78M15
78M15
    SK(時科)
    TO-252(DPAK)
    三端正电压调节器 TO-252-3 15V 70dB -55~+150℃ 500mA
78M15 数据手册
0吉利 78M05 THRU 78M24 SHI KUES • The implementation of standards: Seven post-secondary level:(Enterprise standard nu的er:Q/PS QZJ07-2004) QZJ840日5" Seven special "Technical conditions Prussians level: (Enterprise standard n皿ber:Q/PS 005-2004) GB4589. I 89 (IIClass) GB/T12750 91 Industrial Grade: (Enterprise standard number:Q/PS 005-2004) GB4589. 1-89 (IClass) GB/T12750-91 • Main purposes: The role of regulator and protection for a variety of electrical ap pliances, 啦ctronic equipment, regulator circuit T hree-terminal fixed output voltage regulator 12\V 、 O.SA、 S\'-24\' • Maximum Ratings Symbol Parameter Input voltage (TA·25"C) 78M05�78M15 V1 78M18-78M24 Output current Total power dissipation (TA =25"C ) 1 ' Ratings Unit 35 V 40 lo 0.5 A w w Po 1.3 2 (Tc=2S"C) Work (tube she! l) temperature Po 12 Tor -40-125 ·c Storage temperature T邓 -55-150 它 Ambient temperature T0-251 T0-252 In a well-ventilated l'hen the device is ins1alled in Tc>2S"C the radiator should be a derating . 78M05 El ectncal characteristics (unless othet'Wise specified o,,:;r冬+125-C. V,=10V, I乒350mA. C,=O. 33µF. Co=O. 1�,F) Parameter name 4.8 Typ 5 Max T1=2s·c 5mA�l0 �350mA, 7Y�Y,�20V 4.75 5 5.25 Symbol 。 Test Condition Output Voltage v Volt age Regula! ion Sv TJ=2s·c 10=200mA Current Regulation s, TJ=25-C Quiescent Current lo TJ=2s·c Quiescent Current Change 凶Q lnJl)t - oul{IIII differeatial pressure v,-v Ripple Rejection Ratio Srip 。 Min 7v:e:::;:v1 :e:::;:2sv 8Y�V1 �25V ', " 5.2 100 so SmA:::,;10:::,;soOmA 100 5rnA�I �200rnA, 50 。 6 5mA�l0 �350mA 0.5 10 200mA, 8V�V1 �25V 0.8 = TJ=25"C, I 0=500mA 10 =300mA, 8V�Y1 �18Y, f=l20Hz 。 。 REV.08 1 of 4 V mV mY mA mA 2 V 78 dB 78M06 Electrical characteristics (unless oth妇se specifiedO包�+125-C. V,=11V, l,;=350mA,C,=0.33 µF. 茫0. lµF} Test Condition Max Symbol Min Parameter name Typ 5.75 6 6.25 rJ=2s·c v Output VolLage 5.7 6.3 6 SmA,;;10 ,;;350mA, sv,;;v1 ,;;21V ,. =2s·c 100 sv,,;;v1 ,,;;2sv T J Voltage Regulation Sv _, ,一 Io=200mA 50 9V�V1 �25 V 120 5mA�l0�500mA Current Regulation T尸2s·c s, 60 SmA�I �200mA, Quiescent Current lo 6 Ti=25-C ·一 0.5 5mA�l0 �350mA Quiescent Current Change 凶Q 0.8 10 =200mA, 9V�V1 �25V ' ,. lo卯t - out肛t differential pressore V1 -V 2 T,=25"C, 10=500mA = ,一 75 Srip 10 300mA, 9V�V1 �19V, f=l20Hz Ripple Rejection Ratio 。 Unit Unit V mV mV mA mA V dB 利 uES k 土iJHI nn3s 乙6a 78M05 THRU 78M24 78M08 Electrical characteristics (Unless othelWise specified o,;;;r,,;;;+12s·c'V, =14V, 片350mA, C, =O. 33µF, Co=O. 1µ F ) Parameter name Symbol 。 飞=25 C 7.7 5mA,;;;10 ,;;;3somA, 10.sv,;;;v1 ,;;;23v 7.6 8 Output Vol iage v Voltage Regulation Sv T产25-C lo=200mA Current Regulation s, T J=2s·c Quiescent Current IQ Ti=2s·c Quiescent Current Change 凶Q l盯川I -011I仰I differ切lial pressur, V1-V Ripple Rejection Ratio Srip 。 Min Typ 8 Test Condition ° Max 8.4 8.3 10.sv::;;v1::;;2sv 100 11v:s;v 1:s;2sv 50 SmA,;:;J ,;:;soOmA 160 。 