ME2188
High Efficiency, synchronous PFM step-up DC-DC converter
General Description
Features
ME2188 Series is a PFM Step-up DC/DC converter
High efficiency:93%
IC with low supply current by CMOS process. High
Maximum frequency:320KHz
frequency noise that occurs during switching is reduced
Low Quiescent Current:7.5μA
by using advanced circuit designed, output voltage is
Input Voltage: 0.9V ~ 5.0V
programmable in 0.1V steps between 1.9V~5.0V and
Output Voltage Range:1.9V ~ 5.0V
maximum frequency is 320KHz(TYP.). A low ripple, high
High Accuracy: ± 2%
efficiency step-up DC/DC converter can be constructed
Low ripple and Low noise
of ME2188 with only two external components.
ME2188 is suitable for use with battery-powered
instruments with low noise and low supply current.
Typical Application
Package
Power source for battery-powered equipment
5-pin SOT23-5
Power source for Wireless mouse, toys, Cameras,
3-pin SOT23、SOT23-3、SOT89-3、TO92
VCRs, PDAs, MP3, and Led lighting etc
Typical Application Circuit
L 22uH
VOUT
LX
VIN
V11
CIN
10uF
CE
ME2188
GND
www.microne.com.cn
VOUT
COUT
100uF
RL
Page 1 of 13
ME2188
Selection Guide
ME 21 88 X X X G
Environment mark
Package
M3:SOT23-3
M5:SOT23-5
X:SOT23
P:SOT89-3
T:TO92
Output Voltage
30:3.0V
33:3.3V
Function
A:Without CE
C:Have CE
Product Type
Product Series
Microne
product series
product description
ME2188A22M3G
VOUT =2.2V,Without CE pin,Package:SOT23-3
ME2188A22TG
VOUT =2.2V,Without CE pin, Package :TO-92
ME2188A22XG
VOUT =2.2V,Without CE pin, Package :SOT23
ME2188A24TG
VOUT =2.4V,Without CE pin, Package :TO-92
ME2188A33M3G
VOUT =3.3V,Without CE pin,Package:SOT23-3
ME2188A33XG
VOUT =3.3V,Without CE pin, Package :SOT23
ME2188A33PG
VOUT =3.3V,Without CE pin, Package :SOT89-3
ME2188A33TG
VOUT =3.3V,Without CE pin, Package :TO-92
ME2188C33M5G
VOUT =3.3V,Have CE pin, Package :SOT23-5
NOTE: At present ,there are thirteen kinds of voltage value: 2.2V、2.3V、2.4V、2.5V、2.7V、2.8V、3.0V、
3.3V、3.6V、3.7V、4.0、4.5V、5.0V。
If you need other voltage and package, please contact our sales staff。
V11
www.microne.com.cn
Page 2 of 13
ME2188
Pin Configuration& Pin Assignment
VOUT
VOUT
3
3
1
2
1
LX
GND
1 2 3
5
4
1 2 3
2
1
GND
LX
SOT23
GND
CE VOUT NC
LX
SOT23-3
2
3
GND VOUT LX
GND VOUT LX
SOT89-3
TO92
SOT23-5
Pin Assignment
PIN Number
Pin Name
Description
3
LX
Switch pin
2
2
VOUT
Voltage output
1
CE
Chip enable
1
4
1
1
GND
Ground
3
NC
NC
SOT23/ SOT23-3
SOT23-5
SOT89-3
TO92
2
5
3
3
2
Block Diagram
V11
www.microne.com.cn
Page 3 of 13
ME2188
Absolute Maximum Ratings
Parameter
Symbol
Ratings
Units
CE pin input voltage
VCE
-0.3~6
V
LX pin voltage
LX
-0.3~6
V
LX pin current
ILXmax
1000
mA
VOUT pin voltage
VOUT
-0.3~6
V
SOT23-3
0.54
SOT23-5
0.6
SOT89-3
Continuous Total Power Dissipation
1.25
TO92
0.83
SOT23
0.38
SOT23-3
230
SOT23-5
210
SOT89-3
Thermal resistance(Junction to air)
PD
θJA
W
℃/W
100
TO92
150
SOT23
330
Operating Ambient Temperature Range
TOPR
-40~85
Storage Temperature Range
TSTG
-55~150
Maximum junction temperature
TJ
-40~150
Welding temperature
TL
260
Electrical Characteristics
TA = 25 ºC, VIN =VEN=2V, VOUT=3.3V,L=22uH,CIN=10uF,COUT=100uF, unless otherwise noted.
