HHV-50FT-52-22M
HHV-50FT-52-22M
    YAGEO(国巨)
    插件,D3.3xL9mm
    插件电阻 22MΩ ±1% 500mW ±200ppm/℃
HHV-50FT-52-22M 数据手册
Approval Sheet for Metal Glazed Film Resistors High Voltage & High Ohmic Type HHV series ±1%, ±5% YAGEO CORPORATION Headquarters: 3F, No.233-1, Pao Chiao Rd., Xindian, Taipei, Taiwan, R.O.C. Tel: 886-2-6629-9999 Fax: 886-2-6628-8885 URL: www.yageo.com Page-1 Rev. Description Issue Date Drawn Approved 00 issue new spec. Jul 16, 2007 Sara Lin Joyce Chung 01 Update description Sep 04, 2007 Lynn Chen Joyce Chung Environmental Characteristics revised 02 HHV1WS data is included Jan 09, 2008 Lynn Chen Joyce Chung 03 The 5th color band is changed to yellow Jan 16, 2008 Lynn Chen Joyce Chung for tolerance 5% to represent high HHV 04 Lead Length 26mm is included Apr 18, 2008 Lynn Chen Joyce Chung 05 Series adjustment Aug 29, 2008 Lynn Chen Joyce Chung 06 HHV1SS data is included Feb 25, 2009 Lynn Chen Ken Hsu 07 Revised the product description Apr 07, 2009 Lynn Chen Ken Hsu 08 Adjust Index May 05, 2009 Lynn Chen Ken Hsu 09 Series adjustment Sep 02, 2009 Lynn Chen Ken Hsu 10 Environmental Characteristics revised Jan 15, 2010 Lynn Chen Ken Hsu 11 HHV200 is deleted and HHV3SS is included. 1) T26 packing method for HHV-50 & HHV1SS series is deleted. 2) HHV100 series is deleted. The environmental characteristics are adjusted; Coated with epoxy lacquer type and part number suffix of “Y” are included Modify tape on box packing data Aug 03,2010 Feng Ye Ken Hsu Aug 12, 2010 Feng Ye Ken Hsu Dec 30, 2010 Feng Ye Ken Hsu Apr 07, 2011 Feng Ye Ken Hsu Jun 27, 2011 Feng Ye Ken Hsu 12 13 14 15 th 16 Revise product description of “the 5 color band is yellow” to “the last color band is yellow”; Revise band-code cutline. Feb 03, 2012 Feng Ye Ken Hsu 17 Added “52-“ type taping for HHV2WS&HHV3SS. May.21, 2014 Feng Ye Flora Shen 18 Added reel type taping Nov. 28, 2014 Feng Ye Flora Shen Page-2 Rev. Description Issue Date Drawn Approved 19 Update reel type dimension A , Add Jan 13, 2020 Hui Chen Feng Ye Apr. 09, 2020 Mingfa Liu Feng Ye dimension B 20 Forming dimensions are included. Description Metal Glazed Film Resistors, High Voltage & High Ohmic Type Series HHV Rev. Page-3 20 1. PRODUCT: A metal glazed film is deposited on a high grade ceramic body, the resistors are coated with a pink silicone lacquer or a blue epoxy lacquer (on request), the last color band is yellow to represent high voltage resistors. 2. PART NUMBER: Part number of the high voltage & high ohmic metal glazed film resistor is identified by the name, power, tolerance, packing, temperature coefficient, special type, resistance value and suffix. Example: HHV -50 (1) Series Name (2) Power Rating J T (3) Resistance Tolerance - 52- 100K Y (4) (5) (6) (7) (8) Packing Temperature Special Resistance Suffix Style Coefficient Type Value of Resistance (1) Style: HHV SERIES (2) Power Rating: -25=1/4W、50S=1/2W、-50=1/2W、1SS=1W、1WS=1W、2SS=2W、2WS=2W、 3SS=3W (3) Tolerance: F = ± 1% , J = ± 5% (4) Packaging Type: T=Tape on Box Packing B=Bulk Packing R=Paper Taping Reel (5) Temperature