SmA�I。�200mA, 80 6 Sm A�10 �350mA 0.5 10=200mA, 0.8 10.5V�V,�25V mV mV mA mA 2 V 10=300mA, 73 dB 9V�V冬19V, f=l20Hz 飞=2s·c 8.6 9 9.4 5mA�l0 �350mA, I 1.5V�V1 �24V 8.55 9 9.45 Output Vol Lage v Voltage Regulation Sv TJ=2s·c 10=200rnA Current Regulation s, T』 2s·c Quiescent Current lo Ti=2s·c Quiescent Current Change 凶Q Input - output differential pressure Vi-V Ripple Rejection Ratio Srip = 。 V T尸2s·c, lo= 500mA 78M09 Electrical characteristics (Unless otherwise specified O�T,�+125"C, V,=15V, 忙350mA, C,=O. 33 µ F, 烂0. l µF) Min S ymbol Test Condition Max Typ Parameter name 。 Unit 11.sv�v,�2sv 100 12v:::;v 1:::;2sv 50 5111A,::;10,::;soOmA 180 5mA:e::;Jo:e::;200mA, 90 6 5mA�lo�350mA 0.5 10=200mA, 11 sv:;;;v 1 :;;;2sv 0.8 Unit V mV mV mA mA T 1=2s·c, lo=500mA 2 V 10=300mA, 12.sv,:;;v 1,:;;23v, f=l20Hz 71 dB 78M10 Electrical characteristics (Unless othe呴se specified 0氢�+125"C, V,=17V, I a=350mA. C, =O. 33 µF, Co=O. 1µF) Parameter name Symbol 。 Test Condition 10.4 SmA,;;;10 ,;;;3so111A, 12.sv,;;;v1 ,;;;2sv 9.5 10 10.5 Voltage Regulation Sv TJ=25"C lo=200mA Current Regulation S1 T」 =2s·c Quiescent Current lo TJ=2s·c Input -output differential pressure V 1 -V Ripple Rejection Ratio Srip REV.08 。 Ma: 10 v 凶Q Typ 9.6 Output Voltage Quiescent Current Change Min 1, =2s·c 12.sv::;;;v1::;;;2sv 100 13v:,;;v,:,;;2sv 50 SmA:s;:1 :s;:sOOmA 200 SrnA�I �200rnA, 100 。 。 6 5mA�lo�350mA 0.5 10 200111A, 12.sv,;;:;v 1,;;:;2sv 0.8 = Un几 V mV mV mA mA TJ=25"C, I 0=500mA 2 V 10=300mA, 13V�V 1�23V, �120Hz 71 dB 2 of 4 利 土刁 n日U ` 乙 uES k HI s 78M05 THRU 78M24 . 78M12 El ectncal characteristics (Unlessotherwise specifiedO,;;;T,,;;;+125"C, V,= 19V, l o=350mA, C,=O. 33µF. Co=O. l µF) Min Typ Max T1=2s·c 11.5 12 12.5 5rnA:;;:;10:;;:;350111A, I4.sv:;;:;v 1:;;:;27v 11.5 12 12.6 Parameter name Symbol Output Voltage v Voltage Regulation Sv Ti=2s·c lo=200mA Current Regula I ion S1 Ti=25-C Quiescent Current IQ TJ=2s·c 。 Quiescent Current Change 凶Q Inpu t - ootpot differential pressure V1-V Ripple Rejection Ratio Srip 。 Test Condition 14.5V�V1 �30V 100 16v,;;:;v1,;;:;3ov 50 5mAe:;;J e:;;soOmA 240 SmA:,;;10:,;;200mA, 120 。 6 5mA::::;10::::;350mA 10 =200mA, 一· ' , 0.5 0.8 14.5V�V,�30V Unit V mY mV mA mA TJ=2s·c, 10=500mA 2 V J 0 300mA, ISY�Y1�25Y, f=l20Hz 71 dB = . 78M15 El ectncal charactenStlCS (Unlessotherwise specified o..;;;TJ..;;;+125.C, V, =23V, I iF350mA, C, =O. 33r1F, Co=O. 1µF) Parameter name Symbol 。 Test Cond仆ion TJ =2s·c Output Voltage v Voltage Regulation Sv T尸2s·c I 0=200mA Current Regulation S1 Ti=25'C Quiescent Current lo Ti=25'C Quiescent Current Change 凶Q Input - ou1pu1 differential pressure V 1 -V Ripple Rejection Ratio . SmA�l0�350mA, 17.SV�V,�30V 。 Srip Min Typ Max 14.4 15 15.6 14.25 15 15.75 17.5V�V 1�30V 100 20V�V1�30V 50 SmA�10�500mA 。 .