Symbol
Parameter
Start voltage
Vstart
Hold voltage
Vhold
Maximum input voltage
Vinmax
0.9
5
V
Output voltage accuracy
Vout
-2
+2
Power adjustment
ΔVout1
VIN=Vout×0.4~×0.6,IOUT=10mA
5
mV
Load adjustment
ΔVout2
IOUT=0~100mA,VIN=2V
mV
Quiescent Current
ISS
VOUT=VOUT+0.5
7.5
15
uA
Shutdown current
ISS0
VCE=0V
uA
Current limit
Ilimit
1000
1200
mA
No load input current
Iin0
10
15
uA
Efficiency
93
96
oscillation frequency
320
KHz
74
0.7
V
Oscillation signal duty
cycle
Test Conditions
MIN
TYP
MAX
UNIT
ILOAD=1mA, VIN:0→2V
0.7
0.9
1.1
V
ILOAD=1mA, VIN:2→0V
0.5
800
VIN=1.5V ,VOUT=2.2V
DCosc
EN input high level
EN input low level
V11
V
0.2
www.microne.com.cn
Page 4 of 13
V
ME2188
Type Characteristics
L=22uH,CIN=10uF,COUT=100uF, TA = 25 ºC, unless otherwise noted.
ME2188A33
V11
www.microne.com.cn
Page 5 of 13
ME2188
ME2188A22
V11
www.microne.com.cn
Page 6 of 13
ME2188
Operation Description
ME2188 step-up DC/DC converter charges energy in the inductor when Lx Transistor is on, and discharges the
energy with the addition of the energy from input power source thereto, so that a higher output voltage than the input
voltage is obtained. Following is the operation diagram.
Switching DC/DC Step up Converter operating process
PCB Layout:
Set external components as close as possible to the IC and minimize the connection between the components
and the IC. In particular, when an external component is connected to VOUT Pin, make minimum connection with the
capacitor.
Make Vss pin sufficient grounding, otherwise, the zero level within IC will varied with the switching current. This
may result in unstable operation of IC.
V11
www.microne.com.cn
Page 7 of 13
ME2188
Packaging Information
Package Type:SOT23-3
Millimeters
DIM
Inches
Min
Max
Min
Max
A
1.05
1.45
0.0413
0.0571
A1
0.0000
0.0059
A2
0.9
1.3
0.0354
0.0512
A3
0.6
0.7
0.0236
0.0276
b
0.25
0.5
0.0098
0.0197
c
0.1
0.25
0.0039
0.0098
D
2.8
3.1
0.1102
0.1220
E
2.6
3.1
0.1023
0.1220
E1
1.5
1.8
0.0591
0.0709
e
0.95(TYP)
L
0.25
L1
0.0374(TYP)
0.6
0.0098
0.59(TYP)
θ
c1
0.0232(TYP)
8°
0.2(TYP)
V11
0.0236
0.0000
8°
0.0079(TYP)
www.microne.com.cn
Page 8 of 13
ME2188
Package Type:SOT23-5
Millimeters
DIM
Inches
Min
Max
Min
Max
A
1.05
1.45
0.0413
0.0571
A1
0.0000
0.0059
A2
0.9
1.3
0.0354
0.0512
A3
0.6
0.7
0.0236
0.0276
b
0.25
0.5
0.0098
0.0197
c
0.1
0.23
0.0039
0.0091
D
2.82
3.05
0.1110
0.1201
e1
1.9(TYP)
0.0748(TYP)
E
2.6
3.05
0.1024
0.1201
E1
1.5
1.75
0.0512
0.0689
e
0.95(TYP)
L
0.25
L1
0.0374(TYP)
0.6
0.0098
0.59(TYP)
θ
c1
0.0232(TYP)
8°
0.2(TYP)
V11
0.0236
0.0000
8°
0.0079(TYP)
www.microne.com.cn
Page 9 of 13
ME2188
Package Type:SOT89-3
Millimeters
DIM
Inches
Min
Max
Min
Max
A
1.4
1.6
0.0551
0.0630
b
0.32
0.52
0.0126