Coefficient : “-“=base on spec. (6) Special Type: 26- = 26mm 52- = 52.4mm 73- = 73mm M=M-Type Forming for Bulk MB = MB Type Forming for Bulk F = F Type Forming for Bulk FK = FK Type Forming FFK = FFK Type Forming FKK = FKK Type Forming PN=PANAsert ( rated watts from 1/4W to 2SS size only ) AV=Avlsert ( rated watts from 1/4W to 2SS size only ) (7) Resistance Value: 100K-68MΩ for E24&E96 Series. (8) Suffix: Y = coated with a blue epoxy lacquer None = coated with a pink silicone lacquer. Page-4 3. BAND-CODE: COLOR 1st BAND 2nd BAND 3rd BAND MULTIPLIER BLACK 1Ω 0 0 0 BROWN 1 1 1 10Ω RED 2 2 2 100Ω ORANGE 3 3 3 1KΩ YELLOW 4 4 4 10KΩ GREEN 5 5 5 100KΩ BLUE 6 6 6 1MΩ VIOLET 7 7 7 10MΩ GREY 8 8 8 WHITE 9 9 9 GOLD 0.1Ω SILVER 0.01Ω * TOL: ± 1 % ( F )--- 6 color band. * TOL: ± 5 % ( J )--- 5 color band.(3rd BAND is not included) TOLERANCE ±1%(F) HHV Series ±5%(J) 4. ELECTRICAL CHARACTERISTICS TABLE I STYLE HHV-25 HHV50S HHV-50 HHV1SS Power Rating at 70 ℃ Maximum Working Voltage(DC) Maximum Overload Voltage(DC) Voltage Proof (Silicone Type) Voltage Proof (Epoxy Type) Resistance Range Operating Temp. Range 1/4W 1/2W 1W 1600V 3500V 3000V 7000V 300V 500V 500V 100K ~ 68MΩ for E24 & E96 series value - 55 ℃ to + 155 ℃ Temperature Coefficient ± 200 ppm /℃ HHV1WS HHV2SS 5000V 10000V 600V 700V * Below or over this resistance on request 5. DERATING CURVE Rated Load (%) 70℃ 100 80 60 40 20 20 40 60 80 100 120 140 155 180 Ambient Temperature (℃) Page-5 HHV2WS HHV3SS 2W 3W 7000V 14000V 6. DIMENSIONS ψd L H ψD DIMENSIONS(unit:mm) STYLE ψD L H ψd Normal Miniature HHV-25 HHV50S 6.3±0.5 2.4±0.2 28±2.0 0.55±0.05 HHV-50 HHV1SS 9.0±0.5 3.3±0.3 26±2.0 0.55±0.05 HHV1WS HHV2SS 11.5±1.0 4.5±0.5 35±2.0 0.80±0.05 HHV2WS HHV3SS 15.5±1.0 5.0±0.5 33±2.0 0.80±0.05 7. ENVIRONMENTAL CHARACTERISTICS (1) Short Time Over Load Test At 2.5 times of the rated voltage. or the maximum load voltage, whichever is the less, applied for 5 seconds, the resistor should be free from defects after the resistor is released from load for about 30 minutes Short Time Overload Voltage = 2.5 * Power Rating ´ Resistance Value The change of the resistance value should be within ± 2.0 % + 0.05Ω (2) Voltage Proof The resistor shall be clamped in the trough of a 90° metal V Block. Apply the insulation voltage specified in the “Table I “ between the terminals connected together with the block for about 60 seconds. The resistor shall be able to withstand without breakdown or flashover. (3) Temperature Coefficient Test Test of resistors above room temperature 100°C ± 2°C ( Testing Temperature 115°C to 130°C ) at the constant temperature silicon plate for over 5 minutes. Then measure the resistance value. The Temperature Coefficient is calculated by the following equation and its value should be within the range of requested. Re sistor Temperatur e Coefficien t = R R0 t to R - R0 1 ´ ´ 10 6 R0 t - t0 = Resistance value under the testing temperature = Resistance value at the room temperature = The testing temperature = Room temperature Page-6 (4) Insulation Resistance Apply "measuring voltage" between