US3AB THRU US3MB
Surface Mount Ultrafast Recovery Rectifier
Reverse Voltage – 50V~1000 V
PINNING
Forward Current – 3.0 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• High efficiency
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Marking Code: US3A~US3M
Simplified outline SMB symbol
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.095g / 0.003oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
US3AB
US3BB
US3DB
US3GB
US3JB
US3KB
US3MB
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Parameter
Maximum Average Forward Rectified Current
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
90
A
Maximum Instantaneous Forward Voltage at 3 A
VF
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Maximum Reverse Recovery Time (1)
Typical Thermal Resistance
Operating and Storage Temperature Range
1.3
1.68
5
100
IR
t rr
(2)
1.0
μA
75
50
V
ns
RθJA
RθJC
45
15
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMB-U-US3AB~US3BM-3A1KV
Page 1 of 3
US3AB THRU US3MB
Fig.2 Typical Reverse Characteristics
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Maximum Average Forward Current Rating
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
T J =25°C
1.0
US3AB~US3DB
US3GB
0.1
US3JB~US3MB
0.01
0.001
1.0
1.5
60
80
100
120
140
2.0
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
2.5
1
10
100
Number of Cycles
Instaneous Forward Voltage (V)
2017.01
40
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Typical Forward Characteristics
10
percent of Rated Peak Reverse Voltage (%)
www.sdjingdao.com
Page 2of 3
US3AB THRU US3MB
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
E1
The recommended mounting pad size
Marking
Type number
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
2017.01
JD704228B4
Marking code
US3AB
US3A
US3BB
US3B
US3DB
US3D
US3GB
US3G
US3JB
US3J
US3KB
US3K
US3MB
US3M
Page 3 of 3
很抱歉,暂时无法提供与“US3MB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.47740
- 100+0.28470
- 800+0.19930
- 3000+0.14240
- 6000+0.13520
- 30000+0.12520
- 国内价格
- 1+0.26730
- 200+0.17270
- 1500+0.15070
- 3000+0.13310
- 国内价格
- 20+0.27422
- 200+0.21654
- 600+0.18447
- 3000+0.16524
- 9000+0.14861
