ABF2 THRU ABF10
Voltage Range - 200 to 1000 V olts
Current - 1.2Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
ABF
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic technique
High temperature soldering guaranteed: 260°/10 seconds at 5
lbs., (2.3kg) tension
Small size, simple installation
High surge current capability
Glass passivated chip junction
(1)
(2)
Mechanical Data
Case : JEDEC ABF Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : 82mg 0.0029oz
(3)
(4)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per leg at 1.2A
Maximum DC reverse current
TA=25°C
TA=125°C
at rated DC blocking voltage
Typical thermal resistance
Typical junction capacitance
Operating temperature range
storage temperature range
MDD
MDD
MDD
MDD
MDD
ABF2
ABF4
ABF6
ABF8
ABF10
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
1.2
V
V
V
A
IFSM
40
A
VF
1.1
V
IR
5
100
uA
RθJA
RθJC
70
18
°C/W
Cj
TJ
18
-55 to +150
°C
TSTG
-55 to +150
°C
VRRM
VRMS
VDC
IF(AV)
pF
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
DN:T21308A1
http://www.microdiode.com
Rev:2021A1
Page :1
ABF2 THRU ABF10
Current - 1.2Ampere
Ratings And Characteristic Curves
Fig.1 Average Rectified Output Current
Derating Curve
Fig.2 Typical Reverse Characteristics
1.4
100
Instaneous Reverse Current(uA)
Average Rectified Output Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
TJ=125°C
10
1.0
TJ=25°C
0.1
175
00
Case Temperature (°C)
60
80
100
120
140
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Fig.4 Typical Junction Capacitance
Characteristics TJ=25°C
100
TJ=25°C
Junction Capacitance (pF)
Instaneous Forward Current (A)
10
1.0
0.1
pulse with 300us
1% duty cycle
0.01
10
1
00..
00
0.5
1.0
1.5
2.0
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
50
40
30
8.3 ms Single Half Sine Wave (JEDEC
Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2021A1
Page :2
ABF2 THRU ABF10
Current - 1.2 Ampere
Suggested Pad Layout
Q1
P1
Dim
Min
P1
5.72
P2
4.00
Q1
1.00
Q2
0.90
Q2
P2
Dimensions in millimeters
Rev:2021A1
Page :3
很抱歉,暂时无法提供与“ABF10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.18359
- 100+0.17159
- 500+0.15959
- 2000+0.14159
- 5000+0.13559
- 10000+0.13199
