RB060M-60
RB060M-60
    SK(時科)
    SMF(SOD-123FL)
    SOD123FL 700mV 2A 60V 80pF 2Pins
RB060M-60 数据手册
RB060M-30/40/60 Surface Mount Schottky Barrier Rectifier Reverse Voltage - 30 to 60V Forward Current - 2.0A PINNING PIN Features • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications Cathode 2 Anode 1 MECHANICAL DATA • Case: SOD-123FL • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight:15mg 0.00048oz DESCRIPTION 1 2 Simplified outline SOD-123FL and symbol Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Symbols Parameter RB060M-30 RB060M-40 RB060M-60 Units Maximum Repetitive Peak Reverse Voltage V RRM 30 40 60 V Maximum RMS voltage V RMS 28 28 42 V Maximum DC Blocking Voltage V DC 30 40 60 V Maximum Average Forward Rectified Current I F(AV) 2.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 50 A Max Instantaneous Forward Voltage at 2 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance 1) Typical Thermal Resistance 2) 0.5 5 220 mA 80 pF 80 °C/W Tj -55 ~ +125 °C T stg -55 ~ +150 °C at 1MHz and applied reverse voltage of 4 V D.C. P.C.B. mounted with 0.2 X 0.2" (5 X 5 mm) copper pad areas. REV.07 V RθJA 1) Measured 2) 0.70 0.55 IR Cj Operating Junction Temperature Range Storage Temperature Range VF 1 of 3 RB060M-30/40/60 Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 3.0 100LFM 2.5 2.0 1.5 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.5 0.0 25 50 75 100 125 150 10 4 T J =25°C 10 0 0 40 20 60 80 100 Percent of Rated Peak Reverse Voltage(%) Fig.4 Typical Junction Capacitance 500 Junction Capacitance ( pF) 20 10 1.0 RB060M-30-40 RB060M-60 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 50 RB060M-30-40 RB060M-60 20 10 1 0.1 100 10 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 50 RB060M-30-40-60 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 100 Instaneous Forward Voltage (V) 60 10 T J =25°C 200 1.8 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) RB060M-30-40 RB060M-60 10 1 Fig.3 Typical Forward Characteristic Peak Forward Surage Current (A) T J =75°C 10 2 Lead Temperature (°C) 10 100 Number of Cycles at 60Hz REV.07 T J =100°C 10 3 200 100 10 1 0.01 0.1 1 10 t, Pulse Duration(sec) 2 of 3 100 RB060M-30/40/60 PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123FL ∠ALL ROUND C A ∠ALL ROUND VM D E A g Top View mil Bottom View A C D E e g HE max 1.1 0.20 2.9 1.9 1.1 0.9 3.8 min 0.9 0.12 2.6 1.7 0.8 0.7 3.5 max 43 7.9 114 75 43 35 150 min 35 4.7 102 67 31 28 138 UNIT mm 1.2 (47) 1.2 (47) 2.0 (79) Unit: mm (mil) REV.07 ∠ 7° The recommended mounting pad size 1.2 (47) g pad e E A pad HE 3 of 3
RB060M-60 价格&库存
很抱歉,暂时无法提供与“RB060M-60”相匹配的价格&库存,您可以联系我们找货
RB060M-60
  • 5+0.27002
  • 20+0.24619
  • 100+0.22237
  • 500+0.19854
  • 1000+0.18742
  • 2000+0.17948
库存:26