protective coating and termination for 1 min.,then measure. The measuring voltage shall be either 100V±15V d.c. for resistors with an insulation voltage lower than 500V or 500V±50V d.c. for resistors with an insulatin voltage equal to or greater than 500V. The test resistance should be high than 10,000M ohm. (5) Solderability Immerse the specimen into the solder pot at 245 ± 5 °C for 3 ± 0.5 seconds. At least 95% solder coverage on the termination. (6) Solvent Resistance of Marking The specimen into the appropriate solvent of IPA condition of ultrasonic machine for 5± 0.5 minutes. The specimen is no deterioration of coatings and color code (7) Robustness of Terminations Direct Load – Resistors shall be held by one terminal and the load shall be gradually applied in the direction of the longitudinal axis of the resistor unit the applied load reached the requirement. The load shall be held for 10 seconds. The load of weight shall be ≧ 2.5 kg ( 24.5N ). (8) Periodic-Pulse Overload Apply 4 times of rated voltage to the specimen at the 1 second on and 25 seconds off cycle, subjected to voltage application cycles specified in 10,000 time. The change of the resistance value shall be within ± 1.0% + 0.05 Ω (9) Damp Heat Steady State Place the specimen in a test chamber at 40 ± 2 °C and 90 ~ 95 % relative humidity. Apply the 0.1 times rated voltage to the specimen at the 1.5 hours on and 0.5 hour off cycle. The total length of test is 56 days. The change of the resistance value shall be within ± 5.0 % + 0.05 Ω (10) Endurance at 70 °C Placed in the constant temperature chamber of 70 ± 3 °C the resistor shall be connected to the lead wire at the point of 25mm. Length with each terminal, the resistors shall be arranged not much effected mutually by the temperature of the resistors and the excessive ventilation shall not be performed, for 90 minutes on and 30 minutes off under this condition the rated D.C. voltage is applied continuously for 1000+48/-0 hours then left at no-load for 1hour, measured at this time the resistance value。 The change of the resistance value shall be within ± 5.0 % + 0.05 Ω. There shall be no remarkable change in the appearance and the color code shall be legible after the test.. (11) Temperature Cycling Test The temperature cycle shown in the following table shall be repeated 5 times consecutively. The measurement of the resistance value is done before the first cycle and after ending the fifth cycle, leaving in the room temperature for about 1 hour. Temperature Cycling Conditions: Step Temperature(°C) Time (minute) 1 -55 ± 3 30 2 25 ± 3 2~3 3 155 ± 3 30 4 25 ± 3 2~3 The change of the resistance value shall be within ± 1.0 % + 0.05 Ω After the test the resistor shall be free from the electrical or mechanical damage. Page-7 (12) Resistance to Soldering Heat The terminal lead shall be dipped into the solder pot at 260 ± 3 °C for 10 ± 1.0 seconds up to 2.5 ~ 3.5 mm. The change of the resistance value shall be within ± 1.0 % + 0.05 Ω (13) Accidental Overload Test (Only for silicone lacquer type) At 4 times of the rated voltage or the maximum load voltage, whichever is the less, applied for 1 minute Overload Test Voltage = 4 * Power Rating ´ Resistance Value The resistor shall be able to no evidence of flaming arcing. 