BDFN2C051L
Transient Voltage Suppressors
ROHS
Features
Protects one I/O or Power Line
Completely Compatible with SOD923
Low Clamping Voltage
Working Voltage: 5V
Low Leakage Current
Response Time is Typically < 1 ns
DFN-2L
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±15kV (air), ±10kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Mechanical Characteristics
JEDECDFN-2L package (0402
size)
Molding compound flammability
rating: UL 94V-0
Marking : Marking Code
RoHS Compliant
Applications
Cellular Handsets & Accessories
Personal Digital Assistants (PDAs)
Notebooks & Handhelds
Portable Instrumentation
Digital Cameras
MP3 Players
Schematic & PIN Configuration
Bi irectional
1/4
BDFN2C051L
ROHS
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp = 8/20μs )
PPP
100
Watts
Peak Forward Voltage ( IF = 1A, tp = 8/20μs )
VFP
1.5
V
Operating Temperature
TJ
-55 to + 125
TSTG
-55 to +150
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
Parameter
I PP
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
VC VBR VRWM
IT
IR
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
I
IR
I
T
VRWM VBR VC
I PP
Electrical Characteristics
BDFN2C051L
Parameter
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
5.0
V
VBR
IT=1mA
6.0
V
IR
VRWM=5V, T=25℃
0.5
μA
Peak Pulse Current
IPP
tp =8/20μs
3
A
Clamping Voltage
VC
IPP=1A, tp=8/20μs
9.5
V
Clamping Voltage
VC
IPP=4A, tp=8/20μs
11
V
Junction Capacitance
Cj
VR =0V, f =1MHz
1.5
pF
2/4
V
BDFN2C051L
ROHS
Typical Characteristics
Figure 2: Power Derating Curve
Time
10
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power Vs Pulse
1
100W 8/20µs
Waveform
0.1
0.01
0.1
1
10
100
td – Pulse Duration - µs
110
100
90
80
70
60
50
40
30
50
75
100
125
150
Ambient Temperature - TA (℃)
Figure 4: Normalized Junction Capacitance
vs. Reverse Voltage
Figure 3: Clamping Voltage vs. Peak Pulse
Current
1.1
14
13
12
11
10
9
8
7
6
5
4
3
2
1
F=1MHz
0.9
Cj(VR)/Cj(VR =0)
Clamping Voltage -Vc(V)
25
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
2
3
4
5
6
7
8
9
Peak Pulse Current Ipp(A)
2
3
5
Figure 6: ESD Clamping( 8kV Contact per
IEC 61000-4-2)
Figure 5: Pulse Waveform
Tek Run: 2.50GS/s
110
4
Reverse Voltage -VR(V)
Sample
Waveform
Paramters tr=8µs
td=20µs
100
90
Percent Ipp
80
70
e-t
60
50
40
td=Ipp/2
30
10
15
30
CH1 10.0 VΩ
M 20.0ns Ch1
7V
Time
(µs)
3/4
BDFN2C051L
ROHS
Outline Drawing – DFN-2L
PACKAGE OUTLINE
D
e
h
2
1
L2
L1
1
SYMB
OL
A
A1
b
C
D
e
E
L
L1
h
b
E
h
L1
A1
C
A
BOTTOM VIEW
Land Pattern
DFN-2L
MILIMETER
MIN
NOM
MAX
0.45
0.50
0.55
0.05
0.45
0.50
0.55
0.12
0.15
0.18
0.95
1.00
1.05
0.65BSC
0.55
0.60
0.65
0.20
0.25
0.30
0.05REF
0.07
0.12
0.17
1.00
0.60
0.30
0.35
0.35
Marking Codes
Part Number
BDFN2C051L
Marking Code
VB
Package Information
Qty:10k/Reel
4/4
很抱歉,暂时无法提供与“BDFN2C051L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20507
- 1000+0.13476
- 4000+0.10533
- 10000+0.10099
