Through-hole resistors
General Type
Metal Film Resistors
Normal & Miniature Style [ MFR Series ]
FEATURES
Power Rating
1/6W, 1/4W, 1/2W, 1W, 2W, 3W
Resistance Tolerance
±0.5%, ±1%, ±2%, ±5%
T.C.R.
±50ppm/°C, ±100ppm/°C
DERATING CURVE
For resistors operated in ambient temperatures above 70°C, power rating must be derated
in accordance with the curve below.
INTRODUCTION
The MFR Series Metal Film Resistors are
manufactured using a vacuum sputtering system
to deposit multiple layers of mixed metal
alloys and passivative materials onto a carefully
treated high grade ceramic substrate. After a
helical groove has been cut in the resistive layer,
tinned connecting leads of electrolytic copper
are welded to the end-caps. The resistors are
coated with layers of blue color lacquer.
Rated Load (%)
70
155 °C
100
80
60
40
60
80
100 120 140 160
Ambient Temperature (°C)
DIMENSIONS
Unit: mm
STYLE
ød
H
L
øD
DIMENSION
Normal
Miniature
L
øD
H
ød
MFR-12
MFR25S
3.4±0.3
1.9±0.2
28±2.0
0.45±0.05
MFR-25
MFR50S
6.3±0.5
2.4±0.2
28±2.0
0.55±0.05
MFR-50
MFR1WS
9.0±0.5
3.3±0.3
26±2.0
0.55±0.05
MFR100
MFR2WS
11.5±1.0
4.5±0.5
35±2.0
0.8±0.05
MFR200
MFR3WS
15.5±1.0
5.0±0.5
33±2.0
0.8±0.05
5
Note:
ELECTRICAL CHARACTERISTICS
STYLE
MFR-12
MFR25S
Power Rating at 70°C
1/6W
1/4W
Maximum Working Voltage
200V
250V
300V
350V
400V
500V
Maximum Overload Voltage
400V
500V
600V
700V
800V
1,000V
Voltage Proof on Insulation
300V
700V
1,000V
Resistance Range
1Ω - 4M7Ω & for E24 & E96 series value
Operating Temp. Range
-55°C to +155°C
Temperature Coefficient
400V
MFR-25
MFR50S
MFR-50
1/2W
MFR1WS
MFR100
1W
500V
MFR2WS
MFR200
MFR3WS
2W
3W
Note: Special value is available on request
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage)
±0.25%+0.05Ω
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
Between -55°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>10,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥2.5kg (24.5N)
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off)
±1.0%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±1.5%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±1.5%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±0.75%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±0.25%+0.05Ω
Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“MFR-25FTE52-53K6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09386
- 500+0.07193
- 1500+0.05984
- 国内价格
- 50+0.08603
- 1000+0.06593
- 2000+0.06527
- 5000+0.06396
- 国内价格 香港价格
- 5000+0.124385000+0.01615
- 10000+0.1131910000+0.01470
- 15000+0.1074515000+0.01395
- 25000+0.1009525000+0.01311
- 35000+0.0970835000+0.01261
- 50000+0.0933050000+0.01211
- 国内价格 香港价格
- 1+0.884041+0.11477
- 10+0.3696010+0.04798
- 25+0.3063325+0.03977
- 50+0.2677750+0.03476
- 100+0.23603100+0.03064
- 250+0.20012250+0.02598
- 500+0.17758500+0.02306
- 1000+0.158461000+0.02057
