MB24S THRU MB220S
2A SURFACE MOUNT SCHOTTKY BRIDGE
PINNING
FEATURES:
Reverse Voltage - 40 to 200 V
PIN
DESCRIPTION
1
Input Pin(~)
2
Input Pin(~)
Forward Current - 2 A
High Surge Current Capability
3
Output Anode(+)
Designed for Surface Mount Application
4
Output Cathode(-)
MECHANICAL DATA
• Case: MBS
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 100mg / 0.0035oz
3
4
2
1
MBS Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
MB24S
MB26S
MB28S
MB210S
MB220S
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
60
80
100
200
V
Maximum RMS voltage
V RMS
28
42
56
70
140
V
Maximum DC Blocking Voltage
V DC
40
60
80
100
200
V
Parameter
Maximum Average Forward Rectified Current
at Tc = 100°C
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
Max Instantaneous Forward Voltage at 2 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance 1)
Typical Thermal Resistance
2)
Operating Junction Temperature Range
Storage Temperature Range
I F(AV)
2.0
I FSM
VF
50
0.55
0.70
0.5
10
IR
Cj
A
40
A
0.85
V
0.3
5
220
80
mA
pF
°C/W
RθJA
75
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
2016.01
MBS-S-MB24S~MB220S-2A200V
Page 1 of 3
MB24S THRU MB220S
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
3.0
2.5
2.0
1.5
1.0
0.5
Resistive or Inductive Load
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
T J =100°C
10 3
T J =75°C
10 2
MB24S/MB26S
MB28S-MB220S
10 1
T J =25°C
10 0
Case Temperature (°C)
Junction Capacitance ( pF)
10
1.0
MB24S
MB26S
MB28S/MB220S
0.1
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
100
50
MB24S
MB26F-MB220S
10
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
MB28S-MB220S
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
100
1000
100
10
Number of Cycles at 60Hz
2016.01
T J =25°C
Instaneous Forward Voltage (V)
MB24S-MB26S
1
100
200
1.8
60
10
80
500
T J =25°C
Fig.4 Typical Junction Capacitance
Transient Thermal Impedance( °C /W)
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
Fig.3 Typical Forward Characteristic
Percent of Rated Peak Reverse Voltage(%)
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
MB24S THRU MB220S
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
MBS
A
∠ALL ROUND
C
a
L1
L
d
HE
e
D
e
E
MBS mechanical data
A
C
D
E
HE
d
e
L
L1
a
max
2.6
0.22
5.0
4.1
7.0
2.7
0.7
1.7
1.1
0.2
min
2.2
0.15
4.5
3.6
6.4
2.3
0.5
1.3
0.5
max
102
8.7
197
161
276
106
28
67
43
min
94
5.9
177
142
252
91
UNIT
mm
7°
8
mil
Marking
Type number
6.0
236
2.5
100
0.9
35
2.4
94
Marking code
MB24S
MB24S
MB26S
MB26S
MB28S
MB28S
MB210S
MB210S
MB220S
MB220S
mm
Unit :
(mil)
MBxxS
2016.01
XTH509304B0
Page 3 of 3
很抱歉,暂时无法提供与“MB210S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.99068
- 50+0.78812
- 600+0.59290
- 1200+0.58401
- 3000+0.54468
- 国内价格
- 5+1.09178
- 50+0.86854
- 150+0.77285
- 500+0.65340
- 3000+0.60027
- 6000+0.56841
- 国内价格
- 1+0.63000
- 100+0.58800
- 300+0.54600
- 500+0.50400
- 2000+0.48300
- 5000+0.47040
- 国内价格
- 10+1.85580
- 200+1.10700
- 800+0.77490
- 3000+0.55350
- 6000+0.52580
- 30000+0.48700
- 国内价格
- 1+0.77990
- 200+0.53680
- 1500+0.48840
- 3000+0.45650
