2SC1623
2SC1623
    MDD(辰达半导体)
    SOT-23
    NPN IC(集电极最大电流)=100mA PD(最大功率)=200mW 应用:通讯模块、工业控制、人工智能、消费电子
2SC1623 数据手册
2SC1623 SOT-23 Plastic-Encapsulate Transistors 2SC1623 TRANSISTOR (NPN) SOT-23 FEATURES z High DC current gain :hFE=200(Typ) VCE= 6V,IC=1mA z High voltage:VCEO=50V 1. BASE 2. EMITTER MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter 3. COLLECTOR Value Unit VCBO Collector-Base Voltage 60 V VCEO Collector-Emitter Voltage 50 V VEBO Emitter-Base Voltage 5 V IC Collector Current 100 mA PC Collector Power Dissipation 200 mW Thermal Resistance From Junction To Ambient 625 ℃/W Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ RΘJA ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Typ Symbol ol Test conditions Collector-base breakdown voltage V(BR)CBO IC=100μA,IE=0 60 V Collector-emitter breakdown voltage V(BR)CEO IC=1mA,IB=0 50 V Emitter-base breakdown voltage V(BR)EBO IE=100μA,IC=0 5 V Collector cut-off current ICBO VCB=60V,IE=0 0.1 μA Emitter cut-off current IEBO VEB=5V,IC=0 0.1 μA DC current gain hFE VCE=6V,IC=1mA Parameter Min 90 200 Max Unit 600 Collector-emitter saturation voltage VCE(sat) IC=100mA,IB=10mA 0.3 V Base-emitter saturation voltage VBE(sat) IC=100mA,IB=10mA 1 V fT Transition frequency VCE=6V,IC=10mA 250 MHz CLASSIFICATION OF hFE Rank Range Marking http://www.microdiode.com L4 L5 L6 L7 90-180 135-270 200-400 300-600 L4 L5 L6 L7 Rev:2024A1 Page :1 2SC1623 Typical Characteristics Static Characteristic 4 10uA 3 IC 8uA 6uA 5uA 4uA 3uA 1 IC Ta=25℃ DC CURRENT GAIN 7uA 2 —— Ta=100℃ hFE (mA) 9uA COLLECTOR CURRENT hFE 1000 COMMON EMITTER Ta=25℃ 100 2uA COMMON EMITTER VCE= 6V IB=1uA 0 0 2 4 6 COLLECTOR-EMITTER VOLTAGE VBEsat —— Ta=25℃ Ta=100 ℃ 10 IC COLLECTOR CURREMT IC IC Ta=100 ℃ Ta=25℃ β=10 10 0.1 100 1 10 COLLECTOR CURREMT (mA) VBE fT 1000 —— IC 100 (mA) IC T =2 5℃ a TRANSITION FREQUENCY 10 T =1 00℃ a COLLECTOR CURRENT IC fT (mA) (MHz) —— 100 (mA) 100 β=10 1 100 —— 10 IC 300 1000 100 0.1 1 COLLECTOR CURRENT VCEsat IC COLLECTOR-EMITTER SATURATION VOLTAGE VCEsat (mV) BASE-EMITTER SATURATION VOLTAGE VBEsat (mV) 2000 10 0.1 8 VCE (V) 1 COMMON EMITTER VCE=6V 0.1 0.0 0.6 0.3 0.9 100 COMMON EMITTER VCE=6V Ta=25℃ 10 1.2 1 COLLECTOR CURRENT BASE-EMMITER VOLTAGE VBE (V) 50 Cob/Cib —— VCB/VEB COLLECTOR POWER DISSIPATION PC (mW) Ta=25 ℃ 10 Cib C (pF) PC 250 f=1MHz IE=0/IC=0 CAPACITANCE 70 10 Cob 1 —— IC (mA) Ta 200 150 100 50 0 0.1 0.1 1 REVERSE VOLTAGE http://www.microdiode.com 10 V (V) 20 0 25 50 75 AMBIENT TEMPERATURE Rev:2024A1 100 Ta 125 150 (℃ ) Page :2 2SC1623 Outlitne Drawing SOT-23 Package Outline Dimensions e Suggested Pad Layout 0.037 0.95 0.037 0.95 L L1 E E1 Symbol A A1 b c D E E1 e L L1 θ Dimensions In Millimeters Min Typ Max 0.90 1.40 0.10 0.00 0.30 0.50 0.20 0.08 2.80 2.90 3.10 1.20 1.60 2.80 2.25 1.80 1.90 2.00 0.10 0.50 0.4 0° 0.55 10° Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 http://www.microdiode.com inches mm Rev:2024A1 Page :3 2SC1623 SOT-23 Tape and Reel Packaging Description: SOT-23 parts are shipped in tape. The carrier tape is made from a dissipative (carbon filled) polycarbonate resin. The cover tape is a multilayer film (Heat Activated Adhesive in nature) primarily composed of polyester film,adhesive laye,sealant, and anti-static sprayed agent.These reeled parts In standard option are shipped with 3,000 units per 7" or 17.8cm diameter reel. The reels are clear in color and is made of polystyrene plastic (anti-static coated). 3000 pcs http://www.microdiode.com 7 Inch 45,000 pcs 203×203×195 180,000 pcs 438×438×220 Rev:2024A1 Page :4
2SC1623 价格&库存
很抱歉,暂时无法提供与“2SC1623”相匹配的价格&库存,您可以联系我们找货
2SC1623
库存:1423
2SC1623
  • 10+0.08539
  • 100+0.06946
  • 300+0.06066
  • 3000+0.04568
  • 6000+0.04107
  • 9000+0.03856
库存:1126
