山东晶导微电子有限公司
SS32C THRU SS320C
Jingdao Microelectronics
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V
Forward Current - 3 A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Marking Code: SS32 ~ SS320
Simplified outline SMC and symbol
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.22g / 0.0077oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Parameter
Symbols
SS32C
SS34C
SS36C
SS38C
SS310C
SS312C
SS315C
SS320C
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
3.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
80
A
Max Instantaneous Forward Voltage at 3 A
VF
Maximum DC Reverse Current T a = 25°C
T a =100°C
IR
0.5
5
0.3
3
mA
Typical Junction Capacitance(1)
Cj
450
350
pF
Typical Thermal Resistance (2)
RθJA
50
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
at Rated DC Reverse Voltage
Operating Junction Temperature Range
Storage Temperature Range
0.55
0.70
0.85
0.95
V
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.04
SMC-S-SS32C~SS320C-3A200V
Page 1 of 3
山东晶导微电子有限公司
SS32C THRU SS320C
Fig.2 Typical Reverse Characteristics
3.5
3.0
2.4
1.8
1.2
0.6
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
10 4
T J =100°C
10 3
T J =75°C
10
2
SS32C/SS36C
T J =25°C
10 0
Case Temperature (°C)
60
80
100
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1.0
SS32C/SS34C
SS36C/SS38C
SS310C/SS312C
SS315C/SS320C
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
200
100
SS32C~SS36C
SS38C~SS320C
10
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
80
70
60
50
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
500
1.8
90
30
1000
Instaneous Forward Voltage (V)
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Peak Forward Surage Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
100
Number of Cycles at 60Hz
2017.04
SS38C~SS320C
10 1
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SS32C THRU SS320C
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
3.8
(150)
4.1
(160)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
2017.04
706305A0
Type number
Marking code
SS32C
SS32
SS34C
SS34
SS36C
SS36
SS38C
SS38
SS310C
SS310
SS312C
SS312
SS315C
SS315
SS320C
SS320
Page 3 of 3
很抱歉,暂时无法提供与“SS32C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.65540
- 100+0.39100
- 800+0.27370
- 3000+0.19550
- 6000+0.18570
- 30000+0.17200
- 国内价格
- 10+0.35726
- 100+0.28318
- 300+0.24624
- 3000+0.21843
- 6000+0.19628
- 9000+0.18509
- 国内价格
- 10+0.32417
- 100+0.25696
