山东晶导微电子有限公司
RS2AF THRU RS2MF
Jingdao Microelectronics
Surface Mount Fast Recovery Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 2 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Fast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: RS2A-RS2M
MECHANICAL DATA
• Case: SMAF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 27mg / 0.00095oz
Simplified outline SMAF and symbol
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
RS2AF
RS2BF
RS2DF
RS2GF
RS2JF
RS2KF
RS2MF
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
50
A
Maximum Forward Voltage at 2 A
VF
1.3
V
IR
5
100
μA
Cj
22
pF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
t rr
150
250
500
ns
RθJA
RθJC
65
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.01
SMAF-F-RS2AF~RS2MF-2A1KV
Page 1 of 3
山东晶导微电子有限公司
RS2AF THRU RS2MF
Fig.2 Typical Reverse Characteristics
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.5
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
RS2AF THRU RS2MF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
HE
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.2
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
47
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
Marking
1.6
(63)
1.8
(71)
2.2
(86)
mm
Unit :
(mil)
2016.01
7°
The recommended mounting pad size
1.6
(63)
g
pad
e
E
A
pad
D
E
A
V M
JD512256B0
Type number
Marking code
RS2AF
RS2A
RS2BF
RS2B
RS2DF
RS2D
RS2GF
RS2G
RS2JF
RS2J
RS2KF
RS2K
RS2MF
RS2M
Page 3 of 3
很抱歉,暂时无法提供与“RS2MF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.08680
- 30+0.08370
- 100+0.08060
- 500+0.07440
- 1000+0.07130
- 2000+0.06944
- 国内价格
- 20+0.20650
- 100+0.12800
- 800+0.08450
- 3000+0.06040
- 6000+0.05740
- 30000+0.05310
- 国内价格
- 50+0.13511
- 500+0.10649
- 3000+0.09062
- 6000+0.08111
