BDFN2C051RF2
Transient Voltage Suppressors
ROHS
Features
Small Body Outline Dimensions:
0.039″x 0.024″(1.0 mm x 0.60 mm)
Protects one I/O or power line
Low Clamping Voltage
Ultra Low Capacitance:0.2pF
Working Voltage: 5 V
Low Leakage Current
Response Time is Typically < 1 ns
DFN-2L
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±15kV (air), ±10kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Applications
Mechanical Characteristics
Laptop Computers
DFN-2L package
Molding compound flammability rating: UL
94V-0
Marking: Marking Code
Cellular Phones
Digital Cameras
ersonal Digital Assistants (PDAs)
Packaging: Tape and Reel per EIA 481
RoHS/WEEE Compliant
Schematic & PIN Configuration
DFN-2L (Top View)
1/4
BDFN2C051RF2
ROHS
Absolute Maximum Rating
Rating
Symbol
Value
Units
10 KV(contact)
VESD
Electrostatic discharge Voltage (See Note1 ,2)
Volts
15KV (air)
Operating Temperature
Storage Temperature
TJ
-55 to + 125
°C
TSTG
-55 to +150
°C
Electrical Parameters (T=25℃)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
Electrical Characteristics
BDFN2C051RF2
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Minimum
Typical
VRWM
Maximum
Units
5.0
V
VBR
IT=1mA
IR
VRWM=5V, T=25°C
0.1
0.5
μA
Clamping Voltage
VC
IPP=3A, tp=8/20μs
10
15
V
Peak Pulse Current
IPP
tp =8/20μs
3.0
A
Cj
VR = 0V, f= 1MHz
0.26
pF
Junction Capacitance
6.0
0.17
V
0.2
Note1: ESD Pulse Waveform according to IEC 61000-4-2. see Table1 and Figure4.
Note2:
ESD tests Setup see Figure 5.
2/4
BDFN2C051RF2
ROHS
Typical Characteristics
Figure 2: Power Derating Curve
10
110
1
45w 8/20µswaveform
0.1
0.01 0.1
1
10
100
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
90
80
70
60
50
40
30
td – Pulse Duration - µs
Ipp
80
70
-1
50
40
30
td=Ipp/2
14
12
10
Te
st
8
6
Waveform
Paramters
tr=8µs
td=20µs
4
10
2
10
150
18
Clamping Voltage–VC (V)
90
Waveform
Paramters
tr=8µs
td=20µs
100
Percent
100
Figure 4: Clamping Voltage vs.Ipp
110
e
75
Ambient Temperature - TA (℃)
Figure3: Pulse Waveform
60
50
15
Time (µs)
30
2
3
4
5
6
Peak Pulse Current–IPP (A)
3/4
BDFN2C051RF2
ROHS
Outline Drawing – DFN-2L
PACKAGE OUTLINE
D
e
h
2
1
L2
L1
1
SYMB
OL
A
A1
b
C
D
e
E
L
L1
h
b
E
h
L1
A1
C
A
BOTTOM VIEW
Land Pattern
DFN-2L
MILIMETER
MIN
NOM
MAX
0.45
0.50
0.55
0.05
0.45
0.50
0.55
0.12
0.15
0.18
0.95
1.00
1.05
0.65BSC
0.55
0.60
0.65
0.20
0.25
0.30
0.05REF
0.07
0.12
0.17
1.00
0.35
0.60
0.60
0.30
0.35
Marking Codes
Part Number
Marking Code
BDFN2C051RF2
5C
Package Information
Qty:10k/Reel
4/4
很抱歉,暂时无法提供与“BDFN2C051RF2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32346
- 100+0.26126
- 300+0.23015
- 1000+0.20682
- 5000+0.17140
- 10000+0.16200
- 国内价格
- 20+0.29650
- 1000+0.18959
- 4000+0.15711
- 国内价格
- 1+0.26070
- 500+0.17380
- 5000+0.15180
- 10000+0.13750
