山东晶导微电子股份有限公司
S1A THRU S1M
Jingdao Microelectronics co.LTD
Surface Mount General Purpose Silicon Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 1 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: S1A~S1M
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
S1A
S1B
S1D
S1G
S1J
S1K
S1M
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
30
A
Maximum Instantaneous Forward Voltage at 1 A
VF
1.1
V
IR
5
50
μA
Cj
15
pF
RθJA
75
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
Typical Thermal Resistance
(1)
(2)
Operating and Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.01
SMA-A-S1A~S1M-1A1KV
Page 1 of 3
山东晶导微电子股份有限公司
S1A THRU S1M
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
0.0
25
75
50
100
125
150
175
Instaneous Reverse Current(μ A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Junction Capacitance ( pF)
TJ =
2 5°
C
00
=1
TJ
=1
25
°C
°C
0.5
TJ
Instaneous Forward Current (A)
1.0
0.8
0.9
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
0.2
0.1
0.6
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
100
T J =25°C
10
1
0.7
1.0
1.1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
40
35
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
S1A THRU S1M
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
The recommended mounting pad size
a
0.3
12
Marking
Type number
2.4
(94)
mm
Unit :
(mil)
2016.01
S1A
S1A
S1B
S1B
S1D
S1D
S1G
S1G
S1J
S1J
S1K
S1K
S1M
S1M
1.8
(71)
1.8
(71)
1.8
(71)
Marking code
JD601134B6
Page 3 of 3
很抱歉,暂时无法提供与“S1A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08360
- 500+0.06556
- 1500+0.05552
- 5000+0.04947
- 国内价格
- 50+0.05339
- 500+0.04805
- 5000+0.04449
- 10000+0.04271
- 30000+0.04093
- 50000+0.03987