一"' -- 300 150 5mA�I �200mA, 6 5mA�l0�350mA 0.5 I0 0.8 =200mA, I 7.5V�V 1�30V Unit V mV mV mA mA Ti =25"C, 10=500mA 2 V 10 70 dB =300mA, I 8.5V�V,�28.5V, f= l20Hz 78M18 El ectncal charactenStlCS (Unlessotherwise specified o:e;;;T,:,;;;+ 125·c, V, =26V, I o=350mA. C, =O. 33 µF. Co=O. 1 µF) Parameter name Symbol 。 Test Condition T1=25'C 5mA�lo�350mA, 20.5V�V1 �33V Output Voltage v Voltage Regulation Sv T1= 2s·c 10=200mA Current Regulation s, Ti =25'C Quiescent Current lo Ti=2S'C Quiescent Current Change 凶Q In仰t - out put differential pressure VrV Ripple Rejection Ratio Srip REV.08 。 Typ Max 17.3 18 18.7 17.1 18 18.9 Min 21V�V,�33V 100 24Y�V1 �33Y 50 5mA::,;;10 ::,;;soomA 360 5mA�l0�200mA, 180 6 0.5 SmA�l0 �3SOmA lo=200mA, 21V�V1 �33V 0.8 ' , Unit V mV mV mA 111A T1=25'C, lo=SOOmA 2 V 10=300111A, 22y,;::;y1 ,;::;32y, f=l20f-lz 69 dB 3 of 4 利 uES k 土iJHI ^ u us 6a 乙 78M05 THRU 78M24 78M20 Electrical characteristics (Unless othe呴se specified O�T,�+125 °C, V,=29V. 忙350mA. C,=O. 33 µ F心=O. 1 µ F ) Parameter name Symbol Output Voltage v 。 Voltage Regulation Sv T1=25 C 10=200mA Current Regulation s, T1=25'C Quiescent Current lo Ti=25"C Quiescent Current Change 610 lnjlllt - output differential pressure Vi- V Ripple Reject ion Rat io Srip 。 Typ Max 19.2 20 20.8 19 20 21 Min Test Condition 1J=2s·c 5mA�I �350mA, 23V�V1 �35V ° 。 23V�V,�35V 24v:s;v1 :s;3sv 100 SmA�I �SOOmA 400 SmA�lo�200mA, 200 Unit V mY 50 。 mV 6 mA SmA,::::;10,::::;350mA 0.5 mA l0=200mA, 23V�V,�35V 0.8 ° T1=25 C, lo=SOOmA 2 V 10=300mA, 24V�V1 �34V, f=l20Hz 69 dB 78M24 Electrical characteristics (unless othe咄se specified 0红�+12s·c, V,=33V, lo=350mA, C,=O. 33µ F, Co=O. l µ F) Parameter name Symbol 。 Output Voltage v Voltage Regulation Sv T』:2s·c 10=200mA Current Regulation s, 飞=25'C Quiescent Current lo T』 25"C Typ Min Test Condition 5mA:,;10 �350mA, 27V�V,�38V Max 23 24 25 22.8 24 25.2 .., . 一 100 TJ= 25'C 21v:e::;;v 1 :::;;3gy 28V�V 1�38V 凶Q lop.it - 011tp1t differential pressure V 1- V Ripple Rejection Ratio Srip 。 V mV so 5mA�l0�500mA 480 SmA,;::;10,;::; 20omA, 240 n,V 6 = Quiescent Current Change Unit 5mA�l0 �350mA 0.5 10=200mA, 27V�V1�38V 0.8 T1=25'C, 10=500mA .. . lo=300mA, 2gy,::;y1 ,::;3gy, f=l201-1z ..一· mA mA 2 .' V 67 ·一· dB Unit: mm T0-252 Dimensions T0-252 � Symbol mm max � Symbol mm max A 6.4 6.8 J 0.6 0.95 B 4.8 5.53 K 2.1 2.5 C 0.9 1.3 L 0.4 0.6 D 5.9 6.3 M 0.80 1.4 E 2-3 2.9 N 0.9 LI 0.4 0.6 p 0.81 1.01 F 1.8 2.2 G 2.2 2.4 。 H 2.2 2.4 Q 3.6 4.0 I 0.66 0.92 R 0.4 0.6 1 IN 2 GND 30UT 4 GND REV.08 T0-252 4 of 4
78M15 价格&库存
很抱歉,暂时无法提供与“78M15”相匹配的价格&库存,您可以联系我们找货
78M15
  • 5+0.80049
  • 50+0.64463
  • 150+0.56677
  • 500+0.50839
  • 2500+0.41994
  • 5000+0.39655
库存:1260
78M15
  • 5+0.59117
  • 20+0.53900
  • 100+0.48684
  • 500+0.43468
  • 1000+0.41034
  • 2000+0.39295
库存:757
78M15
    • 2500+0.34804
    库存:15000
    78M15
      • 2500+0.34804
      库存:1500
      78M15
        • 1+0.39200
        库存:10
        78M15
        • 1+0.69630
        • 100+0.46310
        • 1250+0.42130
        • 2500+0.38610
        库存:4425