8. PACKING METHODS Bandolier for Axial leads STYLE Normal Miniature a HHV-25 HHV50S 6 ± 0.5 HHV-50 HHV1SS 6 ± 0.5 HHV1WS HHV2SS 6 ± 0.5 HHV2WS HHV3SS 6 ± 0.5 DIMENIONS A B1-B2 52.4 ± 1.0 1.2 26.0 ± 1.0 1.0 Unit::mm S (spacing) T (max. deviation of spacing) 5 52.4 ± 1.0 73.0 ± 1.5 1.2 1.5 5 52.4 ± 1.0 73.0 ± 1.5 52.4 ± 1.0 1.2 1.5 1.2 5 9. TAPE ON REEL PACKING Page-8 10 1 mm per 10 spacing 0.5 mm per 5 spacing STYLE TAPE ON REEL Normal Miniature A B Qty per reel HHV-25 HHV50S 40/66.5 49/75.5 5,000 HHV-50 HHV1SS 66.5 75.5 2,500 HHV1WS HHV2SS 87 96 2,000 HHV2WS HHV3SS 87 96 1,000 10. TAPE ON BOX PACKING STYLE Standard Lead Length Short Lead Length Unit: mm Qty per box Normal Miniature W(A) H(B) L(C) W(A) H(B) L(C) HHV-25 HHV50S 81 104 260 48 102 255 HHV-50 HHV1SS 73 45 258 HHV1WS HHV2SS 103 78 260 81 91 260 1,000 HHV2WS HHV3SS 103 94 260 81 91 260 1,000 5,000 1,000 11. SPECIAL TYPE (FORMING DIMENSIONS) M TYPE STYLE DIMENSIONS UNIT:mm Normal Miniature L ψD ψd P H HHV-25 HHV50S 6.3 ± 0.5 2.4 ± 0.2 0.55 ± 0.05 10.0 ± 1 10.0 ± 1 HHV-50 HHV1SS 9.0 ± 0.5 3.3± 0.3 0.55 ± 0.05 12.5 ± 1 10.0 ± 1 HHV1WS HHV2SS 11.5 ± 1.0 4.5 ± 0.5 0.8 ± 0.05 15.0 ± 1 12.5 ± 1 HHV2WS HHV3SS 15.5 ± 1.0 5.0 ± 0.5 0.8 ± 0.05 20.0 ± 1 15.0 ± 1 Page-9 MB TYPE STYLE DIMENSIONS UNIT:mm Normal Miniature L ψD ψd P H1 H2 t HHV-25 HHV50S 6.3 ± 0.5 2.4± 0.2 0.55 ± 0.05 10.0 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 HHV-50 HHV1SS 9.0 ± 0.5 3.3± 0.3 0.8± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 HHV1WS HHV2SS 11.5 ± 1.0 4.5 ± 0.5 0.8 ± 0.05 15.0 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 HHV2WS HHV3SS 15.5 ± 1.0 5.0 ± 0.5 0.8 ± 0.05 20.0 ± 1 10.0 ± 1 5.0 ± 1 1.4 ± 0.2 F TYPE STYLE DIMENSIONS UNIT:mm Normal Miniature L ψD ψd P h1 H1 max E max HHV1WS HHV2SS 11.5 ± 1.0 4.5 ± 0.5 0.8 ± 0.05 6.0 ± 1 5.0 ± 1 20 3.5 HHV2WS HHV3SS 15.5 ± 1.0 5.0 ± 0.5 0.8 ± 0.05 8.0 ± 1 5.0 ± 1 25 3.5 Page-10 STYLE DIMENSIONS UNIT:mm Normal Miniature L ψD ψd P h H max E max HHV1WS HHV2SS 11.5 ± 1.0 4.5 ± 0.5 0.8 ± 0.05 6.0 ± 1 8.0 ± 1 24 3.5 HHV2WS HHV3SS 15.5 ± 1.0 5.0 ± 0.5 0.8 ± 0.05 8.0 ± 1 8.0 ± 1 28 3.5 PN Type Forming for Taping (rated watts from 1/4W to 2SS size only) AV Type Forming for Taping (rated watts from 1/4W to 2SS size only) Page-11 12. Plant Address A. China Dongguan Plant 7-1, Gaoli Road, Gaoli Industrial Zone Tangxia Zhen, Dongguan, Guangdong, China (廣東省東莞市塘廈鎮高麗工業區高麗路 7-1 號) Tel. 86-769-8772 0275 Fax. 86-769-8772 0275 #4333 B. China Mudu Plant No.158, Jinchang Road, No.1 Building of NanBangIND.Zone, Mu Du New District, Suzhou, China (江蘇省蘇州市木瀆新區金長路 158 號南濱工業區 1 號) Tel. 86-512-66518889 Fax. 86-512-66519889 Page-12
HHV-50FT-52-22M 价格&库存
很抱歉,暂时无法提供与“HHV-50FT-52-22M”相匹配的价格&库存,您可以联系我们找货
HHV-50FT-52-22M
  • 5000+0.703835000+0.09147
HHV-50FT-52-22M
  • 1+0.32580
  • 100+0.30408
  • 300+0.28236
  • 500+0.26064
  • 2000+0.24978
  • 5000+0.24326
