BZT52B27
BZT52B27
    PSI(宝力芯)
    SOD123
    稳压二极管 Vz=27V 26.46~27.54V Izt=5mA P=500mW SDO123
BZT52B27 数据手册
DATA SHEET BZT52-B2V4 SERIES SURFACE MOUNT ZENER DIODE VOLTAGE 2.4~75 V POWER 500 mW FEATURES z PLANAR DIE CONSTRUCTION z 500mW POWER DISSIPATION z ZENER VOLTAGES FROM 2.4~75V z IDEALLY SUITED FOR AUTOMATED ASSEMBLY PROCESSES z LEAD FREE AND HALOGEN-FREE MECHANICAL DATA z CASE: SOD-123, MOLDED PLASTIC z TERMINALS: SOLDERABLE PER MIL-STD-202, METHOD 208 z POLARITY: SEE DIAGRAM BELOW z APPROX. WEIGHT: 0.01 GRAMS z MOUNTING POSITION: ANY CASE: SOD-123 MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS RATINGS AT 25°C AMBIENT TEMPERATURE UNLESS OTHERWISE SPECIFIED. PARAMETER SYMBOL VALUE MAXIMUM FORWARD VOLTAGE DROP AT IF=10mA VF 0.9 PD 500 MAXIMUM POWER DISSIPATION AT 25°C (NOTE.1) JUNCTION TEMPERATURE RANGE TJ -65 TO +150 STORAGE TEMPERATURE RANGE TSTG -65 TO +150 THERMAL RESISTANCE, JUNCTION TO AMBIENT AIR RθJA 250 NOTE: 1. VALID PROVIDED THAT DEVICE TERMINALS ARE KEPT AT AMBIENT TEMPERATURE. UNITS V mW °C °C °C/W PAGE.1 Nominal Zener Voltage Part Number VZ @ IZT Nom. V Max Reverse Leakage Current Max. Zener Impedance ZZT @ IZT ZZK @ IZK IR @ VR Min. V Max. V Ω mA Ω mA μA V 500mWatts Zener Diodes BZT52-B2V4 2.4 2.35 2.45 94 5 564 1.00 45 1 BZT52-B2V7 2.7 2.65 2.75 94 5 564 1.00 18 1 BZT52-B3V0 3.0 2.94 3.06 89 5 564 1.00 9 1 BZT52-B3V3 3.3 3.23 3.37 89 5 564 1.00 4.5 1 BZT52-B3V6 3.6 3.53 3.67 84 5 564 1.00 4.5 1 BZT52-B3V9 3.9 3.82 3.98 84 5 564 1.00 2.7 1 BZT52-B4V3 4.3 4.21 4.39 84 5 564 1.00 2.7 1 BZT52-B4V7 4.7 4.61 4.79 80 5 470 1.00 2.7 2 BZT52-B5V1 5.1 5.00 5.20 60 5 451 1.00 1.8 2 BZT52-B5V6 5.6 5.49 5.71 40 5 376 1.00 0.9 2 BZT52-B6V2 6.2 6.08 6.32 10 5 141 1.00 2.7 4 BZT52-B6V8 6.8 6.66 6.94 15 5 75 1.00 1.8 4 BZT52-B7V5 7.5 7.35 7.65 15 5 75 1.00 0.9 5 BZT52-B8V2 8.2 8.04 8.36 15 5 75 1.00 0.63 5 BZT52-B9V1 9.1 8.92 9.28 15 5 94 1.00 0.45 6 BZT52-B10 10 9.80 10.20 20 5 141 1.00 0.18 7 BZT52-B11 11 10.78 11.22 20 5 141 1.00 0.09 8 BZT52-B12 12 11.76 12.24 25 5 141 1.00 0.09 8 BZT52-B13 13 12.74 13.26 30 5 160 1.00 0.09 8 BZT52-B15 15 14.70 15.30 30 5 188 1.00 0.045 10.5 BZT52-B16 16 15.68 16.32 40 5 188 1.00 0.045 11.2 BZT52-B18 18 17.64 18.36 45 5 212 1.00 0.045 12.6 BZT52-B20 20 19.60 20.40 55 5 212 1.00 0.045 14.0 BZT52-B22 22 21.56 22.44 55 5 235 1.00 0.045 15.4 BZT52-B24 24 23.52 24.48 70 5 235 1.00 0.045 16.8 BZT52-B27 27 26.46 27.54 80 2 282 0.50 0.045 18.9 BZT52-B30 30 29.40 30.60 80 2 282 0.50 0.045 21.0 BZT52-B33 33 32.34 33.66 80 2 306 0.50 0.045 23.0 BZT52-B36 36 35.28 36.72 90 2 329 0.50 0.045 25.2 BZT52-B39 39 38.22 39.78 130 2 329 0.50 0.045 27.3 BZT52-B43 43 42.14 43.86 141 5 353 0.50 0.045 30.1 BZT52-B47 47 46.06 47.94 160 5 353 0.50 0.045 33.0 BZT52-B51 51 49.98 52.02 169 5 376 0.50 0.045 35.7 BZT52-B56 56 54.88 57.12 188 5 400 0.50 0.045 39.2 BZT52-B62 62 60.76 63.24 202 5 423 0.50 0.045 43.4 BZT52-B68 68 66.64 69.36 226 5 447 0.50 0.045 47.6 BZT52-B75 75 73.50 76.50 240 5 470 0.50 0.045 52.5 PAGE.2 TA=25°C 0.4 CAPACITANCE, (PF) POWER DISSIPATION, (W) 1000 0.5 0.3 0.2 0.1 0V BIAS 100 1V BIAS 10 0 BIASAT 50% OF VZ NOM 1 0 25 50 75 100 125 1 150 TEMPERATURE, (°C) TA=25°C 40 100 Fig.2-TYPICAL CAPACITANCE 30 B2V7 B4V7 30 B10 B5V6 B6V8 ZENER CURRENT, (mA) 50 10 NORMAL ZENER VOLTAGE, (V) Fig.1-STEADY STATE POWER DERATING ZENER CURRENT, (mA) TJ=25℃ f=1MHz B8V2 B3V3 20 10 0 TA=25°C B18 B27 B36 20 B43 B51 10 B75 B62 0 0 1 2 3 4 5 6 7 8 9 10 VZ, ZENER VOLTAGE, (V) Fig.3-VZ=2.7 THRU 8.2 VOLTS 0 10 20 30 40 50 60 70 80 VZ, ZENER VOLTAGE, (V) Fig.4-VZ=10 THRU 75VOLTS LEAKAGE CURRENT, (uA) 1000 100 10 +150°C 1 0.1 0.01 +25°C 0.001 0.0001 -55°C 0.00001 0 10 20 30 40 50 60 70 80 90 NORMAL ZENER VOLTAGE, (V) Fig.5-TYPICAL LEAKAGE CURRENT PAGE.3 SOD-123 DIMENSION Symbol L L1 W W1 H H1 Dimensions In Millimeters Min Max 3.55 3.85 2.60 2.80 1.50 1.70 0.45 0.65 1.05 1.25 0.55 0.75 Dimensions In Inches Min Max 0.140 0.152 0.102 0.110 0.059 0.067 0.018 0.026 0.041 0.049 0.022 0.030 PAGE.4
BZT52B27 价格&库存
很抱歉,暂时无法提供与“BZT52B27”相匹配的价格&库存,您可以联系我们找货
