2SC3357-RE
2SC3357-RE
    SK(時科)
    SOT89-3
    100nA 12V 1.2W 150@20mA,10V 100mA 6.5GHz NPN +150℃@(Tj) SOT-89-3
2SC3357-RE 数据手册
NPN SILICON RF TRANSISTOR Feature High gain:︱S21e︱2 TYP. Value is 10dB Low noise: NF TYP. Value is 1.7dB fT (TYP.) : TYP. Value is 6.5GHz @ VCE=10V,IC=20mA,f=1GHz @ VCE=10V,IC=7mA,f=1GHz @ VCE=10V,IC=20mA,f=1GHz PIN DEFINITION: 1: (Base) 2: (Collector) 3: (Emitter) SOT-89 Absolute Maximum Ratings TA=25℃ Unless Otherwise noted PARAMETER Collector-base breakdown voltage Collector-emitter breakdown voltage Emitter-base breakdown voltage Collector current *Collector Power Dissipation Junction Temperature Storage Temperature SYMBLE MAXIMUM VALUE UNIT VCBO VCEO VEBO IC *PD Tj Tstg 20 12 3 100 1.2 150 -65 ~ +150 V V V mA W ℃ ℃ *With heat dissipation panel hFE Classification Classification A B Marking RH RF hFE 60~100 90~140 C D E RE 130~180 1 of 3 170~250 250~300 ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) PARAMETER SYMBLE MIN. Collector-base breakdown voltage VCBO VCEO ICBO IEBO hFE fT Collector- Emitter breakdown voltage Collector cut-off current Emitter cut-off current DC current gain Transit frequency Power gain Cre | S21e |2 Noise factor NF Output feedback capacitance UNIT TEST CONDITION 20 V 12 V μA μA IC=1.0μA IC=100μA VCB=10V VEB=1V VCE=10V,IC=20mA VCE=10V,IC=20mA VCB=10V,IE=0mA,f=1MHz VCE=10V,IC=20mA,f=1GHz VCE=10V,IC=40mA,f=1GHz VCE=10V,Ic=7mA,f=1GHz 60 TYP. 150 MAX. 0.1 0.1 300 6.5 0.65 9 Package &Dimension: SOT-89 2 of 3 10 2.6 3.2 1.7 2.3 GHz pF dB dB 3 of 3
2SC3357-RE 价格&库存
很抱歉,暂时无法提供与“2SC3357-RE”相匹配的价格&库存,您可以联系我们找货
2SC3357-RE
  • 5+0.51208
  • 50+0.40169
  • 150+0.34659
  • 1000+0.31857
  • 2000+0.28553
  • 5000+0.26891
库存:8130