0.0205
b1
0.4
0.58
0.0157
0.0228
c
0.35
0.45
0.0138
0.0177
D
4.4
4.6
0.1732
0.1811
D1
1.55(TYP)
0.061(TYP)
D2
1.75(TYP)
0.0689(TYP)
e1
3.0(TYP)
0.1181(TYP)
E
2.3
2.6
0.0906
0.1023
E1
3.94
4.4
0.1551
0.1732
E2
1.9(TYP)
0.0748(TYP)
e
1.5(TYP)
0.0591(TYP)
L
0.8
θ
1.2
45°
V11
0.0315
0.0472
45°
www.microne.com.cn
Page 10 of 13
ME2188
Package Type:SOT23
Millimeters
DIM
Inches
Min
Max
Min
Max
A
0.9
1.15
0.0354
0.0453
A1
0.0000
0.0055
A2
0.9
1.05
0.0354
0.0413
b
0.28
0.52
0.0110
0.0205
c
0.07
0.23
0.0028
0.0091
D
2.8
3.0
0.1102
0.1181
e1
1.8
2.0
0.0709
0.0787
E
1.2
1.4
0.0472
0.0551
E1
2.2
2.6
0.0866
0.1024
e
0.95(TYP)
0.0374(TYP)
L
0.55(TYP)
0.0217(TYP)
L1
0.25
0.55
0.0098
0.0217
θ
8°
0.0000
8°
c1
0.25(TYP)
V11
0.0098(TYP)
www.microne.com.cn
Page 11 of 13
ME2188
Package Type:TO-92
Millimeters
DIM
Inches
Min
Max
Min
Max
A
3.3
3.7
0.1299
0.1457
A1
1.1
1.4
0.0433
0.0551
b
0.38
0.55
0.015
0.0217
c
0.36
0.51
0.0142
0.0201
D
4.3
4.7
0.1693
0.185
D1
3.43
一
0.135
一
E
4.3
4.7
0.1693
0.185
e
1.27TYP
0.05TYP
e1
2.44
2.64
0.0961
0.1039
L
14.1
14.5
0.5551
0.5709
h
Φ
一
1.6
一
0.063
V11
www.microne.com.cn
Page 12 of 13
ME2188
The contents of this document will be updated with the product's improvement without prior
notice. Please consult our sales staff before using this document to ensure that you are using
The application circuit examples described in this document are only used to indicate the
representative use of the product an
Please use this product within the limits stated in this document. We will not be responsible for
The products described in this document are not allowed to be used in equipment or devices
that affect the human body without the written permission of our company, including but not
limited to: health equipment, medical equipment, disaster prevention equipment, fuel control
equipment, automobile equipment, aviation equipme
Although our company has always been committed to improving product quality and reliability,
semiconductor products have a certain probability of malfunction or wrong work. To prevent
personal injury or property damage caused by such accidents, please pay full attention to
safety design, for example: Alternate design, fire protection design, and prevention of wrong
When exporting this product or this document overseas, you should abide by applicable import
and exp
Copying or reprinting part or all of this document in any form without the permission of our
company is strictly prohibited.
V11
www.microne.com.cn
Page 13 of 13
很抱歉,暂时无法提供与“ME2188A25M3G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.49916
- 100+0.39461
- 600+0.39066
- 1200+0.38285
- 3000+0.37136
- 国内价格
- 5+0.54454
- 50+0.43049
- 150+0.37347
