC
F1
F2
F3
F4
F5
F6
F7
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
1.0
Amp
IFSM
25.0
Amps
VF
1.3
Volts
IR
10.0
50.0
µA
trr
CJ
Typical thermal resistance (NOTE 4)
RθJA
Operating junction and storage temperature range TJ,TSTG
250
150
4
180
-50 to +150
Note: 1.Averaged over any 20ms period.
2.Measured with IF=0.5A, IR=1A, Irr=0.25A.
3.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
4.Thermal resistance junction to ambient, 6.0 mm2 coppeer pads to each terminal.
500
ns
pF
°C/W
C
RATINGS AND CHARACTERISTIC CURVES SOD1F1 THRU SOD1F7
FIG.2 -- TYPICAL JUNCTION CAPACITANCE
100
10
10
T J =25
Pulse Width=300us
9
CAPACITANCE, pF
4
AMPERES
2
1.0
0.4
0.2
0.1
0.06
0.04
0.02
0.01
0.6 0.8
1.0
1.2
1.4
1.6
8
7
6
5
4
3
2
1
INSTANTANEOUS FORWARD VOLTAGE,V
T J = 150 °
C
T J = 125 °
C
T J = 100 °
C
1
T J = 75 °
C
T J = 50 °
C
0.1
T J = 25 °
C
0.01
200
300
400
500
600
700
800
10
15
30
35
40
900
INSTANTANEOUS REVERSE VOLTAGE,V
FIG.4 -- FORWARD DERATING CURVE
AVERAGE FORWARD CURRENT,
AMPERES
100
10
5
REVERSE VOLTAGE,VOLTS
FIG.3 -- TYPICAL INSTANTANEOUS
REVERSE CHARACTERISTICS
µ AMPERES
INSTANTANEOUS REVERSE CURRENT
INSTANTANEOUS FORWARD CURRENT
FIG.1 --TYPICAL FORWARD CHARACTERISTIC
1.2
Resistive or Inductive Load
1.0
0.8
0.6
0.4
0.2
3.0 x 3.0mm 40 µm
Thick Copper Pad Areas
60
80
100
120
AMBIENT TEMPERATURE,
The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)!
140
160
很抱歉,暂时无法提供与“SOD1F2 F2”相匹配的价格&库存,您可以联系我们找货
