山东晶导微电子有限公司
MB14F THRU MB120F
Jingdao Microelectronics
1A SURFACE MOUNT SCHOTTKY BRIDGE
FEATURES:
PINNING
Reverse Voltage - 40 to 200 V
PIN
DESCRIPTION
1
Input Pin(~)
2
Input Pin(~)
Forward Current - 1 A
High Surge Current Capability
Designed for Surface Mount Application
3
Output Anode(+)
4
Output Cathode(-)
MECHANICAL DATA
• Case: MBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 75mg 0.0024oz
3
4
2
1
MBF Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
MB14F
MB16F
MB18F
MB110F
MB115F
MB120F
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
60
80
100
150
200
V
Maximum RMS voltage
V RMS
28
42
56
70
105
140
V
Maximum DC Blocking Voltage
V DC
40
60
80
100
150
200
V
Parameter
Maximum Average Forward Rectified Current
I F(AV)
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
Max Instantaneous Forward Voltage at 1 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance 1)
Typical Thermal Resistance
2)
Operating Junction Temperature Range
Storage Temperature Range
VF
1.0
40
0.55
30
0.70
0.3
10
IR
Cj
A
110
A
0.85
0.90
V
0.2
5
0.1
2
mA
80
pF
RθJA
100
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
2016.01
MBF-S-MB14F~MB120F-1A200V
Page 1 of 3
山东晶导微电子有限公司
MB14F THRU MB120F
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Resistive or Inductive Load
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
10 3
T J =100°C
10 2
T J =75°C
10 1
T J =25°C
10
Case Temperature (°C)
40
80
100
Percent of Rated Peak Reverse Voltage(%)
500
10
1.0
MB14F
MB16F/MB18F
MB110F
MB115F/MB120F
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
100
50
MB16F-MB120F
10
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
MB110F-MB120F
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
100
1000
100
10
Number of Cycles at 60Hz
2016.01
MB14F
Instaneous Forward Voltage (V)
MB14F-MB18F
1
T J =25°C
200
1.8
50
00
Junction Capacitance ( pF)
Transient Thermal Impedance( °C /W)
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
Fig.4 Typical Junction Capacitance
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
MB14F THRU MB120F
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
MBF
∠ALL ROUND
C
A
a
L1
L
d
HE
e
D
e
E
MBF mechanical data
A
C
D
E
HE
d
e
L
L1
a
max
1.6
0.22
5.0
4.1
7.0
2.7
0.8
1.7
1.1
0.2
min
1.2
0.15
4.5
3.6
6.4
2.3
0.5
1.3
0.5
max
63
8.7
197
161
276
106
31
67
43
min
47
5.9
177
142
252
91
UNIT
mm
7°
8
mil
Marking
6.0
236
Type number
2.5
100
0.9
35
2.4
94
mm
Unit :
(mil)
Marking code
MB14F
MB14F
MB16F
MB16F
MB18F
MB18F
MB110F
MB110F
MB115F
MB115F
MB120F
MB120F
MBxxF
2016.01
XTH601062A8
Page 3 of 3
很抱歉,暂时无法提供与“MB14F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.16716
- 50+0.93204
- 150+0.83128
- 500+0.70546
- 2500+0.64952
- 5000+0.61593
- 国内价格
- 5+1.05909
- 50+0.84574
- 1000+0.64014
- 2000+0.58937
- 5000+0.55889
