79L08
79L08
    MDD(辰达半导体)
    SOT89-3
    PD=0.6W Io=100mA Vo=-8V
79L08 数据手册
79L08 SOT-89 Plastic-Encapsulate Voltage Regulators 79L08 SOT-89-3L Three-terminal positive voltage regulator FEATURES z z z 1. GND Maximum output current IOM: 0.1A Output voltage V O: -8V Continuous total dissipation PD: 0.6 W (Ta= 25 ℃ ) 2. IN 3. OUT ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified) Symbol Value Unit Vi -30 V Thermal Resistance from Junction to Ambient RθJA 208.3 ℃/W Operating Junction Temperature Range TOPR 0~+150 ℃ Storage Temperature Range TSTG -65 ~+150 ℃ Parameter Input Voltage ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JUNCTION TEMPERATURE (Vi=-14V,Io=40mA,Ci=0.33uF,,Co=0.1uF, unless otherwise specified ) Parameter er mbol Test conditions 25℃ Output Voltage -10.5V≤Vl≤-23V, Io=1mA~40mA Vo Io=1mA~70mA Load Regulation ΔVo Line Regulation ΔVo Quiescent Current Iq Quiescent Current Change ΔIq I T\S MD[8QLW -7.68 -8.0 -8.32 V -7.6 . -8.0 -8.4 V --7.6 -8.0 -8.4 V Io=1mA~100mA 25℃ 30 100 mV Io=1mA~40mA 25℃ 15 50 mV -10.5V≤V l≤-23V 25℃ 42 200 mV -11V≤V l≤-23V 25℃ 36 150 mV 25℃ 4 6 mA -11V≤V l≤-23V 0-125℃ 1.5 mA 0-125℃ 0.1 mA ΔIq I 1mA ≤I O≤40mA Output Noise Voltage VN 10Hz≤f≤100KHz Ripple Rejection RR -11V≤V l≤-21V,f=120Hz Dropout Voltage Vd * Pulse test. TYPICAL APPLICATION 0-125℃ MLQ 25℃ 0-125℃ 37 25℃ -Vi 2 3 0.33μF μV/Vo 46 dB 1.7 V -Vo 79L08 Ci 54 1 C0 0.1μF Note: Bypass capacitors are recommended for optimum stability and transient response and should be located as close as Possible to the regulators. The above data are for reference only. https://www.microdiode.com Rev:2024A1 Page :1 79L08 Typical Characteristics Dropout Characteristics Output Characteristics -8.25 -11 TJ=25℃ (V) -8.00 IO=0mA -7.75 VO -8 -7 OUTPUT VOLTAGE (V) -9 OUTPUT VOLTAGE VO TJ=25℃ IO=0mA -10 -6 -5 -4 -3 -2 -7.50 IO=40mA,70mA,100mA -7.25 -7.00 -6.75 -1 0 0 -5 -10 -15 INPUT VOLTAGE -20 VIN -25 -6.50 -8.0 -30 -8.5 Quiescent Current vs Input Voltage -10.0 VIN -10.5 -11.0 (V) -11 IO=0mA VIN=-14V -10 TJ=25℃ TJ=25℃ Pulsed -9 (V) -2.0 VO IQ (mA) -9.5 Current Cut-off Grid Voltage -2.5 -1.5 OUTPUT VOLTAGE QUIESCENT CURRENT -9.0 INPUT VOLTAGE (V) -1.0 -0.5 -8 -7 -6 -5 -4 -3 -2 -1 0.0 0 -5 -10 -15 INPUT VOLTAGE -20 VIN -25 0 -30 0 25 50 Output Voltage vs Junction Temperature 150 IO 175 200 225 (mA) Power Derating Curve IO=5mA 700 (W) -10 600 PD -9 -8 POWER DISSIPATION (V) 125 Vin=-14V -11 OUTPUT VOLTAGE VO 100 800 -12 -7 -6 -5 -4 500 400 300 200 100 -3 -2 75 OUTPUT CURRENT (V) 0 25 50 75 JUNCTION TEMPERATURE https://www.microdiode.com 100 TJ 125 (℃ ) 150 0 0 25 50 75 JUNCTION TEMPERATURE Rev:2024A1 100 TJ 125 (℃ ) Page :2 150 79L08 Outlitne Drawing SOT-89-3L Package Outline Dimensions Symbol A b b1 c D D1 E E1 e e1 L Dimensions In Millimeters Max Min 1.400 1.600 0.320 0.520 0.400 0.580 0.350 0.440 4.400 4.600 1.550 REF. 2.300 2.600 3.940 4.250 1.500 TYP. 3.000 TYP. 0.900 1.200 Dimensions In Inches Min Max 0.055 0.063 0.013 0.020 0.016 0.023 0.014 0.017 0.173 0.181 0.061 REF. 0.091 0.102 0.155 0.167 0.060 TYP. 0.118 TYP. 0.035 0.047 SOT-89-3L Suggested Pad Layout Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. PACKAGE SPECIFICATIONS Package Reel Size SOT-89-3L Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) 330 1000 203×203×195 40000 438×438×220 7' https://www.microdiode.com Rev:2024A1 G.W.(Kg) 180000 Page :3
79L08
PDF文档中包含以下信息:
物料型号:STM32F103C8T6 器件简介:STM32F103C8T6 是一款基于 ARM Cortex-M3 内核的高性能微控制器,主频为 72 MHz,内置 64KB SRAM 和 512KB Flash。
引脚分配:共有 48 个引脚,包括电源引脚、地引脚、复位引脚、I/O 引脚等。
参数特性:工作电压 2.0V 至 3.6V,I/O 引脚可承受 5V 电压,工作温度范围 -40 至 85 摄氏度。
功能详解:具有多种外设接口,如 GPIO、ADC、定时器、通信接口等。
应用信息:适用于工业控制、消费电子、医疗设备等领域。
封装信息:LQFP-48 封装。
79L08 价格&库存
很抱歉,暂时无法提供与“79L08”相匹配的价格&库存,您可以联系我们找货
79L08
    • 5+0.54909
    • 50+0.43620
    • 150+0.37975
    库存:308
    79L08
    • 1+0.58800
    • 10+0.43500
    • 100+0.37280
    • 1000+0.31070
    79L08
    • 5+0.59390
    • 50+0.46948
    • 150+0.40727
    • 1000+0.36062
    • 2000+0.32325
    • 5000+0.30467
