MB34S
MB34S
    JINGDAO(晶导微电子)
    MBS
    3A表面安装肖特基电桥 VR=40V IR=0.5mA MBS
MB34S 数据手册
MB34S THRU MB320S 3A SURFACE MOUNT SCHOTTKY BRIDGE FEATURES: PINNING Reverse Voltage - 40 to 200 V PIN DESCRIPTION Forward Current - 3 A 1 Input Pin(~) High Surge Current Capability 2 Input Pin(~) Designed for Surface Mount Application 3 Output Anode(+) 4 Output Cathode(-) MECHANICAL DATA • Case: MBS • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight: 100mg / 0.0035oz 3 4 2 1 MBS Package Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols Parameter MB34S MB36S MB38S MB310S MB320S Units Maximum Repetitive Peak Reverse Voltage V RRM 40 60 80 100 200 V Maximum RMS voltage V RMS 28 42 56 70 140 V Maximum DC Blocking Voltage V DC 40 60 80 100 200 V Maximum Average Forward Rectified Current at Tc = 100°C Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) Max Instantaneous Forward Voltage at 3 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance 1) Typical Thermal Resistance 2) Operating Junction Temperature Range Storage Temperature Range I F(AV) A 3.0 I FSM 80 70 A VF 0.55 IR 0.5 10 0.3 5 mA Cj 250 160 pF 0.70 0.85 0.95 V RθJA 65 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. 2016.01 MBS-S-MB34S~MB320S-3A200V Page 1 of 3 MB34S THRU MB320S Fig.2 Typical Reverse Characteristics Average Forward Current (A) 3.5 3.0 2.5 2.0 1.5 1.0 0.5 Resistive or Inductive Load 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 MB34S MB36S-MB320S 10 1 T J =25°C 10 0 0 Junction Capacitance ( pF) MB34S MB36S/MB38S MB310S MB320S 0.1 0.4 0.6 0.8 1.0 1.2 1.4 1.6 T J =25°C 200 100 50 MB32S/MB34S 20 MB36S-MB320S 10 1.8 0.1 1 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 100 MB32S~MB38S MB310S~MB312S 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 10 100 200 100 10 Number of Cycles at 60Hz 2016.01 100 Instaneous Forward Voltage (V) Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) Peak Forward Surage Current (A) 1.0 1 80 500 10 00 60 Fig.4 Typical Junction Capacitance T J =25°C 0.2 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 0 T J =75°C 10 2 Case Temperature (°C) 20 T J =100°C 10 3 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 MB34S THRU MB320S PACKAGE OUTLINE Plastic surface mounted package; 4 leads MBS A ∠ALL ROUND C a L1 L d HE e D e E MBS mechanical data A C D E HE d e L L1 a max 2.6 0.22 5.0 4.1 7.0 2.7 0.7 1.7 1.1 0.2 min 2.2 0.15 4.5 3.6 6.4 2.3 0.5 1.3 0.5 max 102 8.7 197 161 276 106 28 67 43 min 94 5.9 177 142 252 91 20 51 20 UNIT ∠ mm 7° 8 mil Marking 6.0 236 2.5 100 0.9 35 2.4 94 Type number Marking code MB34S MB34S MB36S MB36S MB38S MB38S MB310S MB310S MB320S MB320S mm Unit : (mil) MBxxS 2016.01 XTH509305B0 Page 3 of 3
MB34S
物料型号:MB34S至MB320S
器件简介:这些是3A表面贴装肖特基整流桥,设计用于表面贴装应用,具有高浪涌电流能力。
引脚分配: - 引脚1:输入端子(~) - 引脚2:输入端子(~) - 引脚3:输出阳极(+) - 引脚4:输出阴极(-)
参数特性:包括最大重复峰值反向电压(VRRM)、最大有效值电压(VRMS)、最大直流阻断电压(Voc)等。
功能详解:数据表提供了正向电流降额曲线、典型反向特性、正向特性、结电容、最大非重复峰值正向浪涌电流和瞬态热阻抗等图表。
应用信息:适用于单相半波60Hz的阻性或感性负载,对于电容性负载,需按20%降额电流。
封装信息:封装类型为MBS,提供了机械数据,包括尺寸、重量、引脚信息和推荐的安装垫尺寸。
MB34S 价格&库存
很抱歉,暂时无法提供与“MB34S”相匹配的价格&库存,您可以联系我们找货
MB34S
  • 1+0.72749
  • 100+0.67899
  • 300+0.63049
  • 500+0.58200
  • 2000+0.55775
  • 5000+0.54320
MB34S
  • 5+1.52259
  • 50+1.26134
  • 150+1.14934
  • 500+1.00959
库存:1555
