S9015
SOT-23 Plastic-Encapsulate Transistors
S9015
TRANSISTOR (PNP)
SOT-23
FEATURES
z Complementary To S9014
1. BASE
MARKING: M6
2. EMITTER
3. COLLECTOR
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
-50
V
VCEO
Collector-Emitter Voltage
-45
V
VEBO
Emitter-Base Voltage
-5
V
IC
Collector Current-Continuous
-100
mA
PC
Collector Power Dissipation
200
mW
Thermal Resistance From Junction To Ambient
625
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RΘJA
ELECTRICAL CHARACTERISTICS (Ta= 25℃ unless otherwise specified)
Parameter
Symbol
ol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=-100μA, IE=0
-50
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=-0.1mA,IB=0
-45
V
Emitter-base breakdown voltage
V(BR)EBO
IE=-100μA,IC=0
-5
V
Collector cut-off current
ICBO
VCB=-50V, IE=0
-0.1
μA
Emitter cut-off current
IEBO
VEB=-5V, IC=0
-0.1
μA
DC current gain
hFE
VCE=-5V, IC=-1mA
200
1000
Collector-emitter saturation voltage
VCE(sat)
IC=-100mA, IB=-10mA
-0.3
V
Base-emitter saturation voltage
VBE(sat)
IC=-100mA, IB=-10mA
-1
V
Transition frequency
fT
VCE=-5V, IC=-10mA f=30MHz
150
MHz
CLASSIFICATION OF hFE
Rank
L
H
Range
200-450
400-1000
http://www.microdiode.com
Rev:2024A1
Page :1
S9015
Typical Characteristics
Static Characteristic
-8
hFE
EMITTER
-18uA
(mA)
-6
DC CURRENT GAIN
-14uA
-12uA
-4
Ta=25℃
hFE
-16uA
IC
COLLECTOR CURRENT
Ta=100℃
Ta=25℃
-20uA
—— IC
1000
COMMON
-10uA
-8uA
-6uA
-2
100
-4uA
COMMON EMITTER
VCE= -5V
IB=-2uA
-0
-0
-2
-4
-6
COLLECTOR-EMITTER VOLTAGE
VCEsat
COLLECTOR-EMITTER
SATURATION VOLTAGE VCEsat (V)
-1
VCE
10
-0.1
-8
-1
-10
COLLECTOR CURRENT
(V)
IC
VBEsat
IC
-100
(mA)
IC
-2
-1
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
Ta=25℃
-0.1
Ta=100℃
Ta=25℃
Ta=100℃
β=10
β=10
-0.1
-0.01
-1
-10
COLLECTOR CURRENT
fT
1000
-1
COMMON EMITTER
VCE=-5V
-0.6
(mA)
IC
COMMON EMITTER
VCE=-5V
Ta=25℃
10
-0.1
-1.2
-0.9
100
-1
BASE-EMMITER VOLTAGE VBE (V)
Cob/ Cib
-100
IC
fT
Ta=25℃
-0.3
-10
COLLECTOR CURRENT
Ta=100℃
-0.1
-0.0
-1
(mA)
-10
COLLECTOR CURRENT
(mA)
IC
IC
—— VBE
IC
-100
-0.2
-100
TRANSITION FREQUENCY
(MHz)
-0.2
-10
COLLECTOR CURRENT
—— VCB/ VEB
PC
30
IC
-100
(mA)
Ta
250
f=1MHz
IE=0/IC=0
200
10
COLLECTOR POWER
DISSIPATION PC (mW)
C
(pF)
Ta=25 ℃
Cib
CAPACITANCE
Cob
150
100
50
-0.1
-1
REVERSE VOLTAGE
-10
VR
(V)
-20
50
75
AMBIENT TEMPERATURE
Rev:2024A1
100
Ta
125
150
Page :2
S9015
Outlitne Drawing
SOT-23 Package Outline Dimensions
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
0.90
1.40
0.10
0.00
0.30
0.50
0.20
0.08
2.80
2.90
3.10
1.20
1.60
2.80
2.25
1.80
1.90
2.00
0.10
0.50
0.4
0°
0.55
10°
Note:
1. Controlling dimension:in/millimeters.
2. General tolerance: ±0.05mm.
3. The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2024A1
Page :3
S9015
SOT-23 Tape and Reel
Packaging Description:
SOT-23 parts are shipped in tape. The carrier
tape is made from a dissipative (carbon filled)
polycarbonate resin. The cover tape is a multilayer
film (Heat Activated Adhesive in nature) primarily
composed of polyester film,adhesive laye,sealant,
and anti-static sprayed agent.These reeled parts In
standard option are shipped with 3,000 units per 7"
or 17.8cm diameter reel. The reels are clear in color
and is made of polystyrene plastic (anti-static
coated).
3000 pcs
7 Inch
45,000 pcs
203×203×195
180,000 pcs
438×438×220
Rev:2024A1
Page :4
很抱歉,暂时无法提供与“S9015”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.03920
- 600+0.03772
- 1200+0.03734
- 3000+0.03659
- 国内价格
- 20+0.14710
- 100+0.09140
- 800+0.06040
- 3000+0.04310
- 6000+0.04090
- 30000+0.03790
- 国内价格
- 10+0.04277
- 100+0.04180
- 300+0.04115
- 1000+0.04061
- 国内价格
- 1+0.20790
- 200+0.06919
- 1500+0.04323
- 3000+0.03432
