S5MB
S5MB
    JINGDAO(晶导微电子)
    SMB(DO-214AA)
    二极管配置:独立式 直流反向耐压(Vr):1kV 平均整流电流(Io):5A 正向压降(Vf):1.1V@5A 反向电流(Ir):10μA@1kV
S5MB 数据手册
山东晶导微电子股份有限公司 S5AB THRU S5MB Jingdao Microelectronics co.LTD Surface Mount General Purpose Silicon Rectifiers Reverse Voltage - 50 to 1000 V PINNING Forward Current - 5 A PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 2 1 Top View MECHANICAL DATA • Case: SMB • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.095g / 0.003oz Marking Code: S5A~S5M Simplified outline SMB and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols Parameter S5AB S5BB S5DB S5GB S5JB S5KB S5MB Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current I F(AV) 5 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 200 A Maximum Instantaneous Forward Voltage at 5 A VF 1.1 V IR 10 100 μA Cj 40 pF RθJA RθJC 48 16 °C/W T j , T stg -55 ~ +150 °C Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance Typical Thermal Resistance (1) (2) Operating and Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2017.08 SMB-A-S5AB~S5MB-5A1KV Page 1 of 3 山东晶导微电子股份有限公司 S5AB THRU S5MB Jingdao Microelectronics co.LTD Fig.2 Typical Instaneous Reverse Characteristics Average Forward Current (A) 6.0 5.0 4.0 3.0 2.0 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current ( μ A) Fig.1 Forward Current Derating Curve 100 T J =150°C T J =125°C 10 T J =100°C 1.0 T J =75°C 0.1 T J =25°C 0.01 0 600 800 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 10 Junction Capacitance ( pF) Instaneous Forward Current (A) 400 200 Instaneous Reverse Voltage (V) Case Temperature (°C) 1.0 100 T J =25°C 10 T J =25°C 0.1 0.4 1 0.6 0.8 1.0 1.2 1.4 1.6 1.8 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 200 160 120 80 40 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2017.08 www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 S5AB THRU S5MB Jingdao Microelectronics co.LTD PACKAGE OUTLINE SMB Plastic surface mounted package; 2 leads L A A1 C A b D E E1 VM A SMB mechanical data UNIT mm mil A1 L C b 5.59 0.20 1.5 0.305 2.2 3.3 5.08 0.05 0.8 0.152 1.9 155 220 7.9 59 12 87 200 2.0 32 6 75 A E D max 2.44 4.70 3.94 min 2.13 4.06 max 96 185 min 84 130 160 E1 The recommended mounting pad size Marking Type number S5AB 2.2 (86) 2.4 (94) 2.8 (110) 2.4 (94) mm Unit : (mil) 2017.08 JD708229B5 Marking code S5A S5BB S5B S5DB S5D S5GB S5G S5JB S5J S5KB S5K S5MB S5M Page 3 of 3
很抱歉,暂时无法提供与“S5MB”相匹配的价格&库存,您可以联系我们找货
S5MB
  • 10+0.27310
  • 100+0.20350
  • 300+0.17760
  • 3000+0.15860
  • 6000+0.14350
  • 9000+0.13580
库存:6600
S5MB
  • 1+0.27940
  • 200+0.18040
  • 1500+0.15620
  • 3000+0.13970
库存:16368
S5MB
  • 20+0.31100
  • 100+0.23270
  • 800+0.18030
  • 3000+0.13070
  • 6000+0.12420
  • 30000+0.11500
库存:4367
S5MB
  • 10+0.28113
  • 100+0.22508
  • 300+0.19710
  • 3000+0.17615
  • 6000+0.15930
  • 9000+0.15088
库存:15